997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
Shedman
PostPosted: Mon Jun 17, 2019 8:46 pm    Post subject: Reply with quote
I fixed the spoiler wall.
1997 993 Targa Manual
 Filesize:  1.6 MB
 Viewed:  1428 Time(s)
kingroon
PostPosted: Tue Jun 18, 2019 7:43 am    Post subject: Re: Rear end refurb C4 Reply with quote
waiteu2 wrote:
Dansk loud mufflers
Fabspeed X-Cat 200 cell
Stainless nuts bolts all round
Rust prevention/Dinitrol,Bilt Hamber to chassis legs
Rennline engine mounts
KW V3 suspension
New rear heatshields/Bumper supports
Chassis leg supports replaced.
Rear glass out/Scuttle repaired
Powder coated heater pipe/Bumper supports/Muffler brackets etc.,
Need a rear on photo..!
Hasta Luego..
KingRoon
1994 993 Carrera Coupe
waiteu2
PostPosted: Tue Jun 18, 2019 7:13 pm    Post subject: Re: Rear end refurb C4 Reply with quote
kingroon wrote:
waiteu2 wrote:
Dansk loud mufflers
KW V3 suspension
Difficult as its parked about 3 feet from the garage cupboards!
A little further on tonight and hopefully get it completed over the weekend.
Starting to think about the next additions/upgrades or leave it as is now.We'll see.
 Filesize:  84.83 KB
 Viewed:  1295 Time(s)
 Filesize:  940.69 KB
waiteu2
PostPosted: Tue Jun 18, 2019 7:15 pm    Post subject: Rear end refurb C4 Reply with quote
And another
 Filesize:  867.95 KB
Endoman
PostPosted: Tue Jun 18, 2019 7:53 pm    Post subject: Reply with quote
Very nice, same sytem I ran but found the Dansk cans a bit droney so swapped to Fabspeed cans. the RSRs were best sound imho raspy and not too loud.
waiteu2
PostPosted: Tue Jun 18, 2019 8:16 pm    Post subject: Reply with quote
Started it briefly earler and sounded lovely but wont get the chance to go on the road with it until the weekend at the earliest to try it out.
Its difficult with exhausts because all the youtube clips in the world wont tell you if its a sound your looking for or will be happy with.
It'll be an expensive mistake if im not happy with this set up!
RSR's do seem the go to cans but if i go down that route it will be a new set as i think my standard ones are past their best corrosion wise.
Thanks Endoman and i'll hpefully report back over the weekend.
kingroon
PostPosted: Wed Jun 19, 2019 8:25 am    Post subject: Re: Rear end refurb C4 Reply with quote
Hubba hubba.. Cool
Hasta Luego..
KingRoon
 Filesize:  867.95 KB
 Viewed:  1202 Time(s)
Kat1
PostPosted: Wed Jun 19, 2019 10:53 am    Post subject: Reply with quote
Last years mileage was significantly down on the previous 16 years but I still have needed to flash the cash and dust off the Snap on tools this year.
In line with my policy of preventative maintenance, I changed the distributor drive belt and bearings with a kit* from Diddi at 228 euros.
Almost as soon as this work was completed I fitted a new indicator unit which was bought from Type 911 at £255 plus carriage and Vat and fitted.
* I still have a spare set of disturber parts for sale at 170 euros
andyobro
PostPosted: Wed Jun 19, 2019 11:56 am    Post subject: Re: Rear end refurb C4 Reply with quote
kingroon wrote:
Hubba hubba.. Cool
Agreed . yum yum yum
993 Carrera
www.instagram.com/993andy
Albionmuz
PostPosted: Wed Jun 19, 2019 8:12 pm    Post subject: Reply with quote
New distributor belts, rotors and caps. Thanks to the guys at Precision. This was the second attempt to get the distributor out as back in November, during a full service, it proved impossible to remove. They greased it up and advised I try again when the car came out of winter storage. Even so it took quite a while to get it out. Anyone else had this problem? First change in 22 years I believe! They built these cars properly!
Airbag bracket replaced, no more tooting horn on braking
Chuffed
993 Targa manual
Alfa GTV Twinspark
Citroen Deux Chevaux
Alfa 159 Sportwagon
Porsche 968 Cab Tip
Lexus IS 200
Tobesetc
PostPosted: Thu Jun 20, 2019 7:31 am    Post subject: Reply with quote
Ordered new leather cover for centre console from Southbound so it'll match the rest of the interior (door cards, entire rear all now leather but also, importantly, cup holder, handbrake surround and gear gaiter are all new leather, so it stuck out!). Can't wait for it to arrive and be installed.
Now...where do I get a leather dash for less than the price of a small car? Question
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
Kat1
PostPosted: Thu Jun 20, 2019 10:03 am    Post subject: Reply with quote
Yes, I recently removed the distributor on my 993 C4, but would not describe it as impossible.
I started off by removing the securing stud and with the help of plenty of spray and light tapping with a hammer I eventually managed to get the distributor to rotate but was unable to extract it.
The fan assembly and casing were then removed to get better access.
A light chain (25 mm links and shackles) was secured around the distributor with a loop over the top.
Using a pry bar I could then put some pressure on the distributor assembly in the" in line" direction.
More spray, light taping, additional leverage with bags of patience and care and it finally came out.
Be careful and gently - if you can find a replacement I suspect you will then fully appreciate the expression "Porsche Tax".
Cameltoe & Heel
PostPosted: Thu Jun 20, 2019 1:53 pm    Post subject: Reply with quote
Chuffed
Did mine recently too, the rubber rings were shot compared to the new ones. Also glad I bought the whole frame with rubbers already installed, didn't fancy gluing them in myself.
Trev
AndyS
PostPosted: Sun Jun 23, 2019 9:34 am    Post subject: Reply with quote
These:
I've had a fixed wing for 3 years now, and won't be re-fitting the rear wiper as I changed the screen too - so can get rid of those switches and move the sunroof switch to the console.
Now just to fit them.....
Andy
 Filesize:  188.47 KB
 Viewed:  830 Time(s)
Endoman
PostPosted: Sun Jun 23, 2019 1:18 pm    Post subject: Reply with quote
Never seen that handbrake surround before. Do you have the part no? Or is it a diy? Handy place for a rain light switch.
I have a rain light on the 944 produces some interesting reactions from tail-gaters.
AndyS
PostPosted: Sun Jun 23, 2019 3:09 pm    Post subject: Reply with quote
Here you go - it's for the Targa, they must have another switch?
What I didn't realise until I got it all striped out today is that I also needed a switch surround frustrated
From the PET
Parking brake cover
Illustration 809-15 part 9 (993.552.539.00)
£56 at OPC with PCGB discount
Retaining Frame
Illustration 933-05 part 11A (911.613.615.01)
I'll order this one tomorrow.
Andy
 Filesize:  401.05 KB
 Viewed:  766 Time(s)
Albionmuz
PostPosted: Sun Jun 23, 2019 7:43 pm    Post subject: Reply with quote
From the PET
Parking brake cover
Retaining Frame
It’s for the spoiler switch. I guess there wasn’t enough space available with having the roof switch and roof curtain switch alongside the rear wiper switch on the lower dash
993 Targa manual
Alfa GTV Twinspark
Alfa 159 Sportwagon
Porsche 968 Cab Tip
Lexus IS 200
andyobro
PostPosted: Mon Jun 24, 2019 12:07 pm    Post subject: Reply with quote
From the PET
Parking brake cover
Retaining Frame
I have done the same on mine, but cut the hole in my original non targa hand brake surround to fit the switch/surround. The RS compartment is so useful for wallet and keys etc, my fav mod and fairly inexpensive when modding the handbrake surround. thumbsup
The parts I bought
https://www.instagram.com/p/Bsc2C3jFXC1/?utm_source=ig_web_button_share_sheet
The compartment and the switch installed
https://www.instagram.com/p/Bsyf0LYF606/?utm_source=ig_web_button_share_sheet
993 Carrera
AndyS
PostPosted: Mon Jun 24, 2019 5:58 pm    Post subject: Reply with quote
The parts I bought
Cheers Andy Thumb
I've ordered the switch surround today - so will get back on this at the weekend....
Tell - how did you go about extending the wires for the switch?
I'll be moving the sunroof switch and it's 4 pretty thick wires, so probably need some slick connectors with the new RS cubby taking all the free space.
Also - it looks like you've kept the spoiler switch.....are you sunroof-less?
Andy
Barryn
PostPosted: Mon Jun 24, 2019 6:40 pm    Post subject: A few jobs done. Reply with quote
Time flies, this was actually late February. Embarassed
Dieter Refurbished my distributor to his very high standards, it was a job on the to do list ever since I got the car.
Before and after and the new bearings.
Then last week I had the steering rack off and rebuilt by WPS (Western Power Steering) in Bristol. Great service, and now the steering feels better than ever.
Working my way through the car steadily. Thumb
1999 986 Boxster
1997 993 CarreraS
 Filesize:  1.44 MB
 Viewed:  447 Time(s)
 Filesize:  1.47 MB
 Viewed:  447 Time(s)
 Filesize:  1.39 MB
 Viewed:  447 Time(s)
Goto page Previous  1, 2, 3 ... 128, 129, 130, 131, 132  Next
Page 129 of 132
