996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Jonathon555
PostPosted: Sat Apr 02, 2016 8:30 pm    Post subject: Reply with quote
Great looking car, keep the updates coming
916v996
Location: ----Berry Hill----- 2004 Model C4S Manual + mods
PostPosted: Sun Apr 03, 2016 1:52 pm    Post subject: Reply with quote
C11BRA wrote:
Nice thread Lee
I get it!
Purists look away (front bumper)
I had this front end on my C2 996.1 and loved it (the old one was cracked). Got loads of positive comments from Jo Public. I wouldn't worry what purists think. If they were that concerned about their pride and joy they wouldn't take them out the garage. You pays your money tyou takes your choice.
Current: 2004 model C4S manual, 2wd + mods
Current: 1999 Ducati 916 Foggy Rep
Previous: 1999 C2 Tip
Previous: Aprilia RSV
916v996
PostPosted: Sun Apr 03, 2016 2:03 pm    Post subject: Reply with quote
[quote="996lee"]another small update
always thought the wheels looked a bit lost in the arches so purchased some 15mm spacers
Hi Lee. I've got the same make spacers but 20mm on my C4S. They do look better but a word of advice. Keep your ears open for premature bearing wear and possible tyre rubbing. I've got coil overs, so set mine pretty low but not too low to avoid rubbing. I was running 325/25 x 20 on the rears but now got 295/25 x 20. I'm after some 305/25 x 20 as I think they will be spot on.
996lee
PostPosted: Mon Apr 04, 2016 8:28 am    Post subject: Reply with quote
Thanks for the comments guys Thumb
Next up when I get time
Low temperature thermostat
And a rss under drive pulley Cool
2001 Carrera 4 aero all the way!!
996lee
PostPosted: Tue Apr 19, 2016 5:32 pm    Post subject: Reply with quote
Managed to get my new rss under drive pulley fitted today
And also my lower temp thermostat
Still getting the air out the system as there is roughly a litre of coolant that it doesn't seem to want back at the moment lol
But I shall take it for a good blast later n see what the bum dyno says
drabux
PostPosted: Tue Apr 19, 2016 10:18 pm    Post subject: Reply with quote
The underdrive pulley has been measured on dynos a few times and makes around 6-8bhp difference.
2008 Porsche 997TT
2007 Mazda 6 Derv
1977 Saab 99 with 900T engine and 9-3 Trionic engine control
askgeez
PostPosted: Wed Apr 20, 2016 7:33 am    Post subject: Reply with quote
RSS engine mounts thumbsup love them
Please keep us posted on your findings on the pulley. Spent about an hour reading up on various forums , reviews seem really positive.
Esp for "just" £300
997.2 GTS coupe PDK
997.1 C4s coupe Manual (sold)
996lee
PostPosted: Wed Apr 20, 2016 1:09 pm    Post subject: Reply with quote
Thanks guys Thumb
The under drive pulley definitely makes a noticeable difference and worth every penny Cool
temp wise with the LTT I was thinking it seemed too cold if anything these pics were after about a half hour of driving
coullstar
PostPosted: Wed Apr 20, 2016 1:57 pm    Post subject: Reply with quote
That pretty much spot on with LTT fitted.
2000 Audi B5 RS4
Madasmad
PostPosted: Wed Apr 20, 2016 6:50 pm    Post subject: Reply with quote
996lee wrote:
Thanks guys Thumb
Hi Lee,
Firstly great card and really interesting thread!
I have had my 996.1 C4 for about 3 months. It has the low temp thermostat fitted but I was interested to know what temp yours ran at prior to fitting it? Mine runs @80 degrees like yours but it did creep up yesterday to @90 in traffic.
The spacers make the difference! Thumb
askgeez
PostPosted: Wed Apr 20, 2016 11:03 pm    Post subject: Reply with quote
Your pictures show the water temperature
I have the LTT on my 997. The water temp also shows 80c. Been driving it a year and never seen it anything other than that , both pre and post fitting the LTT
My oil temperature gauge definitely reads lower , post LTT fitting
Read that somewhere on here
Question
997.2 GTS coupe PDK
996lee
PostPosted: Sun Apr 24, 2016 6:34 pm    Post subject: Reply with quote
Ah I see unfortunately I don't have the oil temp gauge so can't comment on that
But mine certainly ran a little hotter water temp wise before hand
If I remember correctly the needle used to sit mid way of the 0 on the 80
Pulley wise I wouldn't of expected to feel 6-8 hp but can certainly can so happy with that Thumb
BHZ661
PostPosted: Mon Apr 25, 2016 7:23 am    Post subject: Reply with quote
Does the pulley make that much noticeable difference , its on my list to do , do you feel power gain or just spinning up quicker, top work thumbsup
996lee
PostPosted: Wed May 11, 2016 2:42 pm    Post subject: Reply with quote
After seeing the results a fellow owner had with his led side lights I decided to follow suit
So before orange glow
And after
Lots of different bulbs out there but found one that didnt have LEDs on the sides as I fancied more of a spotlight effect
So went with these (standard bulb on left for comparison )
All in all less than a tenner well spent
996lee
PostPosted: Thu Nov 24, 2016 5:26 pm    Post subject: Reply with quote
Recently got stuck in a Friday traffic jam and noticed the temp needle getting a lot higher than normal
So after doing some investigation work realised only one of the fans was working
Luckily before shelling out for new fans from porsche read a few threads on here and sure enough Alex yates had the same thing and found out the resistor due to the stupid position they are and being 16 years old are often the cause and a suggested replacement was only £5 so went ahead and replaced both which was just a small soldering job
Old ones
And new shiny ones fitted
And that worked a treat and both fans are now working nicely again
Marky911
Watkins Glen
PostPosted: Thu Nov 24, 2016 8:47 pm    Post subject: Reply with quote
Good work Lee. Good to see you're still tinkering and perfecting things.
I'm looking forward to getting stuck into mine next year.
Harv
PostPosted: Sun Nov 27, 2016 11:35 am    Post subject: Reply with quote
Would you know the aux belt size that was fitted along with your under drive pulley?
I will try a search with the part number off the photo you posted and see what it turns up Thumb
996lee
PostPosted: Sat Feb 11, 2017 4:52 pm    Post subject: Reply with quote
sorry buddy totally missed this post
i got it from design 911 and think the part number is on there Thumb
996lee
PostPosted: Sat Feb 11, 2017 4:53 pm    Post subject: Reply with quote
Couple of minor updates
Major service done recently
Fitted a cheap mobile phone holder so I could use it as a sat Nav easily
Even though they weren't particularly bad just yellowing a touch I removed the headlights and used the meguirs one step kit
Completed one on the left for comparison
And decided I'm going to try a 911 badge on the rear instead of the c4
And lastly booked into centre of gravity on the 4th March for new top mounts bump stops and coffin arms as well as anything else needing replacing and setting up
BlackTurbo
PostPosted: Sat Feb 11, 2017 11:00 pm    Post subject: Reply with quote
Great thread and great read. Look forwards to seeing the freshened lights go on and new badge.
Goto page Previous  1, 2, 3, 4, 5, 6  Next
Page 4 of 6
