991 : 2011- 19
997 : 2004- 76
996 : 1997-2005 35
993 : 1993-1998 7
Cayenne : 2003- 4
Darthmjh
PostPosted: Fri Apr 12, 2019 10:04 pm    Post subject: Reply with quote
Had the car serviced
Nij4
PostPosted: Sat Apr 13, 2019 9:09 am    Post subject: Reply with quote
kingroon wrote:
Not sure I’ll mount this to the 993 as a permanent feature, but had some [stressfully patient!] fun with an exact Arctic Silver colour match wrap on the Rear Centre Section..!
Very RUF I thought.. Cool
What do you think..?
Can’t wait to see on the car....I have a spare lens kit for my car may try this too on a black car
993 C4 cab
Allan E
PostPosted: Sat Apr 13, 2019 10:14 am    Post subject: Reply with quote
Allan E wrote:
awaiting delivery of front bump stops and dust covers from the “Homeland”.
Replaced old knackered front bump stops and dust covers, not quite as easy as described in previous posts, assistance needed to guide the top of the shock absorber strut back through the upper bearing whilst positioning the hub and brake assembly. I did use spring compressors incidentally.
Attached picture of one of the destroyed front bump stops...58k miles.
1995 Carrera in Guards Red
1987 Mercedes 300SL (R107)
 Filesize:  1.56 MB
 Viewed:  1636 Time(s)
Normski298
PostPosted: Sun Apr 14, 2019 10:07 am    Post subject: Reply with quote
Just had a front end respray. Also decided to freshen up the front with some RS ducts. Collected yesterday.
993 C4 Schwarz Perl
_____________________
1999 Mercedes C43 AMG
Previously:
993 C2 manual Guards Red
993 Targa Midnight Blue
 Filesize:  26.36 KB
 Viewed:  1573 Time(s)
Barryn
PostPosted: Tue Apr 16, 2019 9:27 pm    Post subject: Brake refresh. Reply with quote
A good clean up, my second full set.
Trying Pagid pads this time.
1999 986 Boxster
1997 993 CarreraS
 Filesize:  1.87 MB
 Viewed:  1465 Time(s)
tyinsky
1997 Porsche 993 Carrera 2S
PostPosted: Wed Apr 17, 2019 5:07 am    Post subject: Reply with quote
What was wrong with the previous set, or did they just wear out?
decgraham
PostPosted: Wed Apr 17, 2019 7:02 am    Post subject: Re: Brake refresh. Reply with quote
I wouldn't go Pagid personally, I tried them years ago on the fronts and they squealed like a pig. Made the same mistake when I changed my 4 discs a couple of years back for Brembo. Discs were fine but the Brembo pads on the front also squealed like a pig. I thought Brembo pads were the same as Textar but not the case. After 3 months I swapped them for Textar and all was fine. I will never fit anything but Textar now.
ATB Smile
kingroon
PostPosted: Wed Apr 17, 2019 7:40 am    Post subject: Re: Brake refresh. Reply with quote
decgraham wrote:
..the Brembo pads on the front also squealed like a pig..
Same here, never heard such bad Brake Squeal.. Then I changed mine to Pagid and all was good..! But, that doesn't seem to make sense given your experience..
Perhaps it's a Pad / Disk combo issue..?
 Filesize:  71.33 KB
 Viewed:  1390 Time(s)
 Filesize:  70.98 KB
decgraham
PostPosted: Wed Apr 17, 2019 8:45 am    Post subject: Re: Brake refresh. Reply with quote
Could be, my Indy in Q8 told me to always go with Textar on the front and I did that. It was only when I changed the discs that I thought I was doing the right thing to buy matching discs and pads. frustrated Over time I've thrown away 3 sets of perfectly good front pads, que sera sera.
Must say your hubs look in great shape very clean Thumb
ATB
 Filesize:  102.95 KB
 Viewed:  1371 Time(s)
 Filesize:  134.37 KB
Cameltoe & Heel
PostPosted: Wed Apr 17, 2019 9:25 am    Post subject: Reply with quote
Dec as a quick question, do you know what the imprinted triangle is on the N/S inner wing, I have the same and apparently all Porsches have the same, either a square or triangle.
Trev
decgraham
PostPosted: Wed Apr 17, 2019 10:44 am    Post subject: Reply with quote
Trev
Sorry Trev not a clue, didn't even know that there were two types, triangle and square until you brought it up.
ATB Smile
Barryn
PostPosted: Wed Apr 17, 2019 11:49 am    Post subject: Reply with quote
Nothing wrong, just worn down.
Nice even wear front and rear.
Brembo competition pads up front and Textar at the rear.
1999 986 Boxster
1997 993 CarreraS
Barryn
PostPosted: Wed Apr 17, 2019 11:59 am    Post subject: Re: Brake refresh. Reply with quote
ATB Smile
Textar do have a good reputation and normally I would go that route, going on track this year so testing the Pagid RS42 competition pads.
Initial impressions are good, no squealing at all (yet) 🙂
1999 986 Boxster
1997 993 CarreraS
decgraham
PostPosted: Wed Apr 17, 2019 12:31 pm    Post subject: Re: Brake refresh. Reply with quote
ATB Smile
All sounds good, didn't know you were fitting competition pads. Have fun on the track Thumb
ATB Smile
Tycho
1995 Porsche 993 Carrera 2
PostPosted: Sat Apr 20, 2019 12:05 pm    Post subject: Reply with quote
Not so much a purchase, more an adoption - new rear seat passenger, if he fits in.
 Filesize:  209.75 KB
 Viewed:  1209 Time(s)
nickjonesn4
PostPosted: Tue Apr 23, 2019 12:15 am    Post subject: Reply with quote
Beautiful dog. How old, what sex etc?
1996 Carrera S Vesuvius Metallic
2016 Golf R
2005 AMG E55K Wagon
kingroon
PostPosted: Mon Apr 29, 2019 9:41 am    Post subject: Reply with quote
Sunday was reserved for a Fog Lamp & Lens Refurb..
NSF has a Bullet through it, both were chipped, scratched and UV damaged / yellowed.. Reckon they mighta been the original glass..!
Hasta Luego..
KingRoon
1994 993 Carrera Coupe
Fogs Out..
 Filesize:  696.62 KB
 Viewed:  966 Time(s)
Cracked, Chipped and Faded lenses need replacing..
 Filesize:  647.57 KB
 Viewed:  966 Time(s)
92M Polar Silver, to match the Bodywork..
 Filesize:  500.21 KB
 Viewed:  966 Time(s)
 Filesize:  756.19 KB
 Viewed:  966 Time(s)
Quite a dramatic change..!
 Filesize:  660.58 KB
 Viewed:  966 Time(s)
Tycho
PostPosted: Mon Apr 29, 2019 1:18 pm    Post subject: Reply with quote
He is a GSD so the right nationality! Fifteen months old but acts more like 15 weeks - interesting with a dog weighing over 40 kg. He is our 5th rescue Shepherd and the first male but he is going for the “op” on Friday – might slow him down a little. Next task will be to fit him into the back of the 993.
Darthmjh
PostPosted: Sun May 12, 2019 7:34 pm    Post subject: Reply with quote
After the Service a few things were highlighted, that needed doing, so over the past few weeks I have:
Fixed an interior light (connection issue)
Replaced the washer bottle cap
Fitted a new headlamp washer pump (Genuine Porsche Pump was £313. Replaced it with a £14 one and a fitting kit from Type911)
Replaced the knackered F&R brake discs with Brembo and installed new Textar pads all round.
Whilst at it, replaced the warn rear handbrake shoes
Changed the front and rear wiper blades
Fitted Michelin PS4 tyres all round
I also changed the front ducts to the original spots that Andy (madalaa) had kept, as I fancied a change. They have gone a bit yellow so will be spraying them in the not so distant future.
And finally as the weather was nice, I clay barred the car and waxed it. Unfortunately highlights the stone chips. Sad
When 911UK offered a free 111 point check at OPC Brooklands last year they said the front A arms were warn and was also picked up an MOT. So on Wednesday have the car booked in for Center Gravity to work there magic. They did my 73 911 and transformed it.
Mike
993 C4
1973 911T
Mike_993
PostPosted: Sun May 12, 2019 9:58 pm    Post subject: Reply with quote
Confirmed order for C4 mounts, new front wishbones and steering track rods. Goal is to return to as close to original ride quality as possible. Already have new front ball joints and new discs and pads all round ready to fitted.
Just need someone to fit unless I have a go myself.
1995 993 C2. Iris Blue.
Goto page Previous  1, 2, 3 ... 124, 125, 126 ... 132, 133, 134  Next
Page 125 of 134
