991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
PostPosted: Fri Jul 11, 2014 8:10 pm    Post subject: DIY Ice Saver Reply with quote
After fitting new condensers last month and doing a 2K mile trip next week thought it'd be a good idea to try and preserve the life of them. Did a DIY mesh guard today with a couple of mesh sheets I bought off eBay for £15.47. Looks quite good and should stop any nasty stones puncturing the rads.
See photos below.
PostPosted: Fri Jul 11, 2014 8:15 pm    Post subject: Reply with quote
Photos
 Filesize:  217.16 KB
 Viewed:  2898 Time(s)
 Filesize:  225.79 KB
 Filesize:  200.96 KB
 Viewed:  2899 Time(s)
 Filesize:  197.99 KB
Gilesharrison
PostPosted: Sat Jul 12, 2014 6:43 pm    Post subject: Reply with quote
Nice job. How did you attach the mesh to the inside of the bumper? Glue/ screws?
PostPosted: Sat Jul 12, 2014 7:36 pm    Post subject: Reply with quote
2 small M4 nut & bolts through the mesh into the plastic shroud at the back part that's covered with the PU. The front inside edge is just pushed up against the shroud in front of the condenser.
Storm996
PostPosted: Sat Jul 12, 2014 7:56 pm    Post subject: Reply with quote
Very neat looking.
Good job.
PostPosted: Sat Aug 09, 2014 5:08 pm    Post subject: Reply with quote
Had the PU off again today so took a couple of quick snaps showing how I'd bolted the mesh in.
 Filesize:  247.29 KB
 Viewed:  2528 Time(s)
 Filesize:  129.49 KB
Kryton
PostPosted: Tue Aug 13, 2019 7:25 am    Post subject: Reply with quote
Great looking job there Alex.. Thumb
2019 Gen 2 Macan
PostPosted: Tue Aug 13, 2019 7:42 am    Post subject: Reply with quote
Been on 5 years now and still looks the same. Condensers still clean as a whistle too.
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Sat Aug 17, 2019 6:27 am    Post subject: Reply with quote
What's the spec Of The mesh? What do you type as eBay search? I get millions of hits no idea what to use..
PostPosted: Sat Aug 17, 2019 9:55 am    Post subject: Reply with quote
That took some digging!
There you go:
https://www.ebay.co.uk/itm/Woven-Wire-10-Mesh-30cm-x-30cm-x2mm-Coarse-gauze-Stainless-Steel/261967305956?epid=1111953499
You need one for each side. thumbsup
wasz
PostPosted: Sun Aug 18, 2019 6:56 pm    Post subject: Reply with quote
i did the same 5 years ago with cheapo black mesh and it still looks fine.
