997 : 2004- 63
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
GT4
Nordschleife
Nordschleife
PostPosted: Mon Apr 29, 2013 10:53 pm    Post subject: Reply with quote
I suggest you direct him to PET and the original brochure/pricelist (spec).
He is spouting drivel.
The fact is, even if you do convince him, it doesn't change the mufflers from M96 to M97 versions.
So probably best to just move on.
PS - some more cut-aways
wadsy
PostPosted: Sun Jan 26, 2014 5:26 pm    Post subject: Reply with quote
Anyone know if a switchable aftermarket set-up is available as an alternative to OE PSE?....or is it possible to fit a valve into a modified standard set-up?
Rockunrolla
PostPosted: Sun Jan 26, 2014 7:50 pm    Post subject: Reply with quote
Here You go
http://www.driftworks.com/qtp-electronic-exhaust-cutout-bypass-valve-and-y-pipe.html
Bandit
Current -
997 C4S cab manual black
Lambo huracan
RR sport
T6 camper
Harley fat bob
Ex- FERRARI California
Ex - 991 S PDK - Aero kit guards red/yellow wrapp.
Ex - Red 997-Man Coupe-Aero kit
Ex - Silver 996 C4 Tip Cab
wadsy
PostPosted: Sun Jan 26, 2014 10:07 pm    Post subject: Reply with quote
Rockunrolla wrote:
Here You go
Bandit
Thanks Smile ...looks like it might have potential. I would think it would need the valve alone fitting in-line with the additional bypass welded in section of tube?
AM123
PostPosted: Tue Jun 03, 2014 3:04 pm    Post subject: Reply with quote
Hi
Have a 996 4S with PSE".
When it wears out or rusts is it possible to use the original bypass pipes complete with valves as a mod on regular 996 3.6 cans?
GT4
Nordschleife
Nordschleife
PostPosted: Tue Jun 03, 2014 11:33 pm    Post subject: Reply with quote
Yes (assuming they too aren't rusted)
PSE design is just regular cans with the bypass and valve/actuator added.
nigel99
2009 Porsche 997 Carrera 2S
PostPosted: Fri Nov 27, 2015 11:24 pm    Post subject: Reply with quote
Brilliant. Thanks for posting. Are the diode cut steps the same for a 997.2?
Current: 997.2 C2S, Audi TTS mk3
Previous: Cayman 987.1, Audi TT mk1 , BMW e46
GT4
Nordschleife
Nordschleife
PostPosted: Sat Nov 28, 2015 12:35 am    Post subject: Reply with quote
No (it's all DME on the 997)
You have to do the plug pull as per page 2
nigel99
PostPosted: Sat Nov 28, 2015 4:45 am    Post subject: Reply with quote
Cheers, I should have read the entire thread before posting frustrated
Johnd52
2011 Porsche Cayman 987
PostPosted: Sun Nov 29, 2015 7:57 am    Post subject: Reply with quote
Does anyone have similar information re the Cayman exhaust? I would have used Carnewal but they do not do exchange for thr R.
2015 Cayman GTS. No more PDK but still red.
Captain Lockheed
PostPosted: Mon Jan 18, 2016 11:30 am    Post subject: Reply with quote
Great thread I am looking to do a retrofit PSE, just getting my head around it all.
Saving for a 993.
GT4
Nordschleife
Nordschleife
PostPosted: Fri Jan 22, 2016 12:15 pm    Post subject: Reply with quote
Do you mean the electronics side of things or physical bypass mod?
Johnd52
PostPosted: Fri Jan 22, 2016 10:33 pm    Post subject: Reply with quote
A physical bypass mod. I have the non PSE standard r system with the larger diameter primary. I would like a bit more noise. I did not bother with the PSE as it did not seem to make much difference on the Cayman.
GT4
Nordschleife
Nordschleife
PostPosted: Fri Jan 22, 2016 10:45 pm    Post subject: Reply with quote
Physical third-party bypass on the pre-DFI models looked like some complex towel rail.
See here (7th post down):
http://911uk.com/viewtopic.php?p=610202
Flow as below:
Post-DFI is as below:
non-PSE (bypass from pre-muffler entry to central exits):
PSE (corner end valving, bypass straight through mufflers):
So, either bypass as per pre-DFI, or cut back muffler corner shielding, make this small "flying" pipe:
Continuous large bore as per PSE (but without valving):
GT4
Nordschleife
Nordschleife
PostPosted: Wed Feb 22, 2017 5:20 pm    Post subject: Reply with quote
And a guide from MisterCorn how to retrofit PSE to a 996.1:
http://www.911uk.com/viewtopic.php?t=118956
Goto page Previous  1, 2, 3, 4
Page 4 of 4
