997 : 2004- 79
996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 10
Cayenne : 2003- 4
912-914-924-928-944-968 3
AndyS
PostPosted: Sat Jul 01, 2017 3:42 pm    Post subject: Reply with quote
Chris993C2 wrote:
A pair of shiny new carry handles Grin
...probably the best mod I ever did to mine Thumb
Andy
A Class AMG & Golf TDi for the daily
Leosayer
1996 Porsche 993 Carrera 2
PostPosted: Sat Jul 01, 2017 6:59 pm    Post subject: Reply with quote
MPS4 all round
1996 C2 Coupe, Polar Silver, Manual
Millomboy
1997 Porsche 993 Targa
PostPosted: Wed Jul 05, 2017 8:14 pm    Post subject: Reply with quote
Two new tyres for the rear of the car.
Ocean blue targa.
The only true freedom, is freedom from the heart's desires. And the only true happiness, this way lies.
Cameltoe & Heel
PostPosted: Thu Jul 06, 2017 8:18 am    Post subject: Reply with quote
PS2's??
Millomboy
PostPosted: Thu Jul 06, 2017 11:05 am    Post subject: Reply with quote
Cameltoe & Heel wrote:
PS2's??
I put Bridgestone Potenza on. I was looking at Michelin, but the front tyres (Bridgestone Potenza) still had plenty of tread and I don't like mismatched tyres on a car and couldn't justify throwing away the fronts. I have been happy with the Bridgestones, but may well change next time.
Ocean blue targa.
cableguy
PostPosted: Thu Jul 06, 2017 12:32 pm    Post subject: Reply with quote
PS2's??
I run the same in 18's bought last year and very impressed with the grip in dry conditions. Thumb
C.
Pork!
badlands
PostPosted: Thu Jul 06, 2017 2:46 pm    Post subject: Reply with quote
ARP wrote:
Pedros Ice Wax to hopefully ease the creaking windscreen.
Do let us know if this is a success
current: 993 carrera coupe, manual, iris blue, bilstein pss10
ex 964 c4
ex 993 carrera cab
Mike_993
PostPosted: Thu Jul 06, 2017 3:59 pm    Post subject: Reply with quote
One set of Koni FSD Shocks and MO33 springs (springs not purchased) to fit shortly.
Any other spring recommendations would be really appreciated.
Aware that this may be just the tip of the iceberg so to speak on suspension improvements so mechanic to assess wear in all parts before stripping it down.
Looking forward to seeing the difference.
1995 993 C2. Iris Blue.
 Filesize:  84.6 KB
 Viewed:  1908 Time(s)
harryk
PostPosted: Thu Jul 06, 2017 4:33 pm    Post subject: Reply with quote
Getting the dreaded chassis legs sorted by Sam at Precision/Impact. Wasn't the worst example of damage thankfully.
Re creaking screen, I've had Sam look at mine and he diagnosed the outer seal as being the culprit: might be a good place to start if anyone has issues.
1995 993 C4 Coupe. Schwartz/Flamenco Red soft nappa leather. Exclusive leather everything, Exclusive extended centre console, MO33 suspension set up by CG, Chipwizards 287bhp remap, FDM Goldenrod & SSK, Techart exhaust, Techart pedal set, Tequipment dials, Tequipment handbrake & gearlever.
bodmin
PostPosted: Thu Jul 06, 2017 6:23 pm    Post subject: Reply with quote
Andy - can you give me some details of this mod?
I assume this enhances the exhaust note?
Any info available about this.
AndyS
PostPosted: Thu Jul 06, 2017 8:14 pm    Post subject: Reply with quote
Sure - it's a simple bypass pipe welded between the in & out on the Cat' (I think that's the technical description). There are loads of threads for this on here - and a resident expert (search Kimbo, Hollamby Ninja etc.)
The degree of sound benefit is in direct relation to the size of by-pass pipe used. I think I went with a 1.5" but others have gone as far as 2" I believe.
Exhaust note? - extra 'Burble' at low revs, nice 'Crackle' on the over-run.
I'm sure Kimbo posted a sound bite of one of his 993's with this mod?
Andy
ColinC
PostPosted: Fri Jul 07, 2017 5:34 pm    Post subject: Reply with quote
Twin distributor rebuild by Indy - 112,000 miles and Indy reckoned it was on the original belt........replaced all of the bearings at the same time so should be good for another 23 years!
Not sure if this item is in Porsche maintence schedule but needed a new dizzy cap and rotor arm and as highlighted by Wozzy mechanic also reckoned I was lucky........
ARP
PostPosted: Sun Jul 09, 2017 8:00 pm    Post subject: Reply with quote
Pedro Ice Wax has largely cured the front windscreen creaking, not totally cured but loads better. Just squeezed the bottle in under the rubber seal and ran it around using the nozzle to open the gap.
Just done a second treatment and will see if that helps quieten the last little bit.
997.1 C4S
993 C2
Previous: 1995 968 Sport, M508
AndyS
PostPosted: Sun Jul 09, 2017 8:10 pm    Post subject: Reply with quote
Eventually fitted the new Ambers' to the front to match the side repeaters and rears:
Also - now using PostImages since Photo Bucket screwed us all nooo
Before:
After:
Andy
ch3tman
1995 Porsche 993 Carrera 4
PostPosted: Sun Jul 09, 2017 9:29 pm    Post subject: Reply with quote
Ambers look great on your car! Good move Cool .
p.s. Imgur is good for ad-hoc image posting, Flickr good if you want to organise and create albums. Both provide forum friendly links, easy to copy/paste here.
madalaa
2009 Porsche Boxster (987)
PostPosted: Sun Jul 09, 2017 10:13 pm    Post subject: Reply with quote
I thought Infrasilver (Chris) said Imgur didn't work here ........ Question
Dont know
bodmin
PostPosted: Sun Jul 09, 2017 11:00 pm    Post subject: Reply with quote
[quote="AndyS
[/quote]
+1 for postimages.org
I tried imgur on another site and couldn't get it to work.
ch3tman
PostPosted: Sun Jul 09, 2017 11:20 pm    Post subject: Reply with quote
Dont know
Just to demonstrate it does work, I posted over 15 images here, via Imgur, without any issues: http://911uk.com/viewtopic.php?p=1195811#1195811.
There's plenty of alternatives, including PostImage Smile.
madalaa
PostPosted: Mon Jul 10, 2017 6:40 am    Post subject: Reply with quote
Maybe 911uk towers has re-jigged the security settings to now accept Imgur ........ Question
Dont know
badlands
PostPosted: Mon Jul 10, 2017 9:32 am    Post subject: Reply with quote
great, have ordered some Thumb
ex 964 c4
ex 993 carrera cab
Goto page Previous  1, 2, 3 ... 99, 100, 101 ... 111, 112, 113  Next
Page 100 of 113
