996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
Macan : 2014- 3
Mondrian
PostPosted: Sun Oct 02, 2016 5:40 pm    Post subject: Reply with quote
paul284pt wrote:
Quote:
That was a timely post as my warning light came up before MOT yesterday so need to investigate today ... Thanks for posting.
Pleased to be of service Mondrian Thumb
If your light keeps coming on but the wheel is intact it probably means the wheel is on it's way out, possibly either a flat spot or it's sticking on it's spindle. If it's the latter you could try a squirt of WD40 if you're accurate enough but don't get it on the belt.
Paul
My whole unit had come off, surprisingly all there and no damage - even the bolt was still there alas hiding/wedged under the unit which I only saw when I pick up the unit up ..... too late however as the bolt disappeared into the well. I had a poke around with a long magnetic screw driver to no avail. Looks like easiest fix is to buy a new bolt - any idea of size?
Might be a good idea for others to check their bolt is nice and tight!
paul284pt
PostPosted: Sun Oct 02, 2016 8:18 pm    Post subject: Reply with quote
Quote:
Bottom of door was fine although full of rust 'gravel' but fortunately the drain holes wern't too blocked. Now all nice and clean..... very difficult to polish in there though!
With your professional skills Mike I'm sure you'll find a way, break out the jeweller's rouge Grin
Hi Mondrian,
Oh b***er! frustrated What happened to your security blanket? While yer in there would you mind having a look for my missing wheel too Grin
This is the part number you need N0147432 pan-head screw M 6 X 30
Here's a link to the page where you can order one from Design 911 for £0.65 plus VAT and postage.
http://www.design911.co.uk/pages/diagramsBrowser.aspx?categoryID=1&diagramID=2227
Today I've been resetting my suspension and tyre pressure in case my fillings fall out next week on the North Yorks Moors run, and of course a little clean up, I know housekeeping is watching, you know who you are wack
Cheers,
Paul
1980-4 924 Turbo with mods. (ex Tony Dron - 12th at Le Mans 1980 with works 924 Carrera Turbo).
1984-9 911 SC (1982)
1989-93 911 Carrera Sport (1989)
2010- 964 Carrera 2 (1990) Redtek 3.8RSR
2012-14 Porsche Cayenne (2012)
2015-17 Porsche Cayenne Diesel S (2015)
2017- Macan Turbo Performance Package
jkeith
PostPosted: Sun Oct 02, 2016 9:23 pm    Post subject: Reply with quote
Now Paul,
Housekeeping inspections are one thing but trying to remove the evidence before a spot check is going too far! Just look at the dirt from the near side front wheel arch! You dirty boy!
Have you been driving around Middlesbrough or is that Tyneside dirt?
The second picture has a fantastic 'glow', is that a special filter or just a different lighting level?
So looking forward to next weekend,
Cheers, Keith.
2005 996 GT3
1986 Grand Prix White 3.2 lhd whaletail
2005 BMW 325 M sport
1986 944 turbo (sold)
968 Clubsport (sold)
964 (sold)
paul284pt
PostPosted: Sun Oct 02, 2016 9:28 pm    Post subject: Reply with quote
You should have gone to Specsavers Keith, that's soap suds matey!
It's the Chrome filter on yer actual iPhone settings. I always think cars look great in the lights of filling stations at night, is it just me Question
Cheers,
Paul
Mondrian
PostPosted: Wed Oct 05, 2016 9:58 am    Post subject: Reply with quote
paul284pt wrote:
Hi Mondrian,
Cheers,
Paul
Thanks for the part number Paul. I thought I had lost the screw so was just evaluating the situation. Tried various sources including OPC and it would have taken 2-3 days. Your friendly engine builder kindly saved the day with his magnetic rod and fished it out, so now I can say my engine has been breathed upon by Nick Fulljames!
paul284pt
PostPosted: Wed Oct 05, 2016 7:43 pm    Post subject: Reply with quote
I like your thinking and a very cheap way to do it Floor
Pleased you're sorted.
Cheers,
Paul
paul284pt
PostPosted: Wed Oct 05, 2016 8:45 pm    Post subject: Reply with quote
Hi Chaps,
When fitting the new alternator sensor I noticed the hose connector/clip on the RH dizzy was loose and came off easily in my hand. Which is potentially bad news, if ozone leaks onto the fan belt it will rot quicker than a good relationship between the press and an England manager. So a mental note to replace it was made, and sooner rather than later.
The small clip comes in the distributor vent kit, it's a fix for earlier models which had the ozone problem. Don't panic unless your car has been in storage for 27 years or so, it would have been done by an OPC on a recall. The distributor nearest the fan should now be vented via a hole in the heater pipe and connected to the rear rear lense.
Obviously I only needed the connector clip but there was a nice length of new tube and mine was looking pretty ratty. Why I'd never thought to renew this before I've no idea but since housekeeping is taking a deeper interest I thought I'd better sharpen up Grin
Unfortunately there's not enough tube to do the final part to the heater tube so I'll need to order another frustrated
Another little job was to fit the carbon engine bay tidy strip I'd ordered from www.kunststofftechnik-buehler.de and the heat resistant Porsche script in red, which I'm not sure about, possibly overkill Question
Cheers,
Paul
Mr Bacchus
PostPosted: Sat Oct 08, 2016 6:00 pm    Post subject: Reply with quote
paul284pt wrote:
Hi Chaps,
On Sunday when I was out doing a recky for our North Yorks run on the 9th my alternator sensor warning light came on, naturally I stopped immediately.
Fortunately it wasn't serious, the belt was still intact apart from some superficial marks on the surface (see photo) but the little spinning wheel on the sensor/sender was nowhere to be seen.
Hi Paul,
I had the same a couple of weeks back, on the way back from an overnighter in the Dales. Light came on whilst heading home on the A1 and having read about this problem predicted what it might be so didn't bother to stop as I was nearly home.
I did actually find the plastic wheel, it was intact and lying just under an engine mount but the bearing was nowhere to be seen - just the shaft on the arm remaining.
Replacement was easy as per your report. I made a mental note to give the wheel a spin before any decent journey but so far have never remembered to do so
Rolling Eyes
In vino veritas
MY89 964 C4 Guards Red, MY16 Evoque Coupe
paul284pt
PostPosted: Sat Oct 08, 2016 6:42 pm    Post subject: Reply with quote
Hi Steve,
It does seem to be a weak point. The trouble with the arm resting on the belt is that it could create heat with the friction and catch fire. It's definitely worth stopping.
Are you coming tomorrow? See N. Yorks Run.
Cheers,
Paul
Mr Bacchus
PostPosted: Sat Oct 08, 2016 7:20 pm    Post subject: Reply with quote
Completely missed the post in events until I read your question Paul, I really need to get on here more frequently! I could have been up for that.
After a summer of avoiding doing any further real work on my car in favour of driving it every weekend I'm finally starting the suspension replacement tomorrow afternoon. I put it in for the MOT today (pass), a month early, so that I can concentrate on the task in hand.
Drive safe and have a great day, see you next time.
Steve
In vino veritas
paul284pt
PostPosted: Tue Dec 13, 2016 8:34 pm    Post subject: Reply with quote
Seasons Greetings Friends santa
I have a problem and I'm going to share it with you lucky chaps! Recently I purchased a Rennline steering wheel quick release knowing I was going to have the problem, so here it is.
Shall I try to find a way to make a connecter which will pull out/disconnect when the wheel is taken off, or leave the horn button as a dummy and find another hopefully elegant solution for the horn?
Any ideas?
Also you may remember I fitted the fantastic R3 LED headlights and some people on the other channel had a little trouble getting sets from the supplier I used and asked for my help.
I knew the bulbs were manufactured in China and set about finding a new supplier, anyway I found a reliable distributor in China and bought myself 3 sets. I'll keep a couple as spares in case I need any, but if anyone would like this brilliant upgrade (get it?) there is one set available at cost (plus postage inc.) i.e. £46. The first interested party to post their intention underneath this post gets them.
For full details please see my earlier posts (p.63 & 64)on this plug and play upgrade.
Happy daze,
Paul
thumbsup
crz21
PostPosted: Tue Dec 13, 2016 8:57 pm    Post subject: Reply with quote
Hi Paul, sorry cant help with your horn problems but I'll take the LED head lights if no one else has claimed them.
Michael
1990 Guards Red 964 C4, deCat & G-Pipe. Bilstien with H&R turbo springs.
2004 Audi A4 Avant 1.8T.
2007 Z4 3.0si Coupe.
paul284pt
PostPosted: Tue Dec 13, 2016 9:02 pm    Post subject: Reply with quote
Hi Michael,
No problem, their your's. They are the headlights only, no sidelights but sometime when I have a minute I'll see if I can get some more LED sidelight bulbs. I'm sure you will be delighted with them.
Just PM me your address please and I'll also send you details and post them Special Delivery tomorrow.
All the best,
Paul
Mr Bacchus
PostPosted: Wed Dec 14, 2016 10:04 pm    Post subject: Reply with quote
Hi Paul,
I have experience of quick connect/disconnect connectors for military applications - but typically they have like 21 conductors and are massively expensive.
I'll talk to some suppliers, might be able to get a sample. The problem is not the connection - but how to mount each half. Unless you want it on a curly cable rally car style which i doubt.
Steve
In vino veritas
paul284pt
PostPosted: Fri Dec 16, 2016 8:12 am    Post subject: Reply with quote
Hi Steve,
Thanks for that, I would be very interested to see what you can come up with.
The idea would be to keep the connector as small as possible and integrate it unseen, I'm not sure if it's possible but its worth trying. But I think a curly cable is out ha!
I appreciate any help you can offer and I'll look forward to hearing from you in the meanwhile have a fantastic Christmas.
All the best,
Paul
jkeith
PostPosted: Fri Dec 16, 2016 4:52 pm    Post subject: Reply with quote
Hi Paul,
This is an interesting problem. I guess horns are not a requirement for single seaters and curly cables can work for rally or other motorsport vehicles.
I can't see anything working on the steering column (some form of jack plug?) and wonder if a horn push can be incorporated on one of the stalks? It probably needs a good auto electrician to engineer an acceptable solution.
I'm intrigued to understand how the quick release mechanism can fit with the ergnomics (pedal reach vs steering wheel reach) of a 964.
I asked myself the obvious question of 'why would you do this?' and could only come up with 'because I can'.
Is there any knowledge from hot rodders across the pond? Could a floor mounted switch (aka mini start button?) or even a door mounted switch near the window controls work?
I'm sure somebody else must have done this on other cars.
Good luck with the search and have a great/safe time over the festive period.
Cheers, Keith.
2005 996 GT3
964 (sold)
paul284pt
PostPosted: Sun Dec 18, 2016 7:54 pm    Post subject: Reply with quote
Hi Keith,
I hope you are keeping well?
The reasons I'm considering this upgrade is not because I can. The main reasons are because it's a brilliant anti-theft deterrent when the car is parked overnight when I'm touring and every little helps. Secondly because if I do have an "off" anywhere (I've been in that situation before) it really does what it says on the tin and releases the wheel quickly.
However, I also don't want to loose the centre push horn, unless of course I/we can come up with some really cool alternative. If I can't do either I'm not going to bother but I needed to buy the piece to be able to visualise them problem.
Cheers,
Paul
Jcx
Estoril
2010 Porsche 997 Turbo
PostPosted: Sun Dec 18, 2016 8:14 pm    Post subject: Reply with quote
I think it would be easy Paul to have a second 'socket' to which the wheel connects when engaged. This second socket is ancillary to the physical connection for steering and will close the power loop for the horn. If you had someone machine a solution for you it could be fully integrated. I have no doubt your talented lad would design something beautiful. 3D print a prototype and then machine the solution.
Job done. Smile
Happy Christmas!!
paul284pt
PostPosted: Mon Dec 19, 2016 8:21 pm    Post subject: Reply with quote
Hi Joe,
Thanks for your input. That's more or less what I'm thinking Thumb
Or it may be possible to adapt the Rennline piece and integrate a jack plug and socket like Keith suggested. Question
Cheers,
Paul
Mr Bacchus
PostPosted: Wed Dec 21, 2016 5:42 pm    Post subject: Reply with quote
Hi Paul,
I've done a bit of digging and this can be done but its going to be some work to get it how I know you will want it!
We are using Amphenol Terrapin connectors (info on the web) in similar applications (push/pull connect/disconnect) but they are mounted in bespoke machined housings
Honestly speaking I think you might be better doing a remote horn or backtracking a bit and getting a pre-wired wheel mount which I have seen.
I could probably get sample Amphenol Terrapin connectors if you wanted to try to make an installation.
Happy to help if I can
All the best
In vino veritas
Goto page Previous  1, 2, 3 ... 65, 66, 67, 68, 69  Next
Page 66 of 69
