:sad: I took delivery of my 06 plate Cayman last May. The air conditioning has ceased to blow cold air and makes a light whirring noise when cold is selected (this stops if the eco button is pressed, presumably turning the compressor off). I am bookein in to the Nottingham porsche Centre in May for MOT , 111 point inspection and to check out this air con problem. I was advised that the system may need a re-gass and that I should have left the climate control on at all times (something that was never mentioned when I picked the car up last may). Is it normal for the gas to have evaporated so soon ? My last car was a Hyundia coupe and was still working fine when 6 years old.
