ian996 said:Question:
What is the difference between the following cars:
991 basic model with Aerokit Cup.
991 GT3
911 Turbo
Answer: Nothing they all look the bloody same.
I know they have different engines,number of seats,size of body,performance etc.
But a big mistake if Porsche give them all exactly the same rear wing.They should all be different to match the cars personality like the 997.
ian996 said:I know they have different engines,
Maxie said:The aerokitted Carrera 996 rear wing (both Gen 1 & 2) was the same rear wing as on the 996.1 GT3 except you couldn't alter the angle. The aerokitted Carrera 997 rear wing (Gen 1 & 2) was the same as the 997.1 GT3 (again, no adjustments possible).
~ Maxie
The three angles are set manually (remove spoiler using Allen keys, adjust bracket angle, refit spoiler).
"Passive" is just the first setting and matches the downforce of front splitter.
Further more aggressive angles increases the rear downforce, but should only really be used for track work (plus it increases drag).
Normal setting:
Mid setting:
High setting:
