996 : 1997-2005 48
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayman : 2005- 17
Cayenne : 2003- 7
Macan : 2014- 3
912-914-924-928-944-968 3
Darthmjh
PostPosted: Fri Sep 29, 2017 9:31 pm    Post subject: Reply with quote
Bought 2 lower rocker gaskets and bolts, which I shall be attempting to fit tomorrow. Hopefully I won't be swearing to much Very Happy
Endoman
PostPosted: Sat Sep 30, 2017 8:03 pm    Post subject: Reply with quote
Oh you will Very Happy
nickjonesn4
PostPosted: Sun Oct 01, 2017 10:55 am    Post subject: Reply with quote
An leather airbag three spoke 996 steering wheel
18" Work Mesiter rims
Oh dear not even collected the car yet Question
Tobesetc
PostPosted: Sun Oct 01, 2017 2:56 pm    Post subject: Reply with quote
Finally had my new ducted fog lights installed. Sylwrster @ Enigma created a clever side light and fog light combined in the single aperture using LEDs. Now the fog light isn't a dreadful weak yellow colour!
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
 Filesize:  105.71 KB
 Viewed:  1849 Time(s)
Jam911
PostPosted: Sun Oct 01, 2017 4:08 pm    Post subject: Reply with quote
Nice
Current '07 997 C4S
Ex '99 2.5 Boxster
nickjonesn4
PostPosted: Sun Oct 01, 2017 4:15 pm    Post subject: Reply with quote
That looks great
Darthmjh
PostPosted: Sun Oct 01, 2017 7:08 pm    Post subject: Reply with quote
I did and I gave up. Decided that I will leave it to the experts!
wilsonny
PostPosted: Mon Oct 02, 2017 7:35 pm    Post subject: Reply with quote
One of those hand painted Porsche crests in black and grey, along with new retaining nuts and rubber seal. Also a mobil 1 sticker for the engine blower. All essentials of course Smile
1996 C2 manual
Allan E
PostPosted: Sat Oct 07, 2017 9:59 am    Post subject: What did you buy Reply with quote
I have had the car for approx. 4 months now and gradually you notice little odds and sods missing. Obviously as time has went by bits of trim etc have been removed and possibly broke, or simply not refitted at all.
Things I have replaced, plastic nut covers under spoiler, plastic turn screws above rear centre reflector, under tray hanging bracket and fastener (more than £45) ultra sonic alarm microphone bracket, replaced velcro fittings in boot with H/D press studs (looks so much tidier) various cup washers located in the cabin, either scratched or cracked and the festoon bulb in glovebox (unusual size-31 mm) I am yet to check whether as a previous post mentioned the bulb if any, in the ashtray. I am presently awaiting for a rubber seal plug and a speed nut fastener located under the bonnet.
I also replaced the clear indicators with as new amber ones, correct for the car, a bargain of eBay (£15.50 the seller must have been gutted).
1995 Carrera in Guards Red
1987 Mercedes 300SL (R107)
AndyS
PostPosted: Sat Oct 07, 2017 11:14 am    Post subject: Re: What did you buy Reply with quote
Good work Allen - it never stops, but that's part of the fun in owning these cars, and you don't have to do it all at once either, if at all Thumb
I'm particularly interested in the H/D press stud thing you mentioned for the front boot carpet. I've not heard of this one - can you elaborate?
Andy
A Class AMG & Golf TDi for the daily
Allan E
PostPosted: Sat Oct 07, 2017 1:50 pm    Post subject: Boot liner Reply with quote
Andy, hope this explains the technique and what you need. The boot liner looks loose and whenever you put anything in the front the velcro would just come away and the liner sag. (OK many I hear say, who puts anything in the front?…I do)
The boot liner has three stud fasteners already, holding the back in so firstly loosen those and remove the liner, then remove the 4 hex head self tappers either side that hold the small metal plate with the velcro discs. You then need to punch out the soft rivet and scrap the discs. Replace these discs with the appropriate half of the stud fastener. The kits come with all the necessary pieces, I got a set of 10 (15mm) H/D from eBay for £4. You can obtain kits from high street retail outlets, they will have the necessary punches etc I already had the punches so only needed the fasteners. Refit the plates with the self tapper hex head screws.
Before you refit the liner and mark off where the new fasteners will match up, remove the stitching of the hook part of the velcro, it makes attaching the outer part of the fastener much easier, then rivet the outer part through the liner one by one (I found it easier doing one side at a time, rather than all at once) and that is it. The finished job looks so much better and now the liner stays in place always.
I also took on board the tip for inserting a piece of wire through the bead on the pocket, no sagging there now.
 Filesize:  21.38 KB
 Viewed:  1501 Time(s)
 Filesize:  976.85 KB
 Viewed:  1504 Time(s)
 Filesize:  1.17 MB
 Filesize:  832.04 KB
 Filesize:  1.59 MB
AndyS
PostPosted: Sat Oct 07, 2017 2:54 pm    Post subject: Reply with quote
^^^^^^^^ Nice job Allan - Thanks Thumb
Andy
PostPosted: Sat Oct 07, 2017 3:03 pm    Post subject: Reply with quote
That's one stiff boot pocket there chum Thumb
Tobesetc
PostPosted: Tue Oct 10, 2017 1:38 pm    Post subject: Reply with quote
MOT passed first time, rattly heat shield refitted... and original '94 sale brochure for "new" C4...
 Filesize:  152.62 KB
 Viewed:  1355 Time(s)
cableguy
PostPosted: Thu Oct 12, 2017 12:45 pm    Post subject: Reply with quote
Gearbox Oil Change, Oil Line repair (pin hole on a return line) and Outer CV Gaiter replaced using new Gaiter Kit.
C.
Pork!
Nij4
PostPosted: Thu Oct 12, 2017 5:44 pm    Post subject: Reply with quote
Small service and brake fluid change. No issues except windscreen washer jets have stopped working, although headlamp washers fine... Dont know
And rear tyres at the limit. Think I will buy full set and finally get a geo done.
993 C4 cab
ch3tman
1995 Porsche 993 Carrera 4
PostPosted: Thu Oct 12, 2017 9:09 pm    Post subject: Reply with quote
Presumably the interior switches operate as per normal? If so, that's a really smart solution.
MattyR
PostPosted: Thu Oct 12, 2017 10:01 pm    Post subject: Reply with quote
Relay? Had this happen on my headlight washer jets.
1994 Aventura Grün C2 993
Darthmjh
PostPosted: Thu Oct 12, 2017 10:14 pm    Post subject: Reply with quote
Funny you should mention headlight jets. My ones also did not work. Checked the fuse and all okay. Checked the relay and thought it was faulty.
I looked at Design911 and they wanted (hope you are sitting down) £192.54 for a replacement Surprised
http://www.design911.co.uk/fu/prod11078/Headlight-Washer-Relay-Porsche-993-99361811100/
You can get replacements from Bosch that fit different Porsche models. Part Number 1397328015.
Picked up a second hand on for a tenner on eBay. Around £30 new. Fitted this evening and now works like a dream.
Endoman
PostPosted: Sat Oct 14, 2017 7:49 pm    Post subject: Because I'm not as flexible as I used to be. Reply with quote
Invaluable little gadget I found in a local garden center, every geriatric 911 owner should have one.
 Filesize:  74.09 KB
 Viewed:  996 Time(s)
Goto page Previous  1, 2, 3 ... 103, 104, 105 ... 114, 115, 116  Next
Page 104 of 116
