997 : 2004- 63
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
Fulla
PostPosted: Fri Jan 10, 2020 8:06 pm    Post subject: Re: Replacement HID/Xenon bulbs Reply with quote
-- 997 -- wrote:
JT888 wrote:
I bought and changed over the old HID xenon bulbs (2007 car) to Osram night breaker - Laser Xenarc. D2S fitting. Lights are now much brighter. Colour is pretty much the same as Philips set that I took out. Easy DIY job.
Whilst I had the left headlight unit out, I saw a hose had disconnected. I reconnected it and now my headlamp washers squirt water again!
This sounds good!! Is there a link to the purchase of the bulbs, i.e. ebay etc or a bulb part number please could do with a light brightness upgrade Grin
J
Assume these are the ones:
https://www.amazon.co.uk/XENARC-BREAKER-brightness-discharge-66240XNL-HCB/dp/B07FYTN7VF
______________________
997.1 GT3
911 3.2 Clubsport
Ex 993 C4S
Ex 993 C2
Ex 996 C2
Fulla
PostPosted: Sat Jan 11, 2020 6:53 pm    Post subject: Reply with quote
Ordered the Osram night breaker - Laser Xenarc.
Should arrive tomorrow, hopefully in day light. Then I can fit an test Monday.
997.1 GT3
911 3.2 Clubsport
Ex 993 C4S
Ex 993 C2
Ex 996 C2
-- 997 --
PostPosted: Sat Jan 11, 2020 11:03 pm    Post subject: Re: Replacement HID/Xenon bulbs Reply with quote
J
Cheers 😁👍 ill look into them!! I have xenon in my 2005, these are ok to fit?
J
JT888
PostPosted: Sun Jan 12, 2020 12:54 am    Post subject: Xenon replacements Reply with quote
OSRAM XENARC NIGHT BREAKER LASER D2S, +200% more brightness, HID xenon bulb, discharge lamp, 66240XNL-HCB, duo box (2 lamps) https://www.amazon.co.uk/dp/B07FYTN7VF/ref=cm_sw_r_cp_apa_i_W1MgEb8TS4DK2
911 Carrera S 997.1
X3 E83
JT888
PostPosted: Sun Jan 12, 2020 1:06 am    Post subject: Xenon bulb replacement -tip Reply with quote
Tools you'll need.
Headlamp removal tool from car toolkit.
Philips head screwdriver.
Remove portion of front trunk side liner to reveal rubber bung. Remove bung, insert headlamp tool, release headlamp with what sounds like a nasty clunk.
Philips screwdriver to remove 4 screws at back of headlamp unit. Remove back cover by pressing in tabs. Twist off silver braided plug from back of bulb to give some slack to cables to get back cover out of the way. Pinch the wire retainer and hinge out. Remove old bulb. Open packaging for n
ew bulb but don't touch the bulb glass! Place new bulb in by handling only the base of the bulb. Replace all connectors, covers and headlamp unit back in car. Wash plastic headlamp with plastic polish to best see the new light!
911 Carrera S 997.1
X3 E83
Cannop
PostPosted: Sun Jan 12, 2020 1:35 pm    Post subject: Reply with quote
Just replaced all my C2S's interior bulbs with LED equivalents, the engine bay, frunk, glovebox, footwells, interior lamps and kerb lights. Those kerb lights can be awkward buggers to remove!
Full fat Hartech'd C2S Manual
Kettmark
PostPosted: Sun Jan 12, 2020 9:58 pm    Post subject: Reply with quote
Where is the best place to obtain the leds?
Kettmark
PostPosted: Sun Jan 12, 2020 10:01 pm    Post subject: Reply with quote
I bought my 997 a new Bosch battery as the previous one wasn't taking charge after a month of no activity.
Cannop
PostPosted: Mon Jan 13, 2020 8:00 am    Post subject: Reply with quote
I bought mine here as a kit, you also get a spare ceiling light and engine bay/trunk bulb.
911lagoongreen
PostPosted: Wed Jan 15, 2020 11:08 pm    Post subject: Reply with quote
I bought a set of OZ Ultraleggera’s!Smile
 Filesize:  141.1 KB
 Viewed:  111 Time(s)
Goto page Previous  1, 2, 3 ... 138, 139, 140
Page 140 of 140
