997 : 2004- 66
996 : 1997-2005 43
993 : 1993-1998 9
964 : 1989-1993 7
Carrera SC : 1977-1983 0
Classic : 1950-1965 1
Boxster : 1997- 15
Cayenne : 2003- 9
912-914-924-928-944-968 4
Mike:)
PostPosted: Sun May 07, 2017 9:08 pm    Post subject: Reply with quote
Great list, they are addictive once you start and inevitably the while you are at it factor creeps in!
Out of interest as I also have these items on my list how far are you going with the suspension and what have you gone for audio wise? I have a box sat at he ready with a set of FSD Konis however am discovering this can be just the tip of the iceberg suspension wise.!!
Mike
1995 993 C2. Iris Blue.
Jet Jock
PostPosted: Sun May 07, 2017 9:52 pm    Post subject: Reply with quote
You won't be disappointed with Chris and Peter at Center of Gravity.
993 C2, RSR's, Cargraphic 100 Cell Cat, Turbo Twist Hollows, Brembo Big Reds Turbo Brakes, Big Ovals, Wayne Schofield Remap, KW Supersport set up by Chris Franklin, RS engine and transmission mounts, Fabspeed induction kit, HID conversion...
rstaichi
PostPosted: Mon May 08, 2017 1:17 pm    Post subject: Reply with quote
Yes feeling excited Laughing .. i always buzz off stuff like this !! As for set up Mike i'm not quite sure yet until its been checked over, i don't even know if the car is still on stock suspenstion or not it will all become aparent when the car is in the hands of Chris and Pete and i will be taking the advice from them regarding parts etc.
I was steady doing $#@ mph on the M1 last week and things did not feel right at high speed lots of body movement and rolling around nooo my old 964 felt solid and safe at 145mph i wouldnt dream of pushing the 993 that far at the moment and these cars are quite capable of doing just that easily.
rstaichi
PostPosted: Mon May 08, 2017 6:32 pm    Post subject: Reply with quote
Noticed you have had some work done by Chris jet jock Thumb
Jet Jock
PostPosted: Mon May 08, 2017 7:47 pm    Post subject: Reply with quote
Another happy customer Rstaichi Thumb
gunner
PostPosted: Wed May 10, 2017 12:11 pm    Post subject: Reply with quote
993 C2 Tip Aventura
Tobesetc
PostPosted: Fri May 12, 2017 7:07 am    Post subject: Reply with quote
Clutch pedal lever (to stop sticking at top).
Lower cam cover (to stop oil dripping onto exhaust & smoking)
Both rear suspension arms (camber) as bushes were kaput.
4-wheel alignment.
Full annual service.
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
decgraham
PostPosted: Fri May 12, 2017 7:58 am    Post subject: Reply with quote
Having done the lower camshaft covers, the cam chain cover gaskets and seals I still have a small leak, about a tear drop appears after a run Mad I am determined to get the car drip free. So I now have new upper camshaft cover gaskets and bolts. I will also change the cam chain oil bridge O ring seals along with the cam chain tensioner gaskets, hopefully this will do the job. My only regret is I should have done it when I did the other work on the upper camshaft covers and the cam chain covers as everything was off wack Moral of the story if you are doing this type of job do all the possible leak points, its only a extra £60 or so in parts.
ATB Smile
 Filesize:  74.3 KB
 Viewed:  2277 Time(s)
 Filesize:  262.97 KB
Cameltoe & Heel
PostPosted: Fri May 12, 2017 8:08 am    Post subject: Reply with quote
HI Dec, yes I have the upper camshaft seals but not the bridge seals so think I'll get myself sorted.
Like you say nothing worse than having to go back, hope your seals fix the annoying drip.
Trev
decgraham
PostPosted: Fri May 12, 2017 1:38 pm    Post subject: Reply with quote
Trev
Trev,
Don't forget to replace the 2 cam adjuster cover gaskets too, (my first pic, item 12 on page 25 in the PET) they are about £10 each if you shop around.
ATB Smile
Tycho
1995 Porsche 993 Carrera 2
PostPosted: Sun May 14, 2017 11:45 am    Post subject: Reply with quote
No purchases, just looks like my 993 is going to get a mid-year holiday.
 Filesize:  180.49 KB
 Viewed:  2156 Time(s)
kerb scraper
1997 Porsche 993 Carrera 4
PostPosted: Sun May 14, 2017 1:03 pm    Post subject: Reply with quote
You have my sympathy with the sling thing. Had to wear one last year for months! So frustrating. I was told it would be illegal to drive at all - not even the automatic gaily driver.
1997 C4 Cabriolet, Arctic Silver, black interior, 18" hollow spokes, Bilstein PSS10s, RSRs, 200 cell cats, Mobil 1 sticker, LED to interior. Bergville t-lights.
Cameltoe & Heel
PostPosted: Mon May 15, 2017 1:04 pm    Post subject: Reply with quote
Gearbox casing, or at least one part of the casing (bell-housing end) which was damaged beyond repair.
This took months and months to source, they are no longer made by Porsche, buy many calls and frustrations later here we have it:
NottsRS
PostPosted: Mon May 15, 2017 2:57 pm    Post subject: Reply with quote
^^ a work of art ^^ Cool
993 RS | Riviera Blue | Lightweight
964 RS | GP White | Lightweight
993 4S | Viola Metallic | Factory Non Sunroof | [Jan'09-Mar'16]
stichill99
PostPosted: Tue May 16, 2017 8:27 pm    Post subject: BBS LM Reply with quote
Eventually got the bbs fitted with PS4's and fitted to the car. I think the next project will have to be lowering the ride height.
 Filesize:  179.92 KB
 Viewed:  1925 Time(s)
New Wheels
 Filesize:  179.92 KB
stichill99
PostPosted: Tue May 16, 2017 8:28 pm    Post subject: bbs lm Reply with quote
New Wheels
bbs lm
 Filesize:  192.4 KB
cableguy
PostPosted: Tue May 16, 2017 9:24 pm    Post subject: Reply with quote
LM's are a quality wheel.
I've never seen a 993 sit so high! Are you running standard suspension or have you renewed anything recently?
C.
Pork!
gunner
PostPosted: Wed May 17, 2017 6:57 am    Post subject: Reply with quote
OSF looks a lot lower than NSF so it's probably on uneven ground?
993 C2 Tip Aventura
Paul Ricard
PostPosted: Wed May 17, 2017 9:32 am    Post subject: Re: bbs lm Reply with quote
stichill99 wrote:
New Wheels
BBS LM's
Black bolts or just my eye's
wilsonny
PostPosted: Wed May 17, 2017 11:18 am    Post subject: Reply with quote
been the same for me since Oct last year, just got back in the 993 in the last month - it was the bike that did for me...staying on four wheels in future.
1996 C2 manual
Goto page Previous  1, 2, 3 ... 96, 97, 98 ... 108, 109, 110  Next
Page 97 of 110
