997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
Mike_993
PostPosted: Sat Jul 06, 2019 10:29 am    Post subject: Reply with quote
Mike_993 wrote:
Caliper refurb, brake and suspension updates all to be fitted this week.
1995 993 C2. Iris Blue.
Albionmuz
PostPosted: Sat Jul 06, 2019 11:40 am    Post subject: Reply with quote
A second hand oem window switch to replace the non oem wobbly one the car came to me with, a much better condition gear stick, carpet retainer to replace the cracked one and two door bins without cracks.
993 Targa manual
Alfa GTV Twinspark
Citroen Deux Chevaux
Alfa 159 Sportwagon
Porsche 968 Cab Tip
Lexus IS 200
PostPosted: Sat Jul 06, 2019 11:41 am    Post subject: Reply with quote
Darthmjh wrote:
By chance I stumbled across a post in this forum about the MPL clutch slave cylinder. The clutch pedal has always been very firm on the car, so I thought I would give it a try. So today I had one fitted. WOW what a difference it makes, the clutch pedal is so much lighter. I would definitely recommend this mod. I now no longer need to do leg presses down the gym Smile
A big thanks to those that have fitted one and posted on this forum.
Its one of those most that you just think “why wouldn’t you” Thumb
kingroon
PostPosted: Sun Jul 07, 2019 6:40 am    Post subject: Reply with quote
Found myself on the Shelf..
Hasta Luego..
KingRoon
1994 993 Carrera Coupe
 Filesize:  268.03 KB
 Viewed:  956 Time(s)
Endoman
PostPosted: Sat Jul 13, 2019 9:45 am    Post subject: Reply with quote
PC based Diagnose Tool UDT999
I already have Tore's Scantool adapter which has been very useful especially locating a faulty ABS sensor but the scantool software is a bit limited.
Good reports from the States on it's functions.
http://jenniskens.livedsl.nl/diag/diag.htm
I had a leak from the filler pipe to tank union and topped the oil up after refitting, too much !
In our clogged local roads, on a very hot day I eventually got free and floored it, horror when clouds of oil smoke poured out of the back. Guage was up to half way but oil had shot into the intake and was pouring out of the filter housing. Gently drove home and pulled the filter box and MAF gave it all a good clean and new filter.
So bit of a puzzle I was so careful not to overfill.
Started fine and pulled the r/h headlight pod to check themostat was opening at correct temp, fans working at both speeds. Dip stick reads 1/2 way up twisty, guage in red which is what I had before but I had lost a litre oil oil. I can only suspect some kind of surge in the tank when I floored it. No damage done only a new pair of underpants.
pierrebear
PostPosted: Sun Jul 14, 2019 7:29 am    Post subject: Reply with quote
I will probably do another thread for this but...Christian Sanger has been working his magic on the car. Suspension completely overhauled - Koni FSD dampers with M033 springs, new or reconditioned parts for everything else pretty much as it was apparently all “very original”...not ideal after 24 years and 100k miles. Now running at RS ride height +10mm, albeit still on Cup 2s.
Sorted out some significant oil leaks by replacing both lower and upper gaskets and covers. Tore’s HID kit (amazing difference) and Christian’s own solution for the main beam (like driving with daylight...actually feel bad flashing people).
And the icing on the cake is...factory Carrera RS aerokit (M002 option) fitted.
1995 Carrera 2 coupe manual, midnight blue
EX 997.1 Carrera 4S coupe manual, basalt black
EX 2003 Mercedes SL500, green black (dark blue!)
ColinC
PostPosted: Sun Jul 14, 2019 8:20 am    Post subject: Reply with quote
Nice spec - same as mine with the exception of the body kit. I did try 18’s and swapped back to the Cup 2 although genuine RS Speedlines would look awesome.....go on then what is the solution for the main beam - enquiring minds and all that.
Ashamed to say haven’t even needed to buy fuel this year.....I’ll get my coat!
Tobesetc
PostPosted: Sun Jul 14, 2019 9:30 am    Post subject: Reply with quote
Whilst the centre console is at the trimmers having the new Southbound leather applied, took the opportunity of buying a new, leather clad, handbrake lever. That completes the upgrade of touch point trim and the leather interior from the back up to the steering wheel.
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
kingroon
PostPosted: Mon Jul 15, 2019 7:51 am    Post subject: Reply with quote
Really wanna see a photo of this.. Cool
Hasta Luego..
KingRoon
kingroon
PostPosted: Mon Jul 15, 2019 7:54 am    Post subject: Reply with quote
Picked up the final Piece to my RS Puzzle on Saturday from a nice chap in the M25 Cobham Services..!
Was a great excuse to get the 968 Sport out for a blat too, Sunny Morning Traffic notwithstanding.. Rolling Eyes
Hasta Luego..
KingRoon
 Filesize:  189.04 KB
 Viewed:  647 Time(s)
Endoman
PostPosted: Mon Jul 15, 2019 9:25 pm    Post subject: Reply with quote
Do get at least one new gas strut for the RS lid I found my originals just too weak to hold it up. I fitted one uprated strut both would have knocked my teeth out. Bit of electrical fiddling needed as well, although there is no provision for engine illumination the interior and frunk lights come on when you have the engine cover open leave it for too long and you have a flat battery. I push the catch down same with frunk if the covers are open for a while. You will get a red light on the instruments unless you remove the tailgate module. Gert's site mentions it (or used to)
kingroon
PostPosted: Tue Jul 16, 2019 9:03 am    Post subject: Reply with quote
I bought and fitted new regular ones already in preparation.. Cool
Thanks for the Electrical tip, I have a few unused Cables/Wires/Boxes that need attending to.. A job in itself..!
Hasta Luego..
KingRoon
andyobro
PostPosted: Tue Jul 16, 2019 1:09 pm    Post subject: Reply with quote
Red tacho dial face finally installed 😁
993 Carrera
www.instagram.com/993andy
 Filesize:  1.91 MB
 Viewed:  474 Time(s)
kingroon
PostPosted: Tue Jul 16, 2019 1:20 pm    Post subject: Reply with quote
Saw that on your Insta.. Cool
Hasta Luego..
KingRoon
Cameltoe & Heel
PostPosted: Tue Jul 16, 2019 4:24 pm    Post subject: Reply with quote
Would love to hear more about the 968 sport please, I really like them.
Trev
kingroon
PostPosted: Wed Jul 17, 2019 11:12 am    Post subject: Reply with quote
Trev
I think I'm gunna write a Blog Post about it.. Cool
Hasta Luego..
KingRoon
Endoman
PostPosted: Wed Jul 17, 2019 10:19 pm    Post subject: Reply with quote
Apart from the engine and bodywork I have converted most of my S2 to 968 CS spec. Mainly because I couldn't afford one. Brilliant car handles a dream and so versatile. Has to be the ultimate 993 companion sounds like an itch that needs to be scratched Trev.
AndyS
PostPosted: Thu Jul 18, 2019 12:00 pm    Post subject: Reply with quote
Annual service - gave Unit 11 in Warrington a go this year. All good thumbsup
Andy
kingroon
PostPosted: Thu Jul 18, 2019 1:29 pm    Post subject: Reply with quote
Endoman wrote:
Apart from the engine and bodywork I have converted most of my S2 to 968 CS spec...
I want to do this.. Did the 944 come in Polar Silver..?
My 968 Sport is going to be for sale imminently, so Trev, if that Itch is getting Itchier [!] and you wanna come have a look.. Wink
Hasta Luego..
KingRoon
 Filesize:  36.24 KB
 Viewed:  197 Time(s)
Endoman
PostPosted: Thu Jul 18, 2019 3:59 pm    Post subject: Colour Chart Reply with quote
Hope your German is good:-
https://www.porsche.com/usa/accessoriesandservices/classic/genuinepartsandhistoricaldocuments/historicaldocuments/colourcharts944/
Goto page Previous  1, 2, 3 ... , 130, 131, 132  Next
Page 131 of 132
