997 : 2004- 79
996 : 1997-2005 40
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 9
Cayenne : 2003- 4
912-914-924-928-944-968 3
Cameltoe & Heel
PostPosted: Thu Apr 27, 2017 4:33 pm    Post subject: Reply with quote
Lips for the Turbo rear bumper?, then yes they will to look right at least.
Trev
Mike_993
PostPosted: Thu Apr 27, 2017 7:20 pm    Post subject: Reply with quote
New Windscreen ordered today and associated seals. Booked into body shop next week to remove, refit and sort out any deterioration under and around screen.
Also ordered are door handle gaskets. scuttle to wing seal, rear window outer seal and antenna booster.
Mike
1995 993 C2. Iris Blue.
Cameltoe & Heel
PostPosted: Fri Apr 28, 2017 7:04 am    Post subject: Reply with quote
Mike, I'm replacing my screen shortly, where did you order yours and how much?.
Trev
Mike_993
PostPosted: Fri Apr 28, 2017 7:37 am    Post subject: Reply with quote
Trev
The screen I have ordered from Porsche Portsmouth. Approx £730.00 plus the inner and outer seals which are about another £100.00 for the pair.
I am just trying to work out how the rear view mirror comes off, it appears that the screen comes bonded with a mounting point so hopefully that is a simple swap over job.
I chose to do the antenna cable and booster because my radio reception is rubbish and it seems a logical point to make sure it is all connected correctly at the time the screen is out.
Mike
 Filesize:  70.12 KB
 Viewed:  2177 Time(s)
ColinC
PostPosted: Fri Apr 28, 2017 8:45 am    Post subject: Reply with quote
The screens can be tricky - a few of us have had bad experience with bodged fitting and although I have personally have successfully installed screens in other cars wouldn't attempt the 993 - the squeak could drive you mad!
The front screen surround is also a favourite point for corrosion - do a search on here and google Glassman for the pro's and cons.
Hope all goes well with the install.......
Mike_993
PostPosted: Fri Apr 28, 2017 9:44 am    Post subject: Reply with quote
Hi and thanks for the observations.
I am inevitably keen to get this right first time and have read many articles before taking the plunge. I have also read about a teflon strip being installed for the squeak being either a good thing or bad with some articles saying it traps water. I am using genuine parts and the bodyshop and their glass guy have done a 993 recently. The OPC confirmed they supplied the glass and parts to the body shop / customer so I am pretty happy I am on the right track and in safe hands.
I am keen to be around when they remove the screen to see what if any work is required below also to grab some photos.
Fingers as always crossed.
KR
Mike
ColinC
PostPosted: Fri Apr 28, 2017 10:19 am    Post subject: Reply with quote
Ah......thought you were trying a DIY install initially.
I'm sure it will be awesome.......
Vaaru
PostPosted: Sun Apr 30, 2017 3:51 pm    Post subject: Reply with quote
....a 2007 997 Tubo to keep it company in the garage.
AndyS
PostPosted: Sun Apr 30, 2017 7:11 pm    Post subject: Reply with quote
Fitted that engine tidy strip thingamyjig thing at long last. I needed a little help from someone with small fingers though - but makes a world of difference Thumb
On another note - I now want to tidy up the full engine bay a bit more now. Anyone got any tips for what to use for the plastics and alloy varioram thing?
Andy
A Class AMG & Golf TDi for the daily
ch3tman
1995 Porsche 993 Carrera 4
PostPosted: Sun Apr 30, 2017 8:08 pm    Post subject: Reply with quote
Some good info in this post:
http://911uk.com/viewtopic.php?p=1303452#1303452
carkid
1996 Porsche 993 Carrera 2
PostPosted: Mon May 01, 2017 7:45 am    Post subject: Reply with quote
I recently had my windscreen removed by Paul aka 'Glassman'.
The body shop tidied the scuttle up and then Paul returned to reinstall the windscreen- it's rock solid now.
While they had the car I also had the chassis legs looked at.
The rust was not as bad on the car as I expected but I'm still glad the jobs are done with.......
Ex:
2015 991GTS
1990 964 C2
1982 911SC
AndyS
PostPosted: Mon May 01, 2017 8:40 am    Post subject: Reply with quote
Good job there Thumb
I recently went through the same pain - but I now have that warm fuzzy feeling when I look at the car and know that it's all sorted Cloud 9
Andy
carkid
PostPosted: Mon May 01, 2017 9:38 am    Post subject: Reply with quote
Yes- you do feel better knowing it's sorted........
After rain I could run my finger along the bottom corner of windscreen outer seal and water would push out where it had gathered- it's all completely water tight now.....
Ex:
2015 991GTS
1990 964 C2
1982 911SC
gunner
PostPosted: Wed May 03, 2017 10:06 pm    Post subject: Reply with quote
New plate and a Blaupunkt Helsinki (old RTM 127, not the current model).
993 C2 Tip Aventura
Mike_993
PostPosted: Wed May 03, 2017 10:18 pm    Post subject: Reply with quote
Delivered my 993 to the bodyshop for the new screen. From first look by removing the front and rear seals is that all looks good and sound so fingers crossed nothing drastic going on.
Whilst there we discussed other options one of which is adding on the third brake light roof spoiler. I wondered if any views as to whether best left standard for a 95 993 or having that done whilst there and they are armed with a spray gun!! Also any views on keeping indicators red or amber. Maybe not the right forum location but just thought I would ask for any opinions?
Mike
PostPosted: Thu May 04, 2017 11:29 am    Post subject: Reply with quote
^^^^ Do it Thumb It makes all the difference, plus it's a safety feature given the fact the brake lights are so low on these cars. I fitted the high level brake light/spoiler to my 964 and so far I've not been tarred and feathered what
AndyS
PostPosted: Thu May 04, 2017 11:39 am    Post subject: Reply with quote
Mike
+ 1 on the 3rd brake light - and get the ToreB upgrade Thumb
I would say go for the rear ambers - and I will even take the 'reds' off your hands Whistling
In fact - do you wanna' swap?
Andy
Mike_993
PostPosted: Thu May 04, 2017 12:10 pm    Post subject: Reply with quote
Hi
Thanks for recommendations. I will do the third brake light as I agree the visibility isn't that good with the lights low down plus it does look good and finishes off the roof line. Its a good opportunity to do it but not cheap. Not sure what the ToreB upgrade is but will check it out.
Re the lights having re read my note I should have said go from Ambers to Red as that is what I have at the moment so thank you Andy for the offer to swap but will stick with the Ambers for the time being. Once I have been to Beaulieu with all the 993's I may have my mind changed!! Again!!
Mike
RobIpswichUK
1994 Porsche 993 Carrera 2
PostPosted: Thu May 04, 2017 9:37 pm    Post subject: Reply with quote
24k Mile service incl. plugs and new plug leads fitted. MOT etc.
Just waiting to collect tomorrow and then get on with fitting various other goodies I have bought over the last year, but haven't got round to fitting.
Rob
'94 C2 Iris Blue (+ White Stripes!)
Cup 2's, Big Ovals, FSD's/Eibach, OMP Strut Brace, 200 Cell Powerspeed Cats, 1.75" Hollamby Exhaust bypass, Carnewal FPB.
Mercedes SL (R230 lowered + wheels)
Range Rover Sport (L320 chipped)
Mercedes E Class (W211 chipped)
TT Roadster (standard - wife’s daily!)
rstaichi
PostPosted: Sun May 07, 2017 8:55 pm    Post subject: Reply with quote
Booked in with Chris Franklin Center Gravity Tamwoth for suspenstion re-fresh, can't wait for this to happen soon enough.. new headlights fitted last week ..3 weeks ago full major service with Porformance Porsche Brighouse..2 weeks ago full Audio upgrade.. new personal reg plate .. new fog lights to fit with front spliter.. i really need pulling back in now as the funds are running low and the mrs is getting suspicious Grin
Goto page Previous  1, 2, 3 ... 95, 96, 97 ... 111, 112, 113  Next
Page 96 of 113
