LED headlamps, The Four-Point Porsche Principle
Moderator
8 Feb 2008
7,361
Light is one of the distinguishing features of Porsche sports cars too - on the road as well as the racetrack. We examine the fascinating interplay of design and electricity, as shown by the example of daytime running lights.
Light is identity, by day as well as by night. It has attributes that also apply to Porsche sports cars: purist, unmistakable, striking. And it too follows the principle that a Porsche should be recognizable as a Porsche from afar. Since the introduction of daytime running lights, light has represented a new and fascinating challenge for Heinz Redlich, a designer at the Porsche Design Studio at the Weissach Research and Development Center. Challenges like these bring out the best in designers, because LEDs (light-emitting diodes) at Porsche have to be more than just a string of lights. "That's not for us," remarks Redlich, "because it'll soon be obsolete." A Porsche is known for its strong, enduring characteristics, especially when it comes to light.
Linking racing with the road, the 918 Spyder has four-point visuals as a matter of course.
From the idea to the perfected product, Redlich has often sat down with Peter Heimpel, who works on electrical systems development. After all, the space available for putting this ambitious project into place is not much larger than the cross-section of your average melon. A combination of specifications and inspiration led to the development of the four-point principle, which initially took up residence as a unique feature in only the top models of the different series, such as the Panamera Turbo (2009), the 911 Turbo, the Cayenne Turbo, and the Macan Turbo. The basic philosophy is clear. "Every Porsche needs a visage, and the four-point visuals establish the brand's identity. They clearly signal that this is a Porsche," observes Redlich. The underlying idea with the four LED spotlights emerged during drafting: "Four points around a module are ideal. Three are harder to configure. And more would be too many."
Light design is always based on both the technical requirements and the car-body environment. If headlights are positioned high, that means the low beams will have a long range. But this position brings a certain challenge. "The higher the position, the further back they are," explains Heimpel, "because the car slopes toward the front. That puts us back into the wheel cup." This results in part because headlights are highly complicated structures, which consist not only of glass, reflectors, and light units. Beyond the purely illuminative aspect, headlights are chock full of technology. Ever since the cornering function was introduced, an entire armada of functions has to share the small installation space, including the requisite cooling systems.
There are also various regulations, crash guidelines, and pedestrian protection requirements to consider. In certain countries, such as the United States, the high beams may not be mounted above the low beams. Therefore, the entire design team confers constantly with the engineers during the development process to solve this complicated puzzle. But ambition is also a distinguishing feature of the brand. As Heimpel confirms, "At the end of the day, a headlight has to have great visuals and top performance. That's the way we operate."
Four-point lights clearly place the Macan Turbo in the Porsche family of top sports cars.
Porsche has turned what used to be a simple lightbulb and diffusing panel into headlamps that no longer require rippled glass, thanks to free-form reflectors. And for reasons of efficiency - a lightbulb converts only three percent of the energy into light - it has moved from xenon lamps to LEDs, which convert 20 percent of the energy into light. Pure LED headlights shine from the 911 Turbo S, the Panamera Turbo S, and the 918. LED four-point daytime running lights are combined with xenon headlights to provide the perfect lighting from the car and onto the road. Porsche's top performers also have Porsche Dynamic Light System (PDLS) Plus, headlights that feature nearly everything: dynamic range control, adverse weather function, and a camera-based system that adjusts light distribution. The High Beam Assistant detects oncoming traffic and automatically dims the lights. The Intersection Assistant activates the left and right indicators, which broadens the cone of light and provides greater illumination of the area directly around the vehicle. In other words, PDLS stands for little high-tech jewels.
Advance warning of a dominant sporty presence: Light from the 911 Turbo S.
That's not all of the artistry that has gone into these lights. The system for the Porsche 918 Spyder was also developed with an emphasis on efficiency. Because this super sports car is already designed with the greatest possible fuel efficiency, it requires the most lightweight light module from Weissach. "If a module can pivot, that means more weight," says Redlich. So the 918 does without pivoting headlights, including the associated electronics and control units, which means its system is 1.5 kilos lighter than that in the 911. But the four-point principle is everywhere in the Spyder - including its indicator lights.
Heinz Redlich is responsible for the look of Porsche's current generation of headlights.
The headlights also help to give Porsche a unique visage on the racetrack, which is just the thing for the World Endurance Championship, with the 24 Hours of Le Mans as its highlight (pun intended). So it only makes sense that the LMP1 racing car, the 919 Hybrid, also has four-point visuals. Along with clear demands on the light itself: a lot of it, and a range of up to 800 meters. At high speeds, on dark tracks, and with slower cars on the course too, the light serves a number of safety purposes. As Martin Kaussen from the racing development department explains, "It has to shine as brightly as a searchlight from start to finish, by day and by night." The guiding premise is to keep it simple. To illuminate a racetrack without oncoming traffic in the best possible way, two main beams and two pencil beams were developed. As Kaussen notes, "We don't need any low beams or daytime running lights; we need full, far-reaching light that doesn't blind the cars in front and helps show them the direction to take when moving out of the way."
Signal effect: LED lights also serve to mark the brand on the Panamera Turbo S.
In order to be as energy-efficient as possible, the headlight control unit has daytime and nighttime modes in its program that runs the continuous main beam. When drivers flash their headlights to signal a passing maneuver, at night the program briefly reduces the pencil beams, and during the day it briefly increases the otherwise continuously low level of illumination. The slower GT cars (with yellow headlights) can recognize the faster LMP1 cars by their pure white beams - and the Porsche 919 Hybrid by its four eyes. Adapted from standard-series cars, the four-point principle takes on completely different functions in racing. If just one of the light modules goes out, the regulations require that it be replaced immediately, so intelligent cooling and mounting systems have been designed to prevent this. The entire concept is Porsche Intelligent Performance in action - extremely lightweight, extremely robust, and extremely bright. It loses very little energy to heat dispersion, distributes light for the best-possible sight conditions, but features a simple design.
Martin Kaussen (left) develops headlights for racing cars, Peter Heimpel for standard-series cars.
Redlich is already working on designing the next generation of headlights for the standard-series models. Now that four-point visuals can be ordered as an optional feature for many series, he is considering how he can provide the top models with a different distinguishing feature. What that will be remains a secret - for now, at least. But one thing is clear for the designer. "We're not going to throw in every technical development just because it's currently in fashion. It's important that every Porsche is recognizable as such from both the front and the back on account of its four-point visuals."
Source, christophorusmagazine-367
124,555
1,441,474
48,969
Stulees65
