991 : 2011- 19
993 : 1993-1998 7
Cayenne : 2003- 4
steveoz
PostPosted: Tue Mar 22, 2011 9:48 am    Post subject: ECU / Relay board access Reply with quote
Another few pics that may help someone:
Nice garage fleece I know lol.
This is pretty easy to get to, you just put the seats down, pull the carpet from the middle and there are the covers and mounting plates. ECU is under the left, relay board on the right.
Both covers are bolted together in the middle. The hardest part is getting those damn rubber washers back around the covering plates.
If you are experiencing starting issues and want to see if the ignition relay is working, bypass it, it's the black one. To test, bridge MFIDI relay in position 1 on the relay board (black), remove relay with ignition off. Use fused wire or pin to bridge position 80+87 on the relay. Turn ignition on to test.
Serial of relay is 14195253B.
P.S that brown stuff isn't rust it was just dirty lol.
