Video, 2012 991 Exhaust "Brombacher" with Valves
Moderator
8 Feb 2008
7,361
Exhaust System 991 12- "Brombacher" with Valves 200 Cell "HD" Cats ,Tips 4x90mm
"BROMBACHER" Stainless Steel Exhaust System with valves for the 991
+ 25 Hp & + 20 Tq Gain.
- 200 cell HJS "HD" Sport Catalysts.
- 25 lb. weight savings over OEM system (Weighs 59 lbs. (27,0 Kg), OEM weighs 84 lbs. (38Kg).
- 2 3/4" Tubing (70mm).
- 4 x 3.5"(90mm) Round Tips.
- Motorsport merge collector.
- T 316 stainless steel for improved durability over T 304.
- Absolutely NO DRONE in the cabin.
- "Aero Quip" style motorsport connections without gaskets or flanges to ensure a leak free exhaust.
- Does NOT interfere with emissions and will NOT trigger the check engine light.
- ECU programming (software) is NOT NECESSARY.
- Under load (moving) with valves closed: 85dB*
- Under load (moving) with valves open: 90dB*
*OEM car is 75 dB with valves closed for reference.
124,591
1,441,866
49,021
Camarocane
