964 : 1989-1993 5
Boxster : 1997- 19
Cayenne : 2003- 3
Macan : 2014- 1
2014 Porsche Boxster 981
PostPosted: Sat Sep 14, 2013 4:13 pm    Post subject: Reply with quote
A bit more playing around with the Bosch "Hammer" today so I understand exactly what I have got in terms of hardware before I get to playing with the software....
the Bosch KTS 300 series of diagnostic testers (also known as a 9288 in Porsche documentation) were usually fitted with generic software modules that can be used to test basic functions of many makes of car including Porsches. However Porsche dealerships were supplied with special versions KTS 301 which had Porsche specific software modules fitted. These were much more expensive (c£4000 18 years ago Surprised ) but could carry out many more diagnostic tests than the generic modules.
The last of the KTS Porsche software modules was version 8.1 dated 1995. This covered models including the 928, 944, 968, 964 and 993.
Up to and including the early 993's the connection for the car was a round socket (19 pin) connector. Later 993's had the upgraded rectangular connectors. There are therefore 2 types of connection leads with either a round or rectangular (for later 993's). They are both interchageable.
My unit has the Porsche specific software module version 8.0 dated 10/1995 and has the later Porsche 993 rectangular connection lead. I could source the older round connection lead to allow the unit to be used on 928, 944, 968, 964 and older 993 models.
The only other consideration is that the units have a built in rechargeable battery. I'm not sure if the units came with a separate charger but it appears they can be recharged when plugged into the car which takes about 8 hours. When I plugged mine in it initially stated that the battery required recharging but after 1 minute worked fine including the display light (which can be turned on / off). This leads me to believe that the unit simply requires the batteries to be fitted and capable of holding some charge rather than being fully charged to work. I can only think the benefit of battery power is the ability to review error codes when disconnected from the car Dont know
The unit is very simple to take apart to access both the rechargeable battery and software module. There is simply a rubber cover which pulls away to reveal access points for the battery cover and the software module in the side of the unit.....
The Porsche specific software module (nb the 928 refers to the model series 9288 and not a Porsche 928)....
Which simply pushes in / out of the side of the unit....
The original Bosch battery was in great condition physically ie no sign of any leaks.....
It is simply a pack of x6 Ni-Cd AA 7.2v rechargeable batteries which have 2.88mm spade connectors.
OCD would dictate that this should be replaced especially as battery technology has come a long way in 18 years. Fortunately these packs are standard in the model car industry albeit with different connector blocks which can easily be replaced with 2.88mm spade connectors Thumb
I have ordered one of these for £3 delivered Bandit
with spade connectors fitted it should look like this....
Not only do I get a new battery for little money / effort but it will last several times longer than the original battery would have when new due to the more advanced NI-MH technology.
Its obvious the unit is in very good condition and has virtually the last version of the Porsche specific software installed. It is worth noting that these units are very robustly built obviously with heavy workshop use / abuse in mind.
The connections cable to the car is c3m in length and well protected. It is presumably designed to allow you to walk around the car with it plugged in whilst testing eg I quickly tested the high and low oil cooler fan speed whilst stood next to the fan in the drivers front wing so you can hear it easily shift speed at the touch of a button.
All in all I'm very chuffed with it. They are not cheap but the way I look at things like this you can always resell for what you pay for them so they don't really cost you anything they just tie up capital in them. I love playing with gadgets so I'm glad I've picked one of these up to help me learn about my 993 over winter Wink
ps of course you should do your research before buying but sometimes you have to take a flyer when time does not allow research ! Looks like I got away with it this time and got the perfect unit for my car, phew Cool
EDIT: I have now got my hands on the manual for the device. Its actually contained in the 993 workshop manual - under section D for diagnosis of all places Hand
It appears one of the buttons is used to "store" screenshots at any time which can later be recalled even when not connected to the car. So the rechargeable battery is presumably required to facilitate this assuming RAM is used which requires a constant power supply Wink
The manual can be downloaded by clicking ......
Operating Instructions
Manual - Bosch Hammer - System Tester 9288 - Operating Instructions - extracted 993 Workshop Manual
"Great spirits have always encountered opposition from mediocre minds" Einstein
#lastoftheaircooled
2014 Porsche Boxster GTS My Journal
mohitos
1995 Porsche 993 Carrera 2
PostPosted: Sat Sep 14, 2013 4:22 pm    Post subject: Reply with quote
Nice bit of kit ! And at only £1.10 more than your handbrake, is arguably good value Laughing
What are your thoughts on the Tore OBD kit by comparison - it sounds like this way more comprehensive in it's abilities.
PostPosted: Sat Sep 14, 2013 5:43 pm    Post subject: Reply with quote
The tore b kit using the free version of scan tool is really good value. For example you can run a full cyclical test of all the climate system servos and flaps.
I've not had chance to use either in enough detail to know the differences other than the obvious hassle of having a laptop in your car v bespoke hand held tester v cost.
I believe the scan tool software will now do idle resets as per the hammer which was one of the differences that may have been removed but I think in principle the hammer still has more functionality. Whether those differences are material to me I don't know yet eg I'm not sure if scan tool can test / reset the airbag ?
I know for certain the hammer is the only way to properly bleed the 964 4 wheel diff but as the 993 4 wheel drive system is totally different to the 964 I'm not sure it is needed for mine Dont know
I can see a boys toys day spent playing with the hammer v the scan tool one winters day Bandit
Ps I've had to hide it as my 3 year old daughter has been trying to plug it into the Denon amp for the past 10 minutes Surprised
#lastoftheaircooled
Dream911
PostPosted: Sat Sep 14, 2013 8:12 pm    Post subject: Reply with quote
jonttt wrote:
Dream911 wrote:
mohitos wrote:
Jonttt - I am deeply concerned. It's 14 days since your last upgrade. Is everything ok ?
I`m looking forward to seeing that handbrake fitted Thumb
pics of it installed are on the previous page Wink
Some how I missed that.
Enjoyed reading the very nice write up.
Handbrake looks fantastic Thumb
g60pops
PostPosted: Thu Sep 19, 2013 10:23 am    Post subject: Reply with quote
Jon, any chance of a link for where you got the battery pack and connectors from for the hammer?
PostPosted: Thu Sep 19, 2013 5:45 pm    Post subject: Reply with quote
From ebay just search spade connectors and get a mixed box for a few £ ...
http://www.ebay.co.uk/itm/400560302838?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I ordered this battery but not received yet...
Search for AA 7.2V 1800MAH Ni-MH Rechargable Battery Pack
http://www.ebay.co.uk/itm/390567661405?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
#lastoftheaircooled
g60pops
PostPosted: Fri Sep 20, 2013 4:32 am    Post subject: Reply with quote
thanks
PostPosted: Sun Sep 22, 2013 7:16 am    Post subject: Reply with quote
What a fantastic weekend driving around the welsh valleys but unfortunately two up with golf clubs meant it had to be in the daily hack Sad
#lastoftheaircooled
cambjones
1997 Porsche 993 Carrera 4
PostPosted: Sun Sep 22, 2013 7:31 am    Post subject: Reply with quote
You have time for golf too Surprised
You're not human.
At least that is what I'm telling myself as I have far less time management skills managing family, work, travel & 993 obsession.
I think you should start running classes!
Smile
PostPosted: Sun Sep 22, 2013 8:08 am    Post subject: Reply with quote
The pressure is on today though, I'm leading on 69 points after 2 rounds with 4 people within 4 points, good fun though.
Perfect golfing weather but I need to figures out how to get 2 sets of clubs in a 993 lol.
Your right though I do deserve a rest so off to Dubai next week for a bit of pampering to get over the golf Bandit
#lastoftheaircooled
mr pg
PostPosted: Mon Sep 23, 2013 7:32 pm    Post subject: Reply with quote
You need to go back then, as I know from experience that a weekend away for two including two sets of clubs is perfectly possible. We've done it.
Dream911
PostPosted: Mon Sep 23, 2013 8:01 pm    Post subject: Reply with quote
Had 2 sets in the back of my 964 Turbo plenty of time. Put the rear seats down, drivers out lying on top. Shoes etc in the bonnet. Thumb
Carry bags only.. no tour bags and trundlers.
PostPosted: Mon Sep 23, 2013 10:05 pm    Post subject: Reply with quote
Unfortunately we both have full tour bags but I must admit we did not try to fit them in the rear but just assumed it would be too tight a squeeze. I'll definitely try the next time we do a uk based tour Thumb
Ps I blew up on the Sunday, well in relative terms anyway, 5th on the day had 37 points Surprised and I was worse. When a 2 handicapper scores 40 points to take it over the weekend you've got to applaud him even though I had to give him a 3 hour ride home while he gloated Sad maybe I would have been better off if Sunday had not been such perfect golfing weather Sad
#lastoftheaircooled
PostPosted: Wed Sep 25, 2013 4:36 pm    Post subject: Reply with quote
I've not had chance to change the defective diaphram on the car but have had some enquiries as to the part number so thought I had better post up some pics for reference....
#lastoftheaircooled
Goose
Watkins Glen
PostPosted: Wed Sep 25, 2013 5:25 pm    Post subject: Reply with quote
As you know, one of these enquiries was from me. Smile Thanks for sharing - I'd best get mine on order. Thumb
Goose
AndyS
PostPosted: Wed Sep 25, 2013 6:17 pm    Post subject: Reply with quote
Jon
Just got back from Dubai last night - still too hot!
40 during the day and still in the 30's at night.
Andy
A Class AMG & Golf TDi for the daily
PostPosted: Wed Sep 25, 2013 8:33 pm    Post subject: Reply with quote
Just asked the mrs and she said 34. I should have specified daytime temps Judge
Plays havoc with the churchills
Too hot for me so I'll be in the air conditioned spa Thumb
The good news is I wrapped the roady up for winter today (after a damn good blast in the last of the sunshine) but the 993 is staying taxed for some winter fun Thumb
#lastoftheaircooled
tikkathree
PostPosted: Thu Sep 26, 2013 6:30 pm    Post subject: Reply with quote
Nice write-up but what's this about a tripod? Can't you just put some different film in? Wink
Used to rally tuned Imps: all the noise at the back. Lately an MGF: top down, all the noise at the back.
Now? Engine slung out the back, flat six music in the form of a 996 Cabrio. Deep joy.
PostPosted: Fri Oct 11, 2013 3:45 pm    Post subject: Reply with quote
Well I finally got chance to fix the heater flap diaphram today.
To recap when my car was remapped it was identified that the varioram system was not activating. The failure was due to a faulty part of the heating system ie there is a vacuum system which operates both the varioram and a a rear heating flap. The rear heating flap is activated by a solenoid which when triggered opens to allow the vacuum to operate a flap via a diaphram. I had a faulty diaphram. This would not normally cause total failure of the varioram as the solenoid would isolate any leaks on the heater side until it was activated but to compound matters my solenoid was also faulty (effectively always open). This meant that the vacuum system effectively had a permanent leak and so the varioram part of the system could not get enough pressure to activate when needed. It is possible that the solenoid failed first and this caused the diaphram failure but I believe the diaphram is a common part to fail.
The heating flaps default position means that air is drawn into the heating system via the engine (ie warm) as and when needed. However there are two reasons why the solenoid may be activated to open the flap to bring in air from outside (via the engine grill) rather than from the engine:
- Used when engine air gets too hot and cooler air is needed.
- When reverse gear is selected. ie the grill intake is higher reducing the chance of exhaust gases being drawn into the heating system.
Neither of these functions are critical and this part of the system can be removed meaning that air is only ever drawn in from the engine (ie a different intake tube can be fitted without the flap etc....)
Therefore as a temporary fix the solenoid was replaced with a replacement part (FOC as they had one spare at the garage on the day of the remap) and the electical connection was disconnected to prevent the solenoid from opening and causing a pressure leak via the faulty diaphram ie meaning that the varioram system worked for the remap.
So down to replacing the faulty diaphram.
Here is the part. I can't remember the exact price as I bought it some time ago now but it was c£50.
The first thing that I noticed was a change in design to the old part ie the activating rod with ball joint is a fixed length. On the original it is two piece allowing the length to be varied. This did not cause any problems as the set length was fine when fitted.
Here is the original in place (spot my winter job to clean the engine now that I have fixed the spoiler wall)....
It is a simple yet fiddly job to remove and replace. There are two hex bolts that need to be unscrewed. However they are accessed via the side and certainly if you have varioram and air con pipes they get in the way. You need a small hex key (or cut an old/cheap one down). You need to feel the key into place blind to undue the bolts (nb putting them back seemed much easier). Tip: place a cloth under the part as its so easy to drop either the hex key or bolts down into the engine and they are a nightmare to get out (ask me how I know!).
Once these two bolts are removed its simply a matter of removing the top vacuum hose and cracking the ball joint at the bottom of the lever.
Here are the parts exposed and you can clearly see the lever that operates the flap in the heater inlet tube to divert airflow from engine to grill intake....
Fitting is the reverse and seemed a lot easier / less fiddly. Job done.
Here is a video of the fresh air flap now working properly. The test is carried out using my Bosch "Hammer" diagnostic tool. The ignition is on which primes the vacuum system and you can use the "Hammer" to switch the flap to the two positions on command. You can actually hear the flap flip over and then see the push rod moving....
ps you could do the same by getting someone to sit in the car and switch from 1st to reverse gears Wink
click on pic for video link
#lastoftheaircooled
PostPosted: Fri Oct 11, 2013 3:55 pm    Post subject: Reply with quote
ps I've got the 993 out for the weekend. First drive for weeks Bandit
#lastoftheaircooled
Goto page Previous  1, 2, 3 ... 18, 19, 20 ... 42, 43, 44  Next
Page 19 of 44
