996 : 1997-2005 42
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
igaffz
PostPosted: Mon Nov 02, 2015 10:24 pm    Post subject: Reply with quote
On Saturday I got the engine and box back in, all plugs and pipes connected, drive shafts fitted and heat shields fitted. Also fitted the MAF and air filter assembly.
Sunday morning I fitted the anti roll bar, powerflex bushes and adjustable drop links.
After work tomorrow night I've Just the heat exchangers, exhaust, blower motor and new fluids and I'll hopefully be able to drive her home!
Ian
Horizon blue, 964 carrera 2 tip, lowered on koni's, k&n, de-cat, cup pipe, leather trim and 18" 3 piece split rims.
Silver 928 S2, B reg, manual.
Guards red 944 lux, the new project!
Johnd52
2011 Porsche Cayman 987
PostPosted: Mon Nov 02, 2015 10:59 pm    Post subject: Reply with quote
Great news Ian. It does look clean under there. Good luck with the final stages. (Did you get the ATF pipes sorted?)
2015 Cayman GTS. No more PDK but still red.
deutschland-dobson
PostPosted: Tue Nov 03, 2015 8:49 am    Post subject: Reply with quote
Congrats bud, looks like you had a busy weekend thumbsup
Big question is tho, did you make it to see Neil Diamond? Very Happy
Porsche 911 (964) C4 - Project RED - Outlaw4
Guards Red & Linen, Custom Leather, BBS LM Split-rims, H&R Coilovers, Cleaned Bodywork, 90s audio instal...
igaffz
PostPosted: Tue Nov 03, 2015 12:53 pm    Post subject: Reply with quote
Chris, of course I did Bandit
John, I haven't been able to find out? I didn't realise they would be removing them for the refurb, they've refitted them on a different angle and I've got confused! 50 50 chance of getting it right lol
Ian
Chief
PostPosted: Tue Nov 03, 2015 1:04 pm    Post subject: Reply with quote
Is the nothing obvious on the PET diagram Ian?
igaffz
PostPosted: Wed Nov 04, 2015 9:41 pm    Post subject: Reply with quote
Hi chief, PET diagrams not clear, I've been told it's a simple loop and dosent matter which way the fluids going through the rad? I'll keep an eye on it.
Anyway I drove her home tonight thumbsup
I will be keeping an eye on her and double checking what I can over the weekend.
Ian
jkeith
PostPosted: Wed Nov 04, 2015 11:40 pm    Post subject: Reply with quote
Great work Ian, nothing short of awsome work on your behalf. Enjoy!
My car has started to deposit oil on the garage floor....going to check it out tomorrow.
See you soon,
Keith
2005 996 GT3
1986 Grand Prix White 3.2 lhd whaletail
2005 BMW 325 M sport
1986 944 turbo (sold)
968 Clubsport (sold)
964 (sold)
igaffz
PostPosted: Thu Nov 05, 2015 8:29 am    Post subject: Reply with quote
Don't worry mate, that's what garage floors are for!
I've ordered a new resistor (the spring thing that clips into the heater ducting) I noticed mine was damaged and my blower fan wasn't working? Hopefully that will sort it!
Ian
deutschland-dobson
PostPosted: Thu Nov 05, 2015 9:02 am    Post subject: Reply with quote
Congrats on getting her home bud thumbsup
Mr Bacchus
PostPosted: Sun Nov 08, 2015 10:09 am    Post subject: Reply with quote
igaffz wrote:
I've got the ATF cooler pipes mixed up! The two pipes fix onto the fittings at the gear box, anyone know which way they go? Or if it matters Which way the ATF goes through the cooler?
Ian
Ian, do you have the Porsche Workshop Manual, maybe that will help? I managed to find a pdf copy of the auto transmission manual with a quick Google search.
Steve
In vino veritas
MY89 964 C4 Guards Red, MY16 Evoque Coupe
igaffz
PostPosted: Sun Nov 08, 2015 7:15 pm    Post subject: Reply with quote
Hi Steve, I've got a workshop manual on cd, when i remember I'll dig it out and put in on our new laptop, thats if I can get my wife to show me how to turn it on Surprised
Can't for the life of me get the blower pipe to stay cliped into the rubber on top of the fan housing?
It just won't stay cliped in around the back frustrated anyone got any ideas? I've tried unbolting the housing from the fan but it comes out again when I bolt it back up!
Ian
Mr Bacchus
PostPosted: Mon Nov 09, 2015 8:10 am    Post subject: Reply with quote
Ian
Are you sure the fan is in the correct position? There is a boss on the fan that sits through a hole in the plated bracket behind (the one that mounts the flywheel and knock sensor connectors). I have had my fan bolts in but not the boss in the hole and hence the fan sits slightly forward? Also, check if the rubber has any small splits around the folded edge, I had to replace mine for that very reason.
Steve
In vino veritas
deutschland-dobson
PostPosted: Mon Nov 09, 2015 10:26 am    Post subject: Reply with quote
Carefully does it, but work the seal around using a flat blade screwdriver so that the blower pipe sits inside the fan housing section.
Chris
tdiquattro
PostPosted: Mon Nov 09, 2015 5:17 pm    Post subject: Reply with quote
Might be worth checking it is a 964 fan not 993, they are sometimes used as a replacement and the bolt fixings are longer and should have been trimmed down. maybe they are not quite trimmed enough?
964 C4 Targa, Audi A2, GSXR750K7, and a Santa Cruz Tallboy carbon
igaffz
PostPosted: Mon Nov 09, 2015 8:30 pm    Post subject: Reply with quote
Cheers lads, with the dark nights and a very wet weekend I haven't been able to look at the car, hopefully I'll be able to sort it this weekend. It was ok befor I removed the engine so it can't be anything to complicated.
I ordered a new resistor from type 911 but got an email off them saying the order hadn't gone through (the web site went a bit funny when I ordered it) any way it was much cheaper from Porsche!
The spade end connector gas snapped off, I tried to solder it back in but the solder wouldn't stick to the metal?
Anyway it's not expensive so I should have it replaced by the weekend. I damaged the rear bumper when I drove off the trailer so I dropped the replacement centre section and two corners off at the body shop today, cheers Chris thumbsup
Ian
deutschland-dobson
PostPosted: Tue Nov 10, 2015 5:13 pm    Post subject: Reply with quote
No worries bud Smile
I hope you're dog has finished sorting that basket of washing? puh
Chris
Marky911
PostPosted: Thu Jan 14, 2016 5:13 pm    Post subject: Reply with quote
Hey Ian, (and Chris, Thomas et al),
I mustn't have looked on this site for about a year or more!
Sorry to read of your box issues. Looks like you've got it all under control though.
Car still looks great and is worth every bit of the effort. Good luck getting it back together etc. thumbsup
igaffz
PostPosted: Thu Jan 14, 2016 8:44 pm    Post subject: Reply with quote
Hi Marky, how's things? You still without a sports car?
Marky911
PostPosted: Thu Jan 14, 2016 11:28 pm    Post subject: Reply with quote
Yes still sports car-less unfortunately but houses and home stuff come first. Got the driveway, gardens and garage doors to do this year then I can have a life again.
Hopefully be back in a 911 again by next summer for my 40th. Or if a straight cheap car comes up, maybe sooner.
Anyway top spannering as ever! Just noticed a 928 thread by you so I'll go and have a read. You're a glutton for punishment. Wink
Enjoy the car once it's back on the road. I'll hopefully make it out on a run when/if I get back into something decent.
igaffz
PostPosted: Sun Feb 07, 2016 10:23 pm    Post subject: Reply with quote
Quick update, after driving the car into the garage with out any drama a week later when I went to start her she was as dead as a door nail! Me and my brother traced the cause to the starter motor. We removed the starter last weekend and I dropped it off at heaton auto electrics for testing and repair. They fitted a new selanoid for a grand total of £15! Refitted the starter today with my brothers help and she started instantly!
Recycled and ready to start the beast for another 20 years!
Word of warning, I don't know if the manual starters are easier to fit but the tiptronic ones are a total nightmare with access close to zero! It was easier to take the engine out lol.
Goto page Previous  1, 2, 3 ... , 16, 17, 18  Next
Page 17 of 18
