Boxster : 1997- 25
nickjonesn4
PostPosted: Fri Jul 19, 2019 11:29 pm    Post subject: Reply with quote
kingroon wrote:
Endoman wrote:
Apart from the engine and bodywork I have converted most of my S2 to 968 CS spec...
I want to do this.. Did the 944 come in Polar Silver..?
Quote:
Has to be the ultimate 993 companion
My 968 Sport is going to be for sale imminently, so Trev, if that Itch is getting Itchier [!] and you wanna come have a look.. Wink
Looks great. Is it Arena?
1996 Carrera S Vesuvius Metallic
2016 Golf R
2005 AMG E55K Wagon
kingroon
PostPosted: Mon Jul 22, 2019 7:41 am    Post subject: Reply with quote
Guards Red.. Cool
Hasta Luego..
KingRoon
1994 993 Carrera Coupe
Fulla
PostPosted: Tue Jul 23, 2019 7:56 am    Post subject: Reply with quote
Full service and MOT -advisory on leaking rear shock.
2 x New rear Bilstein shocks, as 1 was leaking and I was advised by CofG to replace the opposite side.
4 x Michelin PS2's - I needed 2 new rears and then this weekend got a nail/screw in the front...quoted £633 fitted at Wembley tyres so tomorrow it goes in for the new boots.
Then on the 8th and 9th I am booked into CofG for the chassis then the next day the long drive to Wayne for him to work his magic. Really looking forward to the drive back as I'll have 4+hours to feel the difference in the remap.
______________________
993 C4S
911 3.2 Clubsport
Ex 993 C2
Ex 996 C2
pierrebear
PostPosted: Tue Jul 23, 2019 9:15 am    Post subject: Reply with quote
Fulla- I’ll be interested to hear your thoughts re Wayne. On my list of every-growing upgrades...
1995 Carrera 2 coupe manual, midnight blue
EX 997.1 Carrera 4S coupe manual, basalt black
EX 2003 Mercedes SL500, green black (dark blue!)
Fulla
PostPosted: Tue Jul 23, 2019 9:55 am    Post subject: Reply with quote
I'll report back after the 9th. It's a long drive circa 4+hrs there and back so I should be able to feel the difference, I am just hoping with schools out the traffic will be forgiving!
993 C4S
911 3.2 Clubsport
Ex 993 C2
Ex 996 C2
Endoman
PostPosted: Tue Jul 23, 2019 5:50 pm    Post subject: Reply with quote
Oil cooler thermister to go with fan resistor, one of those while I'm in there. What a pig that resitor is to get at. Removed horns, removed lower cooler support and upper stay. Dropped cooler after removing aluminium blanking plate and the plate with the resitor on is easly got at. Remove plate unplugging resistor and smash it to bits just to make me feel better. All in 25 degree heat with sweat dripping in my eyes.
Cameltoe & Heel
PostPosted: Thu Jul 25, 2019 7:25 am    Post subject: Reply with quote
Yes a pig of a job with the wing on, did mine whilst wing was removed so much easier. Gave it all a good clean up too.
Trev
Tombri
PostPosted: Thu Jul 25, 2019 8:21 am    Post subject: Reply with quote
Andyobro showed a photo of a red tacho dial cover on his 993.
Does anyone know where to get a coloured dial cover and how tricky are they to fit? Question
Golf R
RS6 Avant - Sold
944 Turbo - Sold
944 S - Sold
924 Lux - Sold
Endoman
PostPosted: Sat Jul 27, 2019 8:27 pm    Post subject: Reply with quote
Sending oil temp sensor back to Rose Passion it was reading 79C at 24 ambient. OPC one cheaper and accurate. Bit annoyed because it should have been genuine Porsche part. Thanks to Ian at Bolton OPC.
pierrebear
PostPosted: Mon Jul 29, 2019 9:56 am    Post subject: Reply with quote
Think he went to Carbone for that.
andyobro
PostPosted: Mon Jul 29, 2019 12:16 pm    Post subject: Reply with quote
Yes Carbone. Not an easy fit, the aluminium trim ring needs to be levered open, there is a video on you tube showing how, you need to take you time and lever many times to work the ring. Removing the needle is fine with the right tool, I used a plastic trim removal tool shape like a fork. The screws need the right size screwdriver and positive hand movement.
I tried to contact Julian at Reap Design, that would have been my first choice, but could not get a response.
993 Carrera
www.instagram.com/993andy
Endoman
PostPosted: Sat Aug 03, 2019 2:07 pm    Post subject: Reply with quote
I was contemplating fitting an override switch to cooling fan then spotted this on Rennlist:- https://rennlist.com/forums/993-forum/1155041-993-oil-cooler-fan-modification.html
Ordered, a simple and elegant solution when you are stuck in traffic
kingroon
PostPosted: Mon Aug 05, 2019 8:21 am    Post subject: Reply with quote
Removed the OEM Parcel Shelf and Quarters and installed the remainder Perlon Carpet, although, I'm not entirely sure I prefer it..!
What I'd rally like, is some lightweight panels covered in the perlon that have more of the shape/curves of the OEM panels.. If I can't find any, I think I might go about trying to make my own..
Hasta Luego..
KingRoon
 Filesize:  307.05 KB
 Viewed:  1014 Time(s)
 Filesize:  158.93 KB
Tombri
PostPosted: Mon Aug 05, 2019 10:33 am    Post subject: Reply with quote
Thanks Andyobro,
Carbone would only sell me a full set of red dials - and not cheap, so thought I would stick with my black dials. Sad
Golf R
RS6 Avant - Sold
944 Turbo - Sold
944 S - Sold
924 Lux - Sold
kingroon
PostPosted: Mon Aug 05, 2019 10:59 am    Post subject: Reply with quote
Tombri wrote:
..not cheap..
May I ask how much..?
Hasta Luego..
KingRoon
Endoman
PostPosted: Wed Aug 07, 2019 3:25 pm    Post subject: Reply with quote
Following a spate of car break-ins a Faraday Box, although they didn't get in the 993 several more modern cars were opened. I have Tore's T-lock perhaps they couldn't read it.
Endoman
PostPosted: Thu Aug 08, 2019 9:30 pm    Post subject: Reply with quote
Fitted and checked the oil cooler fan mod. Thermostat opens @ 83 c theoritically just before the 3 line on the guage and the fan now kicks in slow speed just above the line stabilising the temp around the 3rd line around 90C. So it works as intended. Normally running free it would hold that temp but in traffic on a hot day it was getting up 120C and the fan was not coming on altough the thermister checked out ok I replaced it and the resistor.
It's easy to check the stat opening by popping the r/h headlight pod and feeling the pipes to the cooler carefully. That's when to check the oil level.
Cameltoe & Heel
PostPosted: Fri Aug 09, 2019 6:45 am    Post subject: Reply with quote
John, glad to hear the fan is working as it should, I have the t-OBD reader that has a function to check all high/low speed operation of each fan and HVAC motor operation, you're welcome to give it a go.
As far a reading the oil level in the car, I've had no success at all, simply cannot see where the oil is on the dipstick. nooo
Trev
Endoman
PostPosted: Fri Aug 09, 2019 8:43 am    Post subject: Reply with quote
Thanks Trev, already got Tore's kit with Scantool software and the UDT999 which has a few more functions. Don't know if either will reset the airbag light as I removed them both ages ago.
I agree getting a reading on the dip stick with clean oil is nigh impossible and the guage is unreliable.
With my oil now slightly darker I can see it. I've set the level 1/2 way on the dip stick and the guage is only just off the red. At 3,oclock it blew oil into the inlet tract with oil temp around the 4th line.
https://www.pelicanparts.com/techarticles/pcar_com/oil_cooler_troubleshoot2.htm
kingroon
PostPosted: Fri Aug 09, 2019 9:05 am    Post subject: Reply with quote
Flat Palm on the OS Rear Wing, in front of the Rear Wheel.. Feel that for Oil Temp.. Hot hot, needs more Oil..
Dip Stick isn't the best way.. Go for a Drive, warm the Engine up nicely, then find a [preferably] unpopulated place to pull up. Rev the Engine so that the Oil Temp Needle sits at the 9 O'Clock position; the Oil Level needle needs to be at the 3 O'Clock position at Idle..
Hasta Luego..
KingRoon
2019-08-09 10_03_44-Porsche 993 RestoRod Journey (@roonsstreetrod) • Instagram photos and videos.jpg
 Filesize:  16.12 KB
 Viewed:  731 Time(s)
Goto page Previous  1, 2, 3 ... 131, 132, 133, 134  Next
Page 132 of 134
