NXI20
Estoril
- Joined
- 2 Feb 2008
- Messages
- 3,572
BRAND NEW, never fitted & still boxed.
Dual Flow Valve Technology (See below)
Ride height adjustment separate from spring pre-load setting
Single (bleed) damping adjuster controls compression & rebound with positive increments
Corrosion salt spray tested according to ISO 9227
Fully serviceable item, use for the life of the car
Optimum settings 'out of the box', but there is the option of re-valve & spring options if required
Temperature sensitive correction valves for unrivalled consistency & no 'fade'
Come complete with monoball top mounts & springs.
Price new £2450, offered at £2000
