911BlackEd
Nurburgring
- Joined
- 27 Jun 2011
- Messages
- 461
Ok, have kept quiet about this one, as with the last debacle, I didn't want to tempt fate..
Upon collecting my car at the OPC the roof operation by remote has not worked, by not worked I mean that the roof will get to the halfway point, or less, and stop, pressing the button again sometimes moves the roof closed a bit, but it gets to the point that you just look like a c**k and get in the car to operate the roof.
Some would say, no biggie, but on a car that was £112k, you would expect it to be faultless.
Now, car has been into OPC, they took the keys to show me how it operates, assuming I was trying it from 100ft away or something, it does the same, they have the car in for the day, and say they have submitted a technical request to Germany... Oh dear...
Now, had a bit of time on my hands last week, and as it was sunny, the feature could be useful, so eventually I get the roof to go down via remote, if I sit in the car, and hold the key over the centre console... just above the roof buttons so deduce that it's some sort of noise, and chase the OPC for an answer.
Fair enough, they have already deduced this, well done, and that it's likely to be the VTS fob interfering with the signal, I duly turn off the fob and try, success.
Now awaiting a new antenna for the car to be tested to resolve the fault.
All is good, just thought if anyone else has a cab, with this fault, you can point your OPC in the right direction. Then probably like mine, it will be fixed sometime before summer 2013....
