997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
318touring
PostPosted: Sat Apr 19, 2014 10:16 am    Post subject: Setting correct date in PCM 2.0 Reply with quote
Yes, I have read the manual. The Date/Time option is greyed out and not-selectable.
I have just changed the battery, and tried to set the date (currently set to 1998), but the Date/Time was greyed out. I can set time easily.
Any help please, it is PCM 2.0 (on 2003 C4), I know PCM's almost useless but it irks me to not being able to set something that simple correctly.
gilessaville
PostPosted: Sat Apr 19, 2014 7:23 pm    Post subject: Reply with quote
Fell for this myself a few weeks ago. It will set itself once out in the open via gps I assume!
I spent some time scratching my head on this one until I went for a spin and voila....on my 2004 PCM2. frustrated
318touring
PostPosted: Sun Apr 20, 2014 8:38 am    Post subject: Reply with quote
Yes, I read through the Porsche workshop manual, seems that it needs maps? I don't have the maps for NZ and can't be bothered getting one since it'll be out of date.
jamesdrew1975
PostPosted: Mon Apr 15, 2019 11:58 am    Post subject: Correcting the date on PCM2 Reply with quote
So, I know this is probably a bit OCD but my PCM2 (2003 turbo) is showing the wrong date and for the life of me I can't find anywhere in the manual where you can manually adjust the date if it's not showing correctly. Does the date automatically update from radio or GPS signal or do I need to get my indie to change it via OBD?
2003 996 Turbo
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Mon Apr 15, 2019 12:20 pm    Post subject: Reply with quote
I would have thought it would have picked that up from the GPS, what date is it showing?
jamesdrew1975
PostPosted: Mon Apr 15, 2019 8:19 pm    Post subject: Reply with quote
It's showing 4th Jan 2019.
2003 996 Turbo
Paynewright
PostPosted: Tue Apr 16, 2019 9:26 am    Post subject: Reply with quote
Did they fit a flux capacitor at the last service? Smile
4b4
PostPosted: Tue Apr 16, 2019 10:03 am    Post subject: Reply with quote
US date format, possibly, 04/01/2019?
2004 996.2 C4S Cabrio Tip in Arctic Silver
PostPosted: Tue Apr 16, 2019 7:06 pm    Post subject: Reply with quote
Pcm are my very weak point i'm afraid but don't you just press set button , pcm settings then the date is listed and you can alter it ?
Failing that it can be done with a tester but you need one that will communicate with the pcm .
jamesdrew1975
PostPosted: Tue Apr 16, 2019 8:41 pm    Post subject: Reply with quote
Date format can be changed (dd/mm/yy, mm/dd/yy etc) but you can't manually enter the date although you can manually enter/set the time. Leads me to think that there must be some automatic system (GPS or radio) which it uses for the date but can't find any clues. Makes me wonder though if that's the case why can't it set the time automatically too? Dont know
2003 996 Turbo
PostPosted: Wed Apr 17, 2019 7:39 pm    Post subject: Reply with quote
Just a stupid question but your nav map does update and show your correct location doesn't it ?
if it is done by GPS and the GPS antenna is not working .. common after a screen replacement then it wont update time or date .
jamesdrew1975
PostPosted: Thu Apr 18, 2019 11:49 am    Post subject: Reply with quote
Ah, not had a screen replacement but do have a large bulls-eye stone chip at the bottom of the screen in the middle. Need to get insurance to look at it to see if it's repairable or a new screen job. I'll look at my nav next time i go out to see if position updates. That should hopefully rule out any potential GPS antenna issue.
Thanks for all of the input so far.
2003 996 Turbo
