996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
Post new topic   This topic is locked: you cannot edit posts or make replies.
Gazc2
PostPosted: Sat Jan 05, 2013 3:35 pm    Post subject: Reply with quote
Discord wouldn`t let it put you off I think its all a balance of what you will pay for a properly sorted one or one that is good to start with (hard to find) as long as the purchase price reflects condition which mine did and was aware of the body needing work, I suppose the killer is of you pay decent money which most of them seem to be asking at the moment and you find it need this degree of work. I am intrigued at the moment with 993 owners looking at the 964 not sure I would change back the way I have a 964 because I couldn`t afford a 993 !
Got the rear bumper off today drilled out the 5 rivets along the top edge , had to take the outer cover of as I didn`t have enough access to the 2 main bumper mounts because of my twin outlet fabspeed however will need to take the tips of for refitting which will be easier . One of the mounting points has corroded and broken and will require welding which would appear to be common after talking to Fuch today.
I will probably replace the center section with the RS type been looking at these ones on Ebay which are moulded rather than fibreglass
http://www.ebay.co.uk/itm/270887350157?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
 Filesize:  99.32 KB
 Viewed:  6172 Time(s)
 Filesize:  119.08 KB
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Sat Jan 05, 2013 3:50 pm    Post subject: Reply with quote
My German is a bit rusty but that looks quite decent.
I think I will,wait until you've bought your before committing.
It is on my "to-do" list for my blue one.
KP964
Watkins Glen
PostPosted: Sat Jan 05, 2013 6:05 pm    Post subject: Reply with quote
Very satisfying to know its going to be as clean as a q cumber Gaz , keep up the good work , all that fire wood will come in handy if it gets to cold for you in there Grin
Keith
Stone Grey Metallic 964 C4
Guards Red 964 C4 sold
Gazc2
PostPosted: Sat Feb 02, 2013 6:27 pm    Post subject: Reply with quote
It was a bit of a struggle getting the rear bumper support of f, you can see the alloy corrosion on both the bolts and the retaining tabs on the bumper support both of which have broken not surprising as there was very little left, I ran the bolts over the wire wheel and the corrosion is so bad the bolts have holes in them, the bumper support tubes, one was covered in oil and is in good nick the other one from the passenger side is shot, clear the bumper has never been removed.
 Filesize:  115.15 KB
 Viewed:  6043 Time(s)
 Filesize:  94.72 KB
 Filesize:  125.44 KB
 Filesize:  147.62 KB
Ghengis
PostPosted: Sat Feb 02, 2013 6:46 pm    Post subject: Reply with quote
Ooh that looks nasty!!!
After trying to remove a couple of bolts and failing miserably and ending up with several bolts minus their heads I have the upmost admiration for your ongoing adventure. You are a very brave chap.
Carry on. Mechanic
1990 911 C4 in Guards Red with black leather. Tweeked and fettled ready for the summer.
Gazc2
PostPosted: Sun Feb 17, 2013 5:17 pm    Post subject: Reply with quote
You would hardlt believe these two brackets came off the same car the good one (Drivers side) was covered in oil which obviously protected it so oil leaks not all bad !.
Prepped the front bumper for fitting the brake ducts all pretty straightforward and happy with the fit.
Also looking to get new j-u nuts for putting everything back does anybody know the most common sizes of these No 8 , 10 ? decent selection on ebay here http://www.ebay.co.uk/itm/2008840104...84.m1423.l2649 unless any one has a decent source.
 Filesize:  148.7 KB
 Viewed:  5831 Time(s)
 Filesize:  120.36 KB
 Filesize:  78.03 KB
 Filesize:  176.45 KB
Gazc2
PostPosted: Wed Mar 06, 2013 5:26 pm    Post subject: Reply with quote
So eventually got round to popping the windscreen out and see how far the rust went even though it doesn`t look great it really only right at the corner thats goosed the scuttle is solid a small distancee away from the rust you see didnt get time to look at the other side but pretty much the same I suspect.
remember boys its not the bubbles you have to worry about its what`s underneath Surprised
 Filesize:  91.3 KB
 Viewed:  5722 Time(s)
KP964
Watkins Glen
PostPosted: Wed Mar 06, 2013 6:33 pm    Post subject: Reply with quote
Interesting to see what lies beneath Gaz , quite shocked to see its that bad , good job you're getting that sorted now , some welding required .
Are you going to be painting the whole car ?
Keith
Gazc2
PostPosted: Wed Mar 06, 2013 8:28 pm    Post subject: Reply with quote
Yip full glass out respray on the cards been busy cleaning and prepping all the various parts , just finding the time between kids work etc you would always like it done quicker but only doing it once so its going to be done right.
Peter`s having a blast with your old car sure he will give you first dibs when he gets the Blue one sorted downright greedy having 3 911 and lost count of his engines Laughing
Gazc2
PostPosted: Sun Mar 10, 2013 6:53 pm    Post subject: Reply with quote
Drivers side scuttle not as bad as pass side
 Filesize:  82.35 KB
 Viewed:  6077 Time(s)
 Filesize:  74.82 KB
Gazc2
PostPosted: Sat Mar 23, 2013 4:32 pm    Post subject: Reply with quote
So got round to popping the rear quarter windows out with not to much trouble all looking fine other than some very minor surface bubbling on the pass side which will rub up no problems . Also pulled an old tracking system that was hidden in the dash which I have no paperwork for more weight removed heavy little battery on that tracker Thumb Bodywork/painter is coming to have a look at the car tomorow
 Filesize:  68.92 KB
 Viewed:  6076 Time(s)
 Filesize:  64 KB
 Filesize:  51.33 KB
 Filesize:  86.98 KB
Chief
PostPosted: Sat Mar 23, 2013 6:23 pm    Post subject: Reply with quote
My God, what messes do we get ourselves into....
Looking good though, very satisfying to tear down knowing it will look a million dollars when your finished Thumb
Gazc2
PostPosted: Sat Mar 23, 2013 7:01 pm    Post subject: Reply with quote
Haha your right it seemed like a good idea at the time ! once you start theres no going back need something to keep you busy on a snowbound saturday
fuch
PostPosted: Sat Mar 23, 2013 7:13 pm    Post subject: Reply with quote
Well done Gaz keep the faith must be hard work in this crappy weather. Thumb
KP964
Watkins Glen
PostPosted: Sun Mar 24, 2013 2:13 pm    Post subject: Reply with quote
No stone left unturned Gaz , its gona be great when your done , lets hope you have it sorted to enjoy "some" of the summer if we get one that is .
Interesting to see the photos of all the bits you cant normally see Thumb
Gazc2
PostPosted: Sun Apr 07, 2013 10:19 am    Post subject: Reply with quote
Another bit of progress yesterday got some of the stripping done all looking ok so far with no additional surprises.
 Filesize:  113.32 KB
 Viewed:  5571 Time(s)
 Filesize:  116.65 KB
PostPosted: Sun Apr 07, 2013 10:26 am    Post subject: Reply with quote
Nearly finished then Embarassed Is the car running on Bilsteins?
KP964
Watkins Glen
PostPosted: Sun Apr 07, 2013 2:22 pm    Post subject: Reply with quote
Did you plan to go this far when you started Gaz , as in actually stripping all the paint off , looks like fun but time taking . I look forward to seeing the finished job. worship k
Gazc2
PostPosted: Sun Apr 07, 2013 4:11 pm    Post subject: Reply with quote
Some of the smaller bits done today rear roof spoiler 993 door handles look lovely polished seems a shame to paint them, after some lovely sunshine yesterday back to the bloody snow today.
Yes they are Bilsteins, that was last years winter project, should be finished this year sometime !and yes Keith the intention was always for a back to metal respray because of the bits of bodywork really wanted to know if there was anything else hiding the car also had multi coloured panels,bumpers,mirrors etc and stripping it myself to keep the costs down.
 Filesize:  58.02 KB
 Viewed:  5493 Time(s)
Chief
PostPosted: Sun Apr 07, 2013 5:15 pm    Post subject: Reply with quote
You go girlfriend Thumb
I'm impressed with progress, have you wandered what you've got yourself into yet?
Post new topic   This topic is locked: you cannot edit posts or make replies.   All times are GMT - 12 Hours
Goto page Previous  1, 2, 3, ... 14, 15, 16  Next
Page 2 of 16
