Porsche Cayenne Drive Shaft Clamping Bearing Support Mount The ONLY device that can be installed without removing the Drive Shaft from the vehicle
Best Selling Product
The innovative Drive Shaft Clamping Center Support (DSCCS) by is the only true Permanent fix to premature bearing support failures. This Patent-Pending device was developed by our team of technicians whom over the course of 2 years were able to create what is now the end-all solution to failing Bearing Supports.
The Clamping Center Support is the ONLY device that can be installed without removing the Drive Shaft from the vehicle or without requiring the disassembly of the Drive Shaft. Why is this so important?
http://www.design911.co.uk/fu/prod1...Repair-Porsche-Cayenne-955---957-Most-models/
