997 : 2004- 76
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
Les Richards
PostPosted: Tue May 14, 2019 6:52 pm    Post subject: Reply with quote
MOT with no advisories, a new starter motor (ouch!) and yearly maintenance check.
Oh, and tax at the end of the month.
Now where is that Lottery ticket...?
Les Richards
993
Polar Silver
5152 MU
kingroon
PostPosted: Wed May 15, 2019 7:43 am    Post subject: Reply with quote
A coupla parts turned up last night, which means that this Weekend is a Workshop Weekend..
Biggest Job is the Rear Wiper Delete; I have the blanking swtich too for the console, so will be removed from Cabin to Glass..
Hasta Luego..
KingRoon
1994 993 Carrera Coupe
2019-05-15 08_40_51-Porsche 993 Rear Wiper Delete Plug - Anodized Black - Black Satin _ eBay.jpg
 Filesize:  25.29 KB
 Viewed:  527 Time(s)
kingroon
PostPosted: Wed May 15, 2019 7:59 am    Post subject: Reply with quote
..and also, and somewhat more importantly I think, a new Masthead arrived.. So I am removing the Cerakote one I installed in place of a 996. part and reinstating a 993. part..
Hasta Luego..
KingRoon
 Filesize:  85.2 KB
 Viewed:  515 Time(s)
 Filesize:  29.42 KB
 Viewed:  515 Time(s)
gunner
PostPosted: Wed May 15, 2019 8:26 am    Post subject: Reply with quote
Where did you source the blanking switch from? It's the one thing I haven't done regarding my wiper delete.
993 C2 Tip Aventura
kingroon
PostPosted: Wed May 15, 2019 8:27 am    Post subject: Reply with quote
https://www.design911.co.uk/fu/prod13456/Blanking-Switch-Porsche-993/
Cool
Hasta Luego..
KingRoon
Nij4
PostPosted: Wed May 15, 2019 9:03 pm    Post subject: Reply with quote
just had a major service...service centre said I need to replace bumper stops, front and rear discs corroded, two rear tyres, rear track control arms and nsf calliper plates lifting....oh and prob could do with a geo.
I need to win the lotto too!
993 C4 cab
gunner
PostPosted: Thu May 16, 2019 7:31 am    Post subject: Reply with quote
Cool
Ordered
993 C2 Tip Aventura
kingroon
PostPosted: Thu May 16, 2019 7:47 am    Post subject: Reply with quote
Ouch, not a nice list to have to listen to, but at least you'll feel a transformation once you get it back from all the work..! thumbsup
Hasta Luego..
KingRoon
mashby
PostPosted: Thu May 16, 2019 12:49 pm    Post subject: Reply with quote
Just had some paintwork done. Front and rear PU's, n/s rear wing, n/s door and both front wings. Collected it on Tuesday thumbsup
1994 993 C2
1974 MGB GTV8 3.5
1980 MGB Roadster 1800 stage 3
 Filesize:  237.77 KB
 Viewed:  356 Time(s)
 Filesize:  214 KB
 Viewed:  356 Time(s)
 Filesize:  220.24 KB
 Viewed:  356 Time(s)
 Filesize:  248.69 KB
 Viewed:  356 Time(s)
 Filesize:  235.94 KB
 Viewed:  356 Time(s)
Endoman
PostPosted: Thu May 16, 2019 1:47 pm    Post subject: Reply with quote
A bit more bling from 9apart
 Filesize:  17.85 KB
 Viewed:  334 Time(s)
 Filesize:  42.04 KB
 Viewed:  334 Time(s)
kingroon
PostPosted: Thu May 16, 2019 2:04 pm    Post subject: Reply with quote
Going to do something similar for my Oil Cap.. Am thinking either Polishing or using a Yellow Enamel Paint..
New unit looks part though..!
Hasta Luego..
KingRoon
Croydon
PostPosted: Thu May 16, 2019 2:25 pm    Post subject: Reply with quote
ah you can help, all about timing.
http://911uk.com/viewtopic.php?t=133956
Darthmjh
PostPosted: Thu May 16, 2019 9:20 pm    Post subject: Reply with quote
Just returned from spending 2 days at Center Gravity where Pete worked his magic on my 993. It now handles fantastic. I opted for 12mm above RS height. The journey is always so much nicer on the way back, shame it was mostly motorway.
Mike
993 C4
1973 911T
Mike_993
PostPosted: Thu May 16, 2019 11:53 pm    Post subject: Reply with quote
Looking forward to having this little lot fitted. Took the advice and C4 mounts.
1995 993 C2. Iris Blue.
 Filesize:  757.94 KB
 Viewed:  226 Time(s)
Mike_993
PostPosted: Fri May 17, 2019 12:22 am    Post subject: Reply with quote
In addition insurance with Classic line and an mot which was passed.
Cameltoe & Heel
PostPosted: Fri May 17, 2019 7:34 am    Post subject: Reply with quote
2 days wow, that's some serious set-up time, I bet it transformed the car, nice work.
Trev
Cameltoe & Heel
PostPosted: Fri May 17, 2019 7:39 am    Post subject: Reply with quote
Great call on the C4 mounts, those new wishbones should tighten things up at the front too, you going to have a geo?.
Trev
Mike_993
PostPosted: Fri May 17, 2019 7:47 am    Post subject: Reply with quote
Yes definitely going to have a geo done. Possibly at OPC. I have also ordered rear lower V wishbones. After much deliberation have gone down the Danske route. It has had a new rear lower arm koni fsd, mo33 springs overhaul last year so hopefully this latest lot will really improve things.
Mike_993
PostPosted: Fri May 17, 2019 7:51 am    Post subject: Reply with quote
And!! New discs and pads also to be fitted with calipers going off to be refurbed and sprayed.
Big dilemma of keep em black and original? or be daring with red or yellow!!!
kingroon
PostPosted: Fri May 17, 2019 7:57 am    Post subject: Reply with quote
Had mine done at the beginning of the year.. Cool
Hasta Luego..
KingRoon
 Filesize:  570.85 KB
 Viewed:  160 Time(s)
 Filesize:  759 KB
 Viewed:  160 Time(s)
 Filesize:  689.06 KB
 Viewed:  168 Time(s)
 Filesize:  541.43 KB
 Viewed:  168 Time(s)
Goto page Previous  1, 2, 3 ... 125, 126, 127, 128  Next
Page 126 of 128
