Hi guys,
My car will NOT start? It has fuel, charge, has no alarm/immobiliser other than the Porsche standard stuff. When you try and start it, it will just turn over and not fire up into life..
One thing worth noting, I topped up the oil a little too much. Maybe a litre absolute maximum, checked the reader and it said it was above the max so I immediate remove a litre of oil or so from the sump and tightened again..
I'm not sure whether the oil over filling is relevant, because I didn't attempted to drive the car before I put a bit of oil in, and if it was over, which I find it very hard to believe it was, it would have minimal as I only added around a litre.
Thinking back over the last couple of weeks, the car has been getting harder to start (cranking a little longer than fire up), but that could be my brain playing tricks on me!
Called the AA and I don't have home start as my cover is through my bank.. They wanted 104 just to come out to me! Then that doesn't cover towing the car to a garage should they not be able to fix, which I doubt they will.
In a bit of a rut. I hope I have been clear here, if not please ask and I will answer. Thanks guys and really looking forward to some ideas/knowledge!
Thanks, Steve
Thanks, Steve
