997 : 2004- 74
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
weebz
PostPosted: Wed Feb 01, 2012 7:43 pm    Post subject: Auto-Dim rear view mirror. Reply with quote
Just a thought with people having things retrofitted to their cars,
Does anyone know if an auto dimming rear view mirror can be retrofitted?
If so what's required and what is the likely cost?
Cheers in advance Very Happy
2010 Basalt Black 997 Carrera S - 'J-Lo 2'
2004 Atlas Grey 996 C4S - 'J-Lo' (sold)
y8cel
PostPosted: Wed Feb 01, 2012 7:55 pm    Post subject: Reply with quote
I would say its all contained in the mirror so would just need power running to the mirror.
Cost of parts and a few meters of wire.
Mine has this already was it not standard?
2004 C4S Cab
Arctic Silver/Metropole Blue
PCM2, BOSE, Hardbacked heated seats, Xenons, Cruise, PSE
weebz
PostPosted: Wed Feb 01, 2012 7:57 pm    Post subject: Reply with quote
Na, this was another 'option' as per usual with Porsches, same with rain sensors etc etc :|
SoliD
PostPosted: Wed Feb 01, 2012 8:44 pm    Post subject: Reply with quote
I was looking into this a while back, apparently you can use a VW/Audi one I read, which is the same design I think. Not sure how reliable it is but may be a cheapeer alternative without the Porsche tax applied.
2003 996 Targa
Partyvan
PostPosted: Tue Apr 03, 2012 9:49 am    Post subject: Reply with quote
Anyone got any further info on this? Very Happy
jml3p
PostPosted: Tue Apr 03, 2012 11:31 am    Post subject: Reply with quote
Me too please
Its the one bug bear I have with mine.
Rgds
jl
weebz
PostPosted: Tue Apr 03, 2012 11:38 am    Post subject: Reply with quote
TBH I never looked into it much more, you can generally find ones on eBay or the like. As for the wiring etc I'm not sure.
fastmonkey
PostPosted: Tue Apr 03, 2012 1:14 pm    Post subject: Reply with quote
Agree on this one annoying not having this as standard.
I looked at A5's a while ago and they are not standard on them either !
04 C4S Atlas Grey
Previous:
B7 RS4 Avant
03 996 C4S
dodgyfocus
PostPosted: Tue Apr 03, 2012 4:43 pm    Post subject: Reply with quote
I've got one which I retro fitted a couple of years ago, Bandit
Its apparently from an Audi a8 (d2) and looks exactly like the manual Porsche one that was fitted originally.
I got it from from ebay for around £40 irc.
1999 996 C2 Manual Coupe in Zenith Blue
SoliD
PostPosted: Tue Apr 03, 2012 4:45 pm    Post subject: Reply with quote
Got any pictures of this and how you wired it into the car? Still interested in doing this to mine.
2003 996 Targa
dodgyfocus
PostPosted: Tue Apr 03, 2012 8:00 pm    Post subject: Reply with quote
Pictures, none (yet) but I could take some tomorrow after work if you like.
It was a while ago that I did it so I can't remember the exact details (without double checking the car), but if you get the right mirror it will just clip straight on the existing mount and there are only 3 wires that require connecting up.
(Switched live, Ground and Reverse)
Anyway (having learnt from my install) if I was to install one again the basic steps would be:-
Extend the (very short) wires from the mirror, across to the passenger side and down behind the A pillar trim.
Then connect the switched live and ground up behind the radio. (assuming its a non MOST car, of course).
Reverse doesn't have to be connected up at all, but its used to get the mirror to automatically clear when reversing which helps a lot at night, (definitely recommended)
As for finding the reverse wire to connect to, that depends:-
If PCM is installed, there is one going to that.
Or "apparently" there's a "weld point" (joint) for the reverse wires under the passenger seat.
(I said apparently because I couldn't find it on my car, so I had to connect it up under the big bit of foam that's behind the rear seats, by running a wire tucked under the carpet all the way from behind the dash, which wasn't actually that hard if I'm honest, may even be easier than moving the seat.)
EDIT - This is the one I've got in mine, although this ones expensive and in the US.
http://www.ebay.com/itm/97-98-99-Audi-A8-AUTO-DIM-Rear-View-Mirror-Rearview-1997-1998-1999-/180855174837?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a1bcef6b5&vxp=mtr
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Mon Nov 12, 2018 10:09 pm    Post subject: Reply with quote
Thread Resurection!
Thought this would be a nice little retrofit, I have autodim mirrors in all my other cars so appreciate it, had a look at the a8 d2 mirror as mentioned in this thread but they have a lot more than 3 wires and the fitment looks different to the standard and 996 mirrors, has anyone done this retrofit themselves?
