997 : 2004- 70
Boxster : 1997- 22
Cayman : 2005- 15
Les
2008 Porsche 997 Carrera 2
PostPosted: Wed Feb 15, 2017 4:34 pm    Post subject: Reply with quote
3 hours and £270 later and it's done.
This is how they should sound from the factory.
I still have the centre box so it's not as loud as my old 996.2, but on the other hand it sounds more classy and less boy racer.
You really need some good speakers to appreciate the sound but here is it.
Open Youtube Page
And now with the centre box replaced with an X-Pipe.
Open Youtube Page
And now with the centre box replaced with a crossover pipe. Louder still.
Open Youtube Page
This is what my 996.2 sounded like (same setup as a Gen1 997).
Open Youtube Page
Paul the pipe man: https://www.facebook.com/Paulscarwelding/?ref=br_rs
5 out of the 8 Porsches I've owned have all suffered catastrophic engine failures.
I've now brought an "unreliable" car and its been perfect ?
KJD
PostPosted: Wed Feb 15, 2017 5:46 pm    Post subject: Reply with quote
Surperb Les .
I've not had mine done yet but it's on the list for the spring.
Arctic Silver 997 Manual Carrera 2s
MidlifeC2S
PostPosted: Tue Mar 21, 2017 10:56 am    Post subject: Reply with quote
Can anyone recommend someone in the north east that does this?
s70rjw
PostPosted: Tue Mar 21, 2017 8:16 pm    Post subject: Reply with quote
Try Revolution at Brighouse between Leeds and Halifax. Great reputation and if you have a look at their website, they have a dedicated area the exhaust mod.
MidlifeC2S
PostPosted: Tue Mar 21, 2017 8:48 pm    Post subject: Reply with quote
Great thanks mate I'll check them out now. Cool
gav_doyle
PostPosted: Wed Apr 05, 2017 4:23 pm    Post subject: Reply with quote
Any suggestions for this job around SW London?
michaelbbwalker
2005 Porsche 997 Carrera 2S
PostPosted: Fri Apr 14, 2017 11:43 pm    Post subject: Reply with quote
Edited post.
Had this done and after a week or so, im not convinced yet...
Definitely sounds better at idle and trundling about, but when I am just driving about it sounds a bit, dare I say it, farty?
Will give it a little longer see if it grows on me but I may end up just swapping beck to standard!
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Tue Jul 04, 2017 11:24 am    Post subject: Reply with quote
Can anybody tell me conclusively, does a 997 gen1 rear silencer, fit a gen2?
I'm looking at buying used back boxes for gundo on my gen2.
I have H&S bypass, will gen1 back boxes fit: a) the bypass b) the tailpipes c) the mounting brackets?
Thanks in advance...
James
glenwells
PostPosted: Fri Jul 07, 2017 6:46 am    Post subject: different I believe Reply with quote
From what I remember they are different and not interchangeable.
Regards
Glen Wells
glenwells
PostPosted: Fri Jul 07, 2017 6:49 am    Post subject: Banana Hack pipe Reply with quote
Hi
I want to have the banana hack done to some spare rear boxes I have for gen2 car.
Anyone know what pipework i need to buy for the donor 'bananas'?
I did see a picture of a 2.5" 180 degree pipe but it did not have any other details.
ta
Glen Wells
Les
PostPosted: Fri Jul 07, 2017 10:35 am    Post subject: Reply with quote
the inlet and output are different on a gen2 so be careful on a banana mod.
adawes
PostPosted: Fri Jul 07, 2017 11:55 am    Post subject: Reply with quote
This is very tempting to get done!
I'm just wondering if having this done would bring a CEL light up or EM light? And if it is still ok to do on the gen 1 turbo?
Thanks all.
997.1 TT black manual.
adawes
PostPosted: Fri Jul 07, 2017 11:57 am    Post subject: Reply with quote
Thanks all.
IGNORE! Just found out that you can't!
Les
PostPosted: Fri Jul 07, 2017 12:28 pm    Post subject: Reply with quote
I've done it on a 996.2 & 997.2. not had any issues.
glenwells
PostPosted: Sun Jul 09, 2017 5:59 pm    Post subject: thanks Les Reply with quote
Thanks Les - looks like my option is for Gundo as trying to get a pipe around to the outlet on the Gen2 will not work.
Regards
Glen
Les
PostPosted: Wed Jul 12, 2017 2:00 pm    Post subject: Reply with quote
Just swapped the centre box for an X-Pipe.
Sounds great in real life when you hit 4K and it's under load.
Open Youtube Page
natpor
PostPosted: Sat Oct 14, 2017 8:47 am    Post subject: Exhaust hack and MOT emissions failure Reply with quote
did the exhaust hack on my 2006 4S a few months ago, loving the sound but yesterday if failed the MOT on emissions. I've known the MOT tester for over 30 years as I used to navigate for him on road rallies so I trust him completely - he said it's probably the exhaust hack as he's had numerous Scoobies in where the owners have removed a silencer to make them sound better and they subsequently fail the MOT on emissions. When the put the missing box back on they pass.
When I start the car sometimes there's a very brief rattle from the exhausts that I can't recreated when it's running or when I'm under the car so I'm suspecting the CATs may be due for replacement.
Suggestions welcome as my C4S is now off the road until I get it sorted.
Rob
 Filesize:  1.58 MB
 Viewed:  8100 Time(s)
glenwells
PostPosted: Thu Oct 26, 2017 2:39 pm    Post subject: Banana mod 997.2 Reply with quote
Tanks for the info Les. Work all done and fitted them myself. A bit tight to fit but the modder kept the pipes as close as possible. Sounds much better but certainly not offensive.
Will see if there is any issues next month come MOT. Think it should be ok as only took pipe from the blanked nipple to the existing outlet.
ta
glen
Les
PostPosted: Thu Oct 26, 2017 2:43 pm    Post subject: Reply with quote
I've had 3 x Gundo'd MOT's without an issue.
PostPosted: Thu Oct 26, 2017 6:14 pm    Post subject: Reply with quote
I have never heard of a gundo failing the mot its one of the most done mods to these cars. I suspect as your thinking its your cats Thumb
Goto page Previous  1, 2, 3 ... 16, 17, 18, 19  Next
Page 17 of 19
