997 : 2004- 67
Boxster : 1997- 31
PostPosted: Fri May 24, 2013 10:38 am    Post subject: Reply with quote
Some small OCd jobs which make all the difference Grin
Myu rear spoiler only had one protection cap fitted. If that would have been missing I would not have even known there should be some.
You need 6 of these in total
Here is full write up on fitting for those poor souls who are not very technical.....
1) raise spoiler. Hint it is easier to do this whilst stationary via the button in the car rather than at 40MPH + Hand
2) push on each protection cap (one at a time unless you have really long fingers and are a magician)
3) lower spoiler via button in car (or slow down Dont know)
job done Cool
Next was for the dreaded drainage rubbers. I had two missing so ordered 5 Rolling Eyes
nb these are listed under the headlight fittings on PET as they are also fitted in the headlight recesses.
and finally a more obscure part......door lock covers. As I have remote central locking I would only ever us the key in the door locks in an emergency. These are designed to stop crap getting onto the keyhole. Again I need to clean the keyholes properly at some point but covers fitted
before
after
PostPosted: Fri May 24, 2013 10:49 am    Post subject: Reply with quote
Nice one Jon - Nipples and teats done Thumb I will have to get the door lock caps Embarassed
BTW have you ever been to the Chung Ku restaurant on the waterfront? Owner Norman Shum is a big Porsche fan - IIRC he has a 964 3.6 Turbo and I believe ninemeister are building a back-date for him. Goes by 'Nski' on RL
The game's afoot. It's time to put a bit of (Colini) stick about......Why RUF when you can WUF
PostPosted: Fri May 24, 2013 12:02 pm    Post subject: Reply with quote
I know of it but never been. Its one of those places I've always wanted to try but never got round to it not helped by the fact the best known chinese in Liverpool is on my doorstep Very Happy
PostPosted: Fri May 24, 2013 10:03 pm    Post subject: Reply with quote
Update on the motorsound airbox....... Yep it makes a difference........ Much more than I thought it would so will be staying on even if it does loose a few BHP. I did scare myself trying it out though Smile
aak
PostPosted: Fri May 24, 2013 10:27 pm    Post subject: Reply with quote
Hi!
where did you get the door lock covers from??
993 C2 Schwarz Black
997 C2S Seal Grey
PostPosted: Sat May 25, 2013 12:31 am    Post subject: Reply with quote
I got them from jasmine porsche a part as I have an office just down the road from them. You could order them from an OPC. The part number is in the picture.
PostPosted: Sat May 25, 2013 9:37 am    Post subject: Reply with quote
I have received my cars official Porsche Certificate of Authenticity.
There is usually a fee for this but its free if you quote your PCGB membership number Very Happy
PostPosted: Sat May 25, 2013 9:42 am    Post subject: Reply with quote
I ordered some aluminium bezel rings and decided to fit them. I used Bluetack as contact adhesive so they are easily removable when required.
They will fit in with some other changes I have in the pipe line as part of my plans to "lift" the blue interior Wink
and original v new look....
ps I've had more chance to drive the car with the new steering wheel fitted and I really am pleased with it Smile
PostPosted: Sat May 25, 2013 9:49 am    Post subject: Reply with quote
Another quick and easy job was to replace the blown light switch bulb.
These should be on whenever the ignition is on and so the bulbs must blow after a few years of constant use.
Very easy change, bulbs sourced for a few £ from ebay, pull off the knob top (nb you do have to pull hard but it will just pull off), pull out the exposed bulb left behind, push in new bulb (leave ignition on so you can check the bulb works) and then push the knob button back on (nb it does have a small grove so is directional with the bulb upside down when you push back on)
Knob pulled off with exposed bulb holder left behind (bulb removed)
New bulb in place
Job done....
Its weird to think this bulb could have been blown for 10 years and no one realised.
Is it working in yours Question Grin
PostPosted: Sat May 25, 2013 10:03 am    Post subject: Reply with quote
I love buying a new hobby car, the first few months feel like Christmas every day Very Happy
New suspension arrived today.
I was keen to retain the M033 OEM 4S suspension height and ride settings whilst upgrading the OEM dampers for some units which would last longer. The car will not be tracked and so I do not need a fully adjustable setup. Plus my other toy has a track "Race" suspension fitted which whilst great around the twisties does not half make the teeth chatter Laughing
I settled on the well proven Bilstien B8 (also known as HD's for Heavy Duty) with new OEM M033 springs. These do offer adjustablility for ride height/corner weighting but not bump and rebound.
nb The Bilstein B8 shocks/dampers have the same damping as the Bilstein B6 but the stroke of the pistons is 20mm shorter. Due to the shorter rebound, it makes the Bilstein B8 a better match for the shorter M033 / M030 OEM springs whilst allowing enough adjustment to retain OEM lowered ride height. B6's should be used if standard (longer) 993 ride height springs are used.
Delivered from Gert Carnewal whose customer service is second to none and he offers a range of well proven "kits" to meet all needs. He was also the cheapest I could find which is always an added bonus Thumb
This is one heavy box but received 2 days from Belgium after placing the order. Its so nice to find a supplier who actually has what he sells in stock.
and the sun even came out for the unpacking...
includes new bump stops which is good as mine where picked up on the inspection as being rotten ....
I have to take my 3 year old daughter to Toys r Us now this afternoon as she wants to know why I am getting all the presents
ellistai
1997 Porsche 993 Carrera 2S
PostPosted: Sat May 25, 2013 1:35 pm    Post subject: Reply with quote
I can see that you've got the "blue" M033 springs for the front (front doesn't have a choice anyway). What about the rear? "White" or "Lilac"?
Ex: 04 997 C2S Manual
Current: 97 993 C2S Vesuvius Grey MT
10 997.2 C2S Macadamia Metallic MT
dommorton
1998 Porsche 993 Carrera 4S
PostPosted: Sat May 25, 2013 2:05 pm    Post subject: Reply with quote
Didn't realise you can pull the whole top off these.
I levered the cap out of the middle and used needle nose pliers Grin
Good cars can get you from point A to point B. And great cars? Well, they'll just get you into trouble.
PostPosted: Sat May 25, 2013 2:08 pm    Post subject: Reply with quote
Very nice............where will it end Dont know I like the alu instrument rings. I'd dismissed these before as tacky (probably the chrome ones) but actually they look very good indeed Thumb
PostPosted: Sat May 25, 2013 5:53 pm    Post subject: Reply with quote
There is more than one way to crack and egg.......but some are harder than others Laughing
PostPosted: Sat May 25, 2013 6:05 pm    Post subject: Reply with quote
I was not sure myself but when I saw this version from Carnewal who only seem to source the best parts for the 993 I thought I would give them a go and so added them onto another order. I figured if I did not like them I could sell them on pretty easily.
I do like them fitted and I'm trying for a slight silver theme inside with the steering wheel stitching, gear stick top and other small things in the pipeline hopefully it will all come together without being OTT.
PostPosted: Sat May 25, 2013 6:31 pm    Post subject: Reply with quote
The Carnewal kit comes with Rear Springs P/N 993 333 531 21 504 (White color).
The difference to the more expensive Lilac Rears (P/N 993 333 531 22 504) is negligible. Consequently everyone stocks the whites as they are interchangeable and you would never notice the difference.
ellistai
PostPosted: Sun May 26, 2013 10:13 am    Post subject: Reply with quote
Yeah, but as being OCD, shouldn't you opt for the Lilac one which is more correct for car with A/C? Price shouldn't be a concern of yours Grin
PostPosted: Sun May 26, 2013 2:47 pm    Post subject: Reply with quote
But the slightly stiffer Lilac rear springs are for Tiptronic and White is for Manual cars. Mine is a manual.
I'll double check what comes off but everyone I've asked confirmed my car is white springs. I'm led to believe the difference is negligible in any event.
J97911
PostPosted: Sun May 26, 2013 4:12 pm    Post subject: Reply with quote
What is the number of the Osram bulb for the light switch. I have to do that!
JL
993 96 C4 Arena Red
993 95 C2 Midnight Blue
993 97 S Black Tiptronic
And a few 997s, and a 991, to work out its the 964 I actually wanted....
PostPosted: Sun May 26, 2013 8:10 pm    Post subject: Reply with quote
They are a common fitting for all makes of car search 2721 bulb on ebay Wink
Goto page Previous  1, 2, 3 ... 9, 10, 11 ... 46, 47, 48  Next
Page 10 of 48
