997 : 2004- 66
996 : 1997-2005 35
964 : 1989-1993 1
smj043
PostPosted: Sun Feb 02, 2014 1:35 pm    Post subject: wet door card driver side at the bottom Reply with quote
Door seems full of water only the drivers side. if i press the door carpet at the bottom water comes out like a squeezed sponge. I had the window regulator replaced on this side a few months back.
What with all the rain, might it have been damaged or could it be a bad install at the indy? the passenger side hasn't been touched and doesn't have the same water issue.
Should I take it back to the indy with this?
Question
huesey1974
1999 Porsche 996 Carrera 4
PostPosted: Sun Feb 02, 2014 1:39 pm    Post subject: Reply with quote
I would sounds like the membrane is damaged. Do a search and theres plenty about the membrane.
cheers
smj043
PostPosted: Sun Feb 02, 2014 2:23 pm    Post subject: Reply with quote
yes I searched the subject to find out what was wrong. My thoughts are though that when the window regulator was replaced, did they not get the membrane right when they put the door back together. On that repair receipt is says membrane o/s no sound pack for £40 or so.
otherwise how else could a newly worked on door suffer these symptoms?
How does a door membrane get damaged?
tbrown
Paul Ricard
2007 Porsche Cayman 987
PostPosted: Sun Feb 02, 2014 3:02 pm    Post subject: Reply with quote
Sounds as if they haven't got the sealing strip on the membrane to adhere properly.
You could check for yourself
http://www.911uk.com/viewtopic.php?t=50427]
but I would take it back to the garage and get them to do it again.
TB
Cayman S
Ex 996C4 Polar Silver 125k
Ex 996C2 Ocean Blue 143k
smj043
PostPosted: Sun Feb 02, 2014 3:21 pm    Post subject: Reply with quote
that's the advice I was hoping for. I read that thread and many others in my searching and very informative it is. I don't have the guts to start opening things up myself.
I'll have a talk with the indy on Monday see what they say.
thank you
tbrown
Paul Ricard
PostPosted: Sun Feb 02, 2014 3:40 pm    Post subject: Reply with quote
It's a really easy job if you can use a screwdriver but as you have
paid the Indy for the job get them to sort it out.
TB
Cayman S
smj043
PostPosted: Wed Feb 05, 2014 4:25 pm    Post subject: Reply with quote
The indy has told me they have sorted it out after a 2 hour visit today. They said the speaker connector in the door had damaged the membrane and asked firstly if i had done any work on the speakers which i have not. I guess it accidentally got damaged when they put it back together following the window regulator replacement.
They said they cleaned the drainage pipes as well just to be sure.
Nicely done Indy.
tbrown
Paul Ricard
PostPosted: Wed Feb 05, 2014 4:32 pm    Post subject: Reply with quote
TB
Cayman S
tbrown
Paul Ricard
PostPosted: Wed Feb 05, 2014 4:33 pm    Post subject: Reply with quote
TB
Cayman S
smj043
PostPosted: Sun Nov 10, 2019 1:39 pm    Post subject: 5 year later Reply with quote
Just finished the rear nearside drain tube making rear seat wet. sorted that - Car dry, no more condensation, then a few days later the wet door carpet has returned in the front driver side.
I've took the door card off, a small part fell out, brittle plastic clips have snapped. What is the part I wonder?
Found the leak. see pic. where should this water be going if it isn't leaking onto the door carpet? is there a drain hole i don't know about? removed the two plastic grommets under side of door nothing i can see to do there no water came out.
any advice welcomed. Confused
1999 C4 Cabrio Ocean Blue
 Filesize:  105.28 KB
 Viewed:  906 Time(s)
 Filesize:  76.41 KB
 Viewed:  906 Time(s)
 Filesize:  63.72 KB
 Viewed:  906 Time(s)
smj043
PostPosted: Sun Nov 10, 2019 2:13 pm    Post subject: sidler 1381 Reply with quote
doah, the part is from the ash tray to make it open slowly. fell off years ago and never bothered to replace it, must have put it in the door compartment. haha.
Number21
PostPosted: Sun Nov 10, 2019 2:46 pm    Post subject: Reply with quote
Mine had the wet door car thing going on as well after we had some rain here.
Regulator was replaced by previous owner, so suspected the membrane - and sure enough it has a small tear - but I've just used some sealant and waterproof tape to do a quick repair.
Membrane is only £65 though so no Biggie, just wanted to try stop the water for now. It seems to have worked but I doubt it is a permanent fix!
Number21
PostPosted: Sun Nov 10, 2019 3:41 pm    Post subject: Reply with quote
Also, the drain isn't where those grommets are - it's under the rubber seals. If you feel under the door you can feel the holes.
Mine are permanently wet, but clear, and there's usually a bit of water on the kick plate which suggests they are working.
If you've replaced the membrane and it all looks fine, take a look at the top of the door where the inner window seal sits near the mirror. You might see a trace that water has run down onto the interior side of the membrane. That could be the culprit even if your membrane is perfect. The seals are pretty expensive too - it is this part:
https://www.design911.co.uk/fu/prod126939/Door-Gasket-INNER-Porsche-986-Boxster---996/
Based on your picture though it looks more like it is actually the seal on the membrane isn't watertight.
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Mon Nov 11, 2019 8:48 am    Post subject: Reply with quote
I have done lots of these over various 996/997/986/987 that are in our garage at the moment.
My feeling is that if you are going to take the door card off for any reason it is wise to have a full set of replacement clips to secure it once whatever the task that required removal is completed.
The clips provide a significant clamping force to secure the membrane against the door and even if the membrane is intact it is likely that with a failed or failing clip you are likely to see a leak.
They are not expensive by any means from OPC but are also available from lots of sellers on ebay also.
GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
smj043
PostPosted: Mon Nov 11, 2019 5:25 pm    Post subject: Reply with quote
The door card has dried out indoors. It came off well all clips intact so hopefully will go back ok. I used a plastic spatula from my old rice cooker to remove the door card, worked remarkably well.
The seal is the fault for certain see pic. Will reseal with tiger seal when a dry day outside. Good to find the drains under the rubber seal as suggested Number21 thanks.
Many thanks to all on this great forum.
 Filesize:  96.85 KB
 Viewed:  754 Time(s)
 Filesize:  62.54 KB
 Viewed:  754 Time(s)
 Filesize:  243.58 KB
 Viewed:  754 Time(s)
Number21
PostPosted: Mon Nov 25, 2019 5:50 pm    Post subject: Reply with quote
Did you manage to get the door leak fixed?
My 'temporary' job seems to have fixed the issue. As some of the door clips were tired I'll take a proper look when I refit the door card properly with new clips. For £65 though I might just get a new membrane and fit that while I'm there Dont know
As a warning note though, clear the front bulkhead drains while you're fixing water-related issues. One of mine got blocked and the water builds up fast, apparently it can mess the brake booster and it definitely could soak into places you don't want it if left unchecked!
PostPosted: Mon Nov 25, 2019 8:23 pm    Post subject: Reply with quote
Door membrane is the usual leak but occasionally it's worth getting a small bit of Butil and wrapping it around the lower plastic door fixings as an added seal .
I was told recently that a heavy downpour and these can possibly leak .
997 onwards and these fixings have a rubber seal on them to stop just this from happening .
point to note .. when replacing a door membrane then make sure you get the door panel as clean as possible .. even a small amount of old glue can cause a leak when a new membrane is fitted ... at the bottom .. above this it's not so much of a problem .
I found that out many years ago !
