Stuttering and kangaroo jumps
Stevie43_uk
21 Mar 2005
4
Hi All,
Just wondered if anyone can help.
Engine runs fine but if it is held around 2300 rpm in any gear it surges and causes car to stutter and kangaroo ?
I have to dip the clutch to stop it.
I know it's difficult to diagnose on forums, but could someone help with suggestions.
It is due a service so may be associated with that maybe ?
Many thanks
Steve
Hi Steve, are you 100% sure it is not the clutch slipping?
That rev range is just about when you are starting to apply some proper load....
If it's got an Lambda O2 sensor it could be that :dont know:
Thanks all.
It has had a clutch recently so don't think it's that - it does it when I hold it at 2300 rpm and not when I'm booting it.
Ta
Steve
Yep, could be. On these cars can you unplug the 02 and go for a quick drive to see if that's what's causing it? Have done that on other cars but don't know what the Porsche ECU is looking for.
Also consider the sparking, plugs to dizzy...
Leads.
Lots of them. Hard to see compared to most cars (eg run in dark look for arcing), but this too is also capable of producing the symptoms you describe.
Go with simple things first, plugs,leads,fuel fiilter,air filter etc.
Air flow meters can wear out on that type of injection.
The engine bay wiring loom and connectors can be suspect on Carreras also.
124,590
1,441,848
49,021
Camarocane
