997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 17
deutschland-dobson
PostPosted: Sun Feb 02, 2014 3:55 pm    Post subject: 964 Project - A few weekend jobs... Reply with quote
Been busy over the last couple of weekends, sorting winter jobs on the 964.
First up was to sort the hunting idle that has appeared while the car has been off the road during winter. The idle drops have resulted in second gear stalls and a flat power curve.
First up easy job is to replace the DME fuse. Next up was to clean the ISV.
Following the link below I stripped, cleaned and re-fitted. Engine sound deadening pad was tidied up too.
Idle was better but not great. Next drop was to pull it back out and strip, clean and re-fit the AFM!
Rennlist link:
http://forums.rennlist.com/rennforums/964-1989-1994-911/197997-how-to-clean-isv-and-air-flow-meter.html
It's still not perfect, but I'll give it a good run before trying some other ideas, including ordering the famous Steve Wong Chip. More power and a steady idle!
Next up was to replace my knackered engine mounts. The price of new 964 mounts from porsche is a fortune, so I considered RS mounts, 964 mounts or aftermarket.
WEVO mounts from the USA won in the end. I went with wevo "blacks" to keep vibration to a minimum:
Under tray had to be removed first for access. This was cleaned before being refitted.
Old mounts were knackered!
Wevos installed:
Next job was to fit new bonnet shockers / struts, as these failed last weekend and the bonnet twatted me on the head! Right pain in the arse this job! Far too fiddly to get access to fit them. Didn't take any photos, as too busy swearing at the car. The rennlist how-to's don't even help much for this job!
Few more small jobs...
The black reR wipe bung I had fitted didn't look neat enough. I'm going to fit an RS rear screen when time / cash allows. In the mean-time I've tried a few universal clear ones. A one from Venom Motorsport was bought, then sent back. In the end an eBay item ordered. Here's it dry fitted, before I took the protective film off.
More jobs:
I've got a battery drain, so as a temporary fix I removed the bulbs from bonnet, glovebox and engine compartment.
I re-dyed my front seats at the end of last year. There was a couple of imperfections, so I smoothed them out with some 3000 grit paper.
Last job was a well deserved pie and beer!
Porsche 911 (964) C4 - Project RED - Outlaw4
Guards Red & Linen, Custom Leather, BBS LM Split-rims, H&R Coilovers, Cleaned Bodywork, 90s audio instal...
Chief
PostPosted: Sun Feb 02, 2014 5:08 pm    Post subject: Reply with quote
Chris, you've been busy. Sorry you twatted your noodle but I'm sure the pie, beer and carrot cake made it all better Grin
paul284pt
I thought it hit you on the head Grin
Nice going Chris!
Cheers,
Paul
1980 - 84 924 Turbo with mods. (ex Tony Dron - 12th at Le Mans 1980 with works 924 Carrera Turbo).
1984 - 89 911 SC (1982)
1989 - 93 911 Carrera Sport (1989)
2010 - 964 Carrera 2 (1990) Redtek 3.8RSR
2012 - 14 Porsche Cayenne (2012)
2015 - 17 Porsche Cayenne Diesel S (2015)
2017 - 18 Macan Turbo Performance Package (2017)
2018 - 991.2 Carrera 4 GTS (2018)
deutschland-dobson
PostPosted: Sun Feb 02, 2014 5:24 pm    Post subject: Reply with quote
Lol cheers lads Smile
Good work on the 993 rear windows / rubbers Chief. Not the easiest job in the world, but pleased I sorted mine as the tin worm was eating away:
http://911uk.com/viewtopic.php?t=88943&start=30
Chris
igaffz
PostPosted: Sun Feb 02, 2014 9:57 pm    Post subject: Reply with quote
Looking great Chris, keep up the good work!
Ian
Horizon blue, 964 carrera 2 tip, lowered on koni's, k&n, de-cat, cup pipe, leather trim and 18" 3 piece split rims.
Silver 928 S2, B reg, manual.
Guards red 944 lux, the new project!
Boxsey
Watkins Glen
1990 Porsche 964 Carrera 2
PostPosted: Mon Feb 03, 2014 10:23 am    Post subject: Reply with quote
Chris,
Regarding your hunting and stalling, an SW chip is not really the way to go to sort it out because you don't have a light weight flywheel. Seeing as you've done the usual cleaning things to try and sort it and they've not worked, I would try looking for leaks on the intake i.e. check all the hose clamps. Failing that get a Hammer adaption done on it.
Steve
Racing Yellow Cayman GT4
History of my now gone 964
deutschland-dobson
PostPosted: Mon Feb 03, 2014 3:33 pm    Post subject: Reply with quote
Boxsey wrote:
Chris,
Thanks Steve,
I'll start by tightening all the hose clamps and go from there. Not sure who has a hammer in the North East, but i'll ask...
The hunting was there before I took the car off the road for winter, but then developed the 2nd gear stalls over 2 months or so. Not sure why that would be (colder weather?). Hopefully the cleaning has improved the issue, the short run out that I had certainly showed that.
Chris
deutschland-dobson
PostPosted: Mon Feb 03, 2014 5:18 pm    Post subject: Reply with quote
Just checking through old threads and noticed that Zingers commented about checking whether the Lamda/O2 sensor on the Cat has been installed corectly.
Mine had a de-cat fitted not long ago and TBH the car has felt a bit flat ever since. Is this worth a check? Do they just screw into place?
Chris
Edit to say I'm going to buy a new Bosch lambda sensor and fit ASAP following this thread:
http://forums.rennlist.com/rennforums/964-1989-1994-911/208133-diy-oxygen-sensor-replacement.html
deutschland-dobson
PostPosted: Mon Feb 03, 2014 8:14 pm    Post subject: Reply with quote
Bargain, new full lambda kit for £58 delivered at Mister -Auto Thumb
Chris
PostPosted: Mon Feb 03, 2014 9:20 pm    Post subject: Reply with quote
Yep got mine from there Thumb
my experience with the knackered Lambda was after I had started to drive and the engine had warmed up. Engine was bucking and wouldn't hold an idle or do much else. IIRC lambda only takes effect with a warm engine.
It might/might not resolve the problem. Check also whether you have the idle adaptation applied as Boxsey mentions. Mine had it done a few years back by OPC with a previous owner as it wouldn't idle without stalling. I think the Tore-B device allows you to do this.
igaffz
PostPosted: Mon Feb 03, 2014 10:36 pm    Post subject: Reply with quote
Unlikely but it would cost nowt to check your dizzy caps and rotor arms mate, if you get a dodgy cap on a 964 it causes no end of problems, as I said its unlikely to be the cause of hunting and stalling but check just the same, lambder plug awkward to get to but a lambder change isn't to difficult, it's only a nightmare if your trying to get the lambder out of a standard cat after 20 years!
Ian
PostPosted: Mon Feb 03, 2014 10:41 pm    Post subject: Reply with quote
Ian
How very true PC
deutschland-dobson
PostPosted: Tue Feb 04, 2014 8:19 am    Post subject: Reply with quote
Ian
Cheers bud Smile
Luckily the lads at D&G removed the lambder from the standard cat and fitted it to the de-cat (with heat needed!), so it should be easy enough to screw back out now.
The Rennlist guide doesnt look too bad for getting access to the plug, so I'll give it a wirl.
One quick question (because im at the desk and not under the car) will I have to remove the rear undertray again or will removing the rear NS wheel gain access to the lambda?
Chris
Boxsey
Watkins Glen
PostPosted: Tue Feb 04, 2014 9:45 am    Post subject: Reply with quote
You don't have to remove the tray. Access to the lambda is ok with just the wheel off. Before you do anything, I would check that they have actually plugged the lambda back in. It's not unknown for people to forget this!
Steve
Mr Bacchus
PostPosted: Tue Feb 04, 2014 12:38 pm    Post subject: Reply with quote
Ian
How very true PC
My car was in for a service last week and the sensor was found to be loose Surprised
In vino veritas
MY89 964 C4 Guards Red, MY16 Evoque Coupe
deutschland-dobson
PostPosted: Tue Feb 04, 2014 3:00 pm    Post subject: Reply with quote
Boxsey, Mr B - good call!
When crawling about under the car last weekend it looked to be fitted, but i'll have a proper look Question
Chris
Boxsey
Watkins Glen
PostPosted: Tue Feb 04, 2014 4:47 pm    Post subject: Reply with quote
Chris
Chris, I mean check that it's plugged in, inside the engine bay. The lead goes from the cat, through a grommet in the engine tin and plugs in to the plug that is hidden underneath the rear blower. Once connected the plug then sits in a plastic clip - this is important as it keeps the cable away from the HT leads so that it doesn't pick up pulses from them.
Steve
deutschland-dobson
PostPosted: Tue Feb 04, 2014 9:01 pm    Post subject: Reply with quote
Cheers bud thumbsup
Porsche964FP
Donuts For Windows
PostPosted: Mon Feb 10, 2014 12:35 pm    Post subject: Reply with quote
Nice work mate!
deutschland-dobson
PostPosted: Mon Feb 10, 2014 1:14 pm    Post subject: Reply with quote
Stripped the blower out easy enough on Saturday and exposed the engine side of the lambda, only the find...they're shipped the wrong bleedin lambda sensor!
Argh!
Awaiting a response on how to exchange and when the new one will arrive.
In the mean-time I went mad and bought this...
Not the C4 lightweight mind Surprised Just the steering wheel puh
If the missus reads this I blame Tom, Ian and the chaps over on Rennlist for buying new wheels
Chris bye
Goto page 1, 2, 3 ... 22, 23, 24  Next
Page 1 of 24
