997 : 2004- 63
Cayman : 2005- 22
Macan : 2014- 7
Mr Bacchus
PostPosted: Wed Aug 21, 2013 7:45 pm    Post subject: Early 964 alarm control unit location Reply with quote
Can anyone provide a photo of the alarm control unit in situ? I believe it to be in the vicinity of the driver side luggage compartment on RHD cars, I am guessing it is somewhere near to the ABS control unit? I know what it looks like but I can't find it.
Steve
In vino veritas
MY89 964 C4 Guards Red, MY19 Evoque
PostPosted: Wed Aug 21, 2013 8:36 pm    Post subject: Reply with quote
I always thought these were under the drivers seat Dont know Weren't they retro fit?
The game's afoot. It's time to put a bit of (Colini) stick about......Why RUF when you can WUF
Chief
PostPosted: Wed Aug 21, 2013 9:12 pm    Post subject: Reply with quote
Mine were under the front scuttle (by the heater) passenger side. There are two boxes just kinda stuffed in there right by the gas strut for the bonnet.
Meant to say, there are different boxes for what alarm features are fitted.
Mr Bacchus
PostPosted: Wed Aug 21, 2013 9:21 pm    Post subject: Reply with quote
Later models, as I understand it from Adrian Streathers book and other sources, have the unit under the seat.
As Chief mentions it is supposed to be under the scuttle. My car has the ABS unit and another small black thing in that location (buried too deep to get eyes on it) but no sign of the alarm unit. I have reason to believe that mine has been removed but I would really like to see a pic of where it should be.
Steve
In vino veritas
Chief
PostPosted: Wed Aug 21, 2013 9:29 pm    Post subject: Reply with quote
I think I actually have a picture somewhere, I will have a look for it tomorrow for you.
Mr Bacchus
PostPosted: Wed Aug 21, 2013 9:31 pm    Post subject: Reply with quote
That would be much appreciated Sir.
Steve
In vino veritas
Chief
PostPosted: Thu Aug 22, 2013 7:33 am    Post subject: Reply with quote
As promised Mr B
Mr Bacchus
PostPosted: Thu Aug 22, 2013 3:54 pm    Post subject: Reply with quote
Thanks very much.
Most of my research suggested the unit would be at the drivers side and that is where I rummaged the most. I shall look again this evening but suspect that the unit has indeed been removed.
Steve
In vino veritas
Mr Bacchus
PostPosted: Thu Aug 22, 2013 7:32 pm    Post subject: Reply with quote
Found the connector for the alarm unit but it was well hidden, that confirms my suspicion that the unit has been removed and jumped.
Chief, what is the other black box in your pics please?
Steve
In vino veritas
Chief
PostPosted: Thu Aug 22, 2013 8:02 pm    Post subject: Reply with quote
Steve, not sure. I think it's for the pressure sensors on the back shelf (now removed) the alarm seems modular, as in you could have extra alarmy type bits fitted. This is all speculation to be honest. When it pulled all this out I had uncovered and removed four none OE alarms and the Porkie immobiliser Surprised
Tokyo Joe
1996 Porsche 993 Turbo
PostPosted: Sat Aug 24, 2013 11:35 pm    Post subject: Reply with quote
Thanks for posting those pics Chief, I too was under the impression the alarm was under a seat somewhere - since mine's a 90 model will take a look out the front to compare with the pics.
TJ
964 C2 1990
993 Turbo 1996 (X50)
Previous;
993 Carrera 1995
986 Boxster 2001
Chief
PostPosted: Sun Aug 25, 2013 4:59 pm    Post subject: Reply with quote
TJ, there is a control unit under the dash by the drivers right knee.
I think the boxes in my pictures are factory add on's or relay type units to kill the ignition and activate the interior sensors....
I am no expert, I just have many pictures Embarassed
Mr Bacchus
PostPosted: Sun Aug 25, 2013 7:07 pm    Post subject: Reply with quote
According to Adrian Streathers book the factory fit control unit is under the seat from 1991 and in the luggage compartment prior to that year.
Steve
In vino veritas
Stu964
PostPosted: Sun Oct 06, 2019 8:56 am    Post subject: Resurrecting this thread re alarm Reply with quote
Chief
On the pictures that you uploaded there is an extension box, the one with some red paint on. This is probably dealer fitted and allows connection to the ultrasonics and internal sensors. Question is, as this is just added in in series by the installer can you just remove it and plug the original 2 blocks back into the hella alarm control relay?
Stuart
