Ridiculous question pondered many times ...
kevinbuckley70
27 Dec 2013
64
Yes, I know, I know ...
Never owned a Porsche. Middle age crisis looming. £25k to waste. Ongoing costs not a problem.
Want a 911, not a cabriolet. Must look cool. Red. Younger than 2005.
Has to be reliable though.
What?
That will be one of these then. :D
That is certainly very pretty! I read on here that the 996 (and others) are considered to be 'real' Porches, whereas the Cayman is not. Why is that?
Don't get a 993.
It will always be worth more than you paid for it, and it won't have any ongoing costs or nasty surprises.
:nooo:
:welcome: Kevin,
The Cayman IS a real Porsche but it's not a 911.
If you want a Porsche, £25k will get you into some really nice Caymans or an early 997 with good provenance.
There are very few 2005 996s around and a Turbo of that age will be a bit over your £25k budget.
Happy Hunting. :bye:
Really dumb question I'm sure, but ...
So is a Cayman not a 911 simply because Porsche say so on the badge?
Or is there a fundamental difference between, say, a 996 and a Cayman?
More so than the difference between a 993 and a 996 for example.
Dumb :?: ................. probably
The Porsche 911 has always had its engine in the rear and can be 2wd or 4wd, Coupe or Cabriolet, normally aspirated or turbocharged. It also has rear seats. A 993 and a 996 are just different model incarnations of the 911.
The Cayman is a mid-engined, 2wd, 2-seater, normally aspirated Coupe also made by Porsche.
Asking why a Cayman isn't a 911 is like asking why a Ford Fiesta isn't a Ford Focus. In fact, it's worse as the Fiesta and Focus both have 4/5 seats, have their engines in the same place and, iirc, even share the same engines.
Thanks, that was helpful, as was your earlier response.
I am wondering if it might be better not to spend right up to the budget, and get something like a well maintained 2003 C4S which, it seems, I can do for around £17k - £21k, and keep something in the bank to fix issues.
I just sold my 2001, Mercedes E320, which I had for many years, and kept well serviced and maintained. However, latterly, it was falling to pieces and rusting faster than I was prepared to fix it, so it had to go (although that variant is well known for certain issues).
Whilst managing maintenance costs is not such a problem, I don't want a car which is forever in the shop, or lets me down. So a question is: is a 2003 996 likely to be much (or any) less reliable than an early 997?
Does the 996 have any well known body/corrosion issues which are going to become a major problem in a 10yr old car?
You should get into a very good 996 C4S for under £20k. An early 997 with similar miles would cost you a few £k more.
As with any car age hurts consumable components so like-for-like a car 2 or 3 years newer will probably cost a bit less to get up to scratch/maintain. The engines in the 996C4S and the early 997s are fundamentally the same but both have known potential issues. Neither will give any concerns re body rust - unless they've been pranged and repaired.
Take your time. Decide whether you'd prefer to spend a bit more for the newer 997 and then the exciting bit really starts. :thumb:
Would I have to compromise anything in terms of interior spec. if I went for a 997 which, at around £25k, seems to be the very bottom of the price range, compared with spending £20k on a 996?
When I bought the Merc., the first thing I did was give it to a specialist independent guy I know very well, who spent a week fixing or replacing everything which was dubious. I am inclined to think I should do the same thing with this purchase.
It very much depends on how much of your budget you want to spend and how much you prefer the 997 over the 996.
For £20k-£23k I'd want a late (early 04) 996, well spec'd and with lowish miles and with a dealer warranty.
These days £23k would get a 997 (04-06 according to spec and miles) from a dealer. There seem to be a lot of that age with sensible mileage (60k ish) around at the moment. Decide what options you particularly want and it shouldn't be difficult to narrow the field a bit.
With a full £25k you'd be really spoilt for choice. :thumb:
Unfortunately you'd then also start seeing the odd 'S' with the 3.8 engine and a whole new quandary would begin. :grin:
T8 said:
... 996, well spec'd and with lowish miles and with a dealer warranty.
I assume you mean independent dealers? If I went down the dealer route, would you recommend also getting a separate independent inspection? Or are dealers to be trusted?
Yes, sorry. You wouldn't find a £25k car at an OPC.
If buying from a non-Porsche dealer or one claiming to be a 'specialist' I'd definitely get a PPI and look very carefully at any restrictions in the wording of their warranty.
If buying from one of the specialists that advertise on here (& a few that don't) the car and the warranty should both be ok.
That's great, thanks. I think it's time to go look & drive!
I actually quite like the look of the 996. But I guess until you see/drive for real, it's hard to tell.
124,538
1,441,264
48,945
kclassicauto
