997 : 2004- 65
Boxster : 1997- 31
Macan : 2014- 6
badbadtz
PostPosted: Tue Sep 24, 2019 12:01 pm    Post subject: Reply with quote
2 new PASM front shocks and bump stops. Only the nearside was shot but decided to change them in pairs
bullet-proof_biscuit
PostPosted: Tue Sep 24, 2019 12:04 pm    Post subject: Reply with quote
And the X51 centre rad kit
 Filesize:  110.91 KB
 Viewed:  1417 Time(s)
911rpd
PostPosted: Tue Sep 24, 2019 12:38 pm    Post subject: Reply with quote
Whats the cost/part no on this - I remember reading about it a while ago but it was an old post and the price seemed really cheap/reasonable* for a Porsche part!
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Tue Sep 24, 2019 2:09 pm    Post subject: Reply with quote
it is cheap (under £100) but its a very bad idea as it makes your engine actually run hotter rather than colder..... best ignored and buy a hartech low temp thermostat instead Thumb
PostPosted: Wed Sep 25, 2019 3:44 pm    Post subject: Reply with quote
Oorrr; fit a thermostatic valve on to the centre radiator inlet hose AND a Hartech low temperature thermostat, like me!
Very Happy Very Happy Very Happy
Hertsdriver
PostPosted: Thu Sep 26, 2019 11:02 am    Post subject: Reply with quote
Good stuff, most (like me) are/were unaware that fitting an additional rad actually increases engine temps (which is completely counter intuitive) so if you have found a way around this ot would be good if you could post up a 'how to' to help others out, especially if you have a link to the part number of the inline thermostat you've used Thumb
C4Silver
PostPosted: Thu Sep 26, 2019 12:19 pm    Post subject: Reply with quote
This is achieved I believe by the engine having to work harder to keep the coolant up to temp ?
Sounds counter productive and illogical but if you read the relevant posts it all kind of makes sense ? I only read all this after I’d bought the kit, thinking that the way to go was increase cooling efficiency reduce the engine temp and hey presto...... but nope,
Any way this week....... I have mostly been buying a private plate !
Jam911
PostPosted: Thu Sep 26, 2019 6:53 pm    Post subject: Reply with quote
What is the plate?
Current '07 997 C4S
Ex '99 2.5 Boxster
C4Silver
PostPosted: Thu Sep 26, 2019 8:01 pm    Post subject: Reply with quote
ELF 3R
Or TREVOR ? lock depending on how hard you squint, and stand on one leg, whilst hopping ?
Bought off a Forum member,
SGH
2010 Porsche 997 Carrera 4S
PostPosted: Thu Sep 26, 2019 8:21 pm    Post subject: Reply with quote
2 year Porsche Warranty.
Porsche 997.2 Carrera 4S - Carrara White / Cocoa
Defender 300Tdi 110 HCP - Keswick Green
Connect L2 Double Cab - Moondust Silver
VW California Ocean 150PS DSG - Reflex Silver
Brunty88
PostPosted: Thu Sep 26, 2019 9:23 pm    Post subject: Reply with quote
2 of these
 Filesize:  1.56 MB
 Viewed:  1188 Time(s)
PostPosted: Thu Sep 26, 2019 9:46 pm    Post subject: Reply with quote
C4Silver wrote:
ELF 3R
You might get a bit of this when you're out and about...
C4Silver
PostPosted: Thu Sep 26, 2019 10:56 pm    Post subject: Reply with quote
I thought all this name calling malarkey had been ostracised now with all these snow flakes and gender fluidity nonsense ?
I thought now would be a good time to purchase, so I can take shelter from the dwarfe throwers.......
Surprised
Highhhhh HOOOoooooo !!!!
badbadtz
PostPosted: Fri Sep 27, 2019 10:42 am    Post subject: Reply with quote
991 steering wheel Cool
 Filesize:  488 KB
 Viewed:  1083 Time(s)
tony_i
PostPosted: Fri Sep 27, 2019 12:49 pm    Post subject: Reply with quote
Is that an Android head unit?
How do you find it?
badbadtz
PostPosted: Fri Sep 27, 2019 12:58 pm    Post subject: Reply with quote
How do you find it?
Nope that's stock HU
Jam911
PostPosted: Fri Sep 27, 2019 2:06 pm    Post subject: Reply with quote
New exhaust gaskets and stainless exhaust bolts.
Glamorous I know.
Current '07 997 C4S
Ex '99 2.5 Boxster
splattric
PostPosted: Sun Sep 29, 2019 10:16 am    Post subject: Reply with quote
Seems a common theme.
New exhaust gaskets (had a slight blow on one of them) and stainless exhaust bolts
997 C4S - sold
997 turbo
PostPosted: Tue Oct 01, 2019 12:17 pm    Post subject: Reply with quote
No, the thermostat is on the coolant inlet side of the engine, so the extra radiator capacity makes the coolant 'cooler', this cooler coolant then hits the thermostat when coming into the engine, causing the thermostat to close... Causing the engine to run slightly hotter.
The centre radiator thermostat opens only when the factory radiators & fans cannot maintain the coolant temperature, thus diverting to the extra radiator only when required, reducing 'excess' cooling capacity and the above closing thermostat scenario.
Hertsdriver
PostPosted: Tue Oct 01, 2019 1:33 pm    Post subject: Reply with quote
Hertsdriver wrote:
Good stuff, most (like me) are/were unaware that fitting an additional rad actually increases engine temps (which is completely counter intuitive) so if you have found a way around this it would be good if you could post up a 'how to' to help others out, especially if you have a link to the part number of the inline thermostat you've used Thumb
thumbsup
Goto page Previous  1, 2, 3 ... 135, 136, 137, 138  Next
Page 136 of 138
