997 : 2004- 79
996 : 1997-2005 44
993 : 1993-1998 6
Boxster : 1997- 19
Cayman : 2005- 11
Macan : 2014- 1
LMR
PostPosted: Mon Feb 23, 2015 8:53 pm    Post subject: Reply with quote
Chief
I don't think my iPhone understands Porsches...... PC
LMR
PostPosted: Fri Feb 27, 2015 9:44 pm    Post subject: Reply with quote
The temperature in the potting shed is hovering above freezing, so some progress is being made.
I started on the driveshafts this evening. as you can see, the boots were past their best.....
I would love to have taken more photos, but it is a dirty old job. But I did strip the CV joint, cleaned it in paraffin, and reassembled and regreased.
In its component parts
New boot
And new bolts / nuts for refitting tomorrow
Chief
PostPosted: Sat Feb 28, 2015 7:52 am    Post subject: Reply with quote
Brilliant Phil, looks like the freeze spray or as we reckoned with the Potting Shed heating up spray did the trick! I'll pop over later after removing my wheel studs. Or if it doesn't go to plan, I'll be over for commiseration coffee frustrated
james.mckenzie
PostPosted: Sat Feb 28, 2015 12:13 pm    Post subject: Reply with quote
Hi Phil,
Great thread. been scaring myself stupid this week reading resto jobs on 911UK.
Are you not stripping the driveshafts? I feel uneasy putting new CV boots over heavily corroded drive shafts.
J
LMR
PostPosted: Sat Feb 28, 2015 8:08 pm    Post subject: Reply with quote
James
As you will see from my thread, I have stripped the inner joints. I was intending on doing the same with the outer joint, I have even bought the tool to strip the joint from the shaft, but they appear pretty new. The rusty bit you can see is not the joint, it is a piece between the CV joint and the rubber boot. It is a pretty thick piece of metal, the jointing face and the inside are perfect. Therefore no point in replacing them. If there was any sign of weakness, they would have been in the bin.
LMR
PostPosted: Sun Mar 01, 2015 8:59 pm    Post subject: Reply with quote
Some more progress this weekend. First off, torquing up the driveshaft inner joints.
with plenty of extension bars to avoid being right under the car.
Whilst under the car, I thought I would tidy up the bumper mounting brackets
Just before I refitted the engine tins, I noticed some damage to the sheathing on the wiring loom.
Glad I spotted it. I have repaired with self amalgam wiring loom tape - I think I have forgotten to take a photo
LMR
PostPosted: Sun Mar 01, 2015 9:15 pm    Post subject: Reply with quote
Today has been reassembly. As I stripped down, the engine tins etc looked like this
After lots of hours, it now looks like this
A bit of a difference! I wish I had a better camera, it looks so much better in the flesh Smile
Engine tin side view
Still a long way to go, but the feeling of progress is very satisfying.
LMR
PostPosted: Sun Mar 15, 2015 9:49 pm    Post subject: Reply with quote
Evening all
I am at that funny point of this resto, where the finishing bits seem to be taking ages. I covered fitting the sunroof seals a little while ago. Putting the sunroof back in is a fairly simple exercise. But after operating it, it was staying very low at the back.
I tried various things, but in the end trimmed the seal to remove the excessive overlap, and now have a perfectly fitted sunroof Smile
I also refitted the catalytic converter today.
And it would have been rude not to start it up.... It was joyous to here it run again Very Happy
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Mon Mar 16, 2015 7:55 am    Post subject: Reply with quote
Good work.
What's left to do? When will she be back on the road?
LMR
PostPosted: Mon Mar 16, 2015 8:27 pm    Post subject: Reply with quote
Pete
Target date was 6th March, as that was the sixth anniversary of ownership, but clearly that has passed. I am waiting for a few bits and piece to turn up / be finished. I will then have a week off work with a view to final assembly and MOT. In all honesty, I don't think it will ever be finished, it will continue to evolve.....!!
LMR
PostPosted: Sat Mar 21, 2015 9:15 pm    Post subject: Reply with quote
So, another day at the potting shed - I do wish the weather would warm up....
When stripping the car, the headlamp bowls were thankfully rust free, but clearly could do with a tidy up.
What I did find was the tab where the retaining bolt goes through had stripped its thread. So I bought some weld on nuts and put them in. The shot below is post welding but before tidying up
This week, Mark got busy with the spray gun and I now have this Smile
The connector to the headlamp has seen better days........
So I bought these
And fitted up
And because I have a touch of OCD, I have bought new drain bung......
That was it for today, headlamps are going back in tomorrow.
LMR
PostPosted: Thu Mar 26, 2015 9:52 pm    Post subject: Reply with quote
Quick midweek update. I had a meeting finish earlier than expected this afternoon, and together with some parts arriving in the post, I had a quick session in the potting shed.
After cleaning out the threads with a tap, I waxoyled the headlamp bowls
And after fitting the new seals, popped in the headlamps.
I will pop the surrounds on tomorrow, and hopefully fit these
Chief
PostPosted: Fri Mar 27, 2015 8:33 am    Post subject: Reply with quote
More sterling work our Phil. Not long now until the next project arrives???
Baby blue and all that.......
LMR
PostPosted: Fri Mar 27, 2015 9:39 pm    Post subject: Reply with quote
Chief
Next one was due to arrive in Rotterdam next week and then be shipped to Southampton a few days later.
I had an email yesterday - apparently it is delayed a further 3 weeks...... I joked a few months ago that I was hoping it would arrive before I go it Le Mans. Turns out my joke might have been a prophecy...
For the rest of you who have no idea what Chief and I are talking about, all will be revealed soonish.
LMR
PostPosted: Fri Mar 27, 2015 10:03 pm    Post subject: Reply with quote
A busy evening at the potting shed
I started by fitting the surrounds to the headlamps. The old ones were ruined - I ran the car for a couple of years without them they were so bad, so brand new ones, which as you would expect, are lovely Very Happy
I them moved on to fit the wing mirrors. When removing the mirrors a couple of the terminals came away, do I bought new ones and fitted them - couple of photos below.
Fitting the mirrors is a fiddly business. I put on new seals, which chief covered previously. They take a lot of patience frustrated
I got there in the end.
Final job of the evening was to fit the head shields around the rear lights. The ones I removed were probably reusable, but would have needed a lot of tape to repair, so I bit the bullet and increased the smile on my OPC parts manager's face!
Old and new
Plenty of waxoyl applied before fitting
And fitted
I will be having a weekend without much fiddling in the potting shed. Restoration show at NEC tomorrow, classic car meeting on Sunday.
Chief
PostPosted: Sat Mar 28, 2015 8:11 am    Post subject: Reply with quote
Soon Phil, soon.......
What, when and where is the classic car meet?
I'll be at the NEC show on Saturday.
LMR
PostPosted: Sat Mar 28, 2015 5:44 pm    Post subject: Reply with quote
Chief
Classic meet is at Stratford Armouries
P
LMR
PostPosted: Sun Apr 05, 2015 8:11 pm    Post subject: Reply with quote
I have taken advantage of the bank holiday to get a few jobs done.
New (and powder coated) wing support brackets and nice shiny fittings added
Seats re dyed - photo was before they were buffed up
I have thought long and hard about getting the seats recovered. The piping (obscured by the masking tape) isn't brilliant, but I quite like the lived in look
Now the door mirror are on and everything working, I thoughts some rustproofing was appropriate, so out with this. As ever, it was rather cold in the workshop - I had to heat up the Dinatrol to get it to spray.....
And generously applied leaves them looking like this
Chief popped in yesterday, he reckons it adds a couple of kilos to each door! I have been around and made sure the drain holes are clear. New door membranes trial fitted
These are now in place but I haven't taken a photo
Next job is to replace the old speakers........
......with some nice, shiny new ones
paul284pt
PostPosted: Sun Apr 05, 2015 8:30 pm    Post subject: Reply with quote
No stone left unturned, nice work Thumb
Cheers,
Paul
1980-4 924 Turbo with mods. (ex Tony Dron - 12th at Le Mans 1980 with works 924 Carrera Turbo).
1984-9 911 SC (1982)
1989-93 911 Carrera Sport (1989)
2010- 964 Carrera 2 (1990) Redtek 3.8RSR
2012-14 Porsche Cayenne (2012)
2015-17 Porsche Cayenne Diesel S (2015)
2017- Macan Turbo Performance Package
LMR
PostPosted: Mon Apr 06, 2015 7:29 pm    Post subject: Reply with quote
Thanks Paul, I try my best!
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Page 6 of 10
