997 : 2004- 60
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
GT4
Nordschleife
Nordschleife
PostPosted: Sat Jun 18, 2011 11:18 pm    Post subject: Reply with quote
Some more on that crated engine:
GT4
Nordschleife
Nordschleife
PostPosted: Sun Jun 19, 2011 12:28 am    Post subject: Reply with quote
Slightly modified torque delivery stats courtesy of "Porsche 996 - The Essential Companion" by Adrian Streather
In my previous post, although peak power figures were quoted from Porsche AG with associated engine speeds, the peak torque figures were stated by Porsche without engine speeds. The engine speed ranges were extracted from "simplified" (ie marketing) charts.
These are now corrected:
Adrian Streather wrote:
3.4
Power: 300 PS @ 6,800 rpm
Torque: 258 lbft @ 4,600 rpm
Idle speed: 700 rpm
Rev limit: 7,300 rpm
3.4 X51
Power: 320 PS @ 6,600 rpm (corresponding to 252 lbft)
Torque: 266 lbft @ 5,000 rpm
Idle speed: 800 rpm
Rev limit: 7,400 rpm
3.6
Power: 320 PS @ 6,800 rpm
Torque: 273 lb ft @ 4,250 rpm
Idle speed: 670 rpm
3.6 X51
Power: 345 PS @ 6,800 rpm (corresponding to 268 lbft)
Torque: 273 lbft @ 4,850 rpm
Idle speed: 670 rpm
Just as another piece of trivia, the engine (under X51 modification), like the Turbo block under X50 or GT2 modification, gets a new engine designation code
Even as a retrofit the X51 (and X50) retrofit TSB covers the procedure for amending the physical engine stamping (as well as the Porsche AG engine database).
BASE CODE > REVISED CODE = DESIGNATION
M96/01 > M96/01S = 3.4 X51 POWERKIT (320PS) - DME 5.2.2 Cable throttle
M96/02 > M96/02S = 3.4 X51 POWERKIT (320PS) - DME 7.2 eGas throttle
M96/04 > N/A = 3.4 X51 POWERKIT (320PS) incompatible with Secondary Air Injection (SAI) / OBDII/LEV Euro3 compliance
M96/03 > M96/03S = 3.6 X51 POWERKIT (345PS)
M96/70 > M96/70E = 3.6 TURBO X50 POWERKIT (450PS)
M96/70 > M96/70S = 3.6 TURBO GT2 POWERKIT (462PS)
M96/70 > M96/70SL = 3.6 TURBO GT2 POWERKIT MK2 (483PS)
 Filesize:  67.89 KB
 Viewed:  14937 Time(s)
doulas bader
PostPosted: Sun Jun 19, 2011 6:22 am    Post subject: Reply with quote
Mmmm! Maybe there should be a separate forum for the X50/51 cars, between 996 and GT cars. Clearly a breed apart...
Anybody also also got the LSD?
mankers
PostPosted: Sun Jun 19, 2011 9:12 am    Post subject: Reply with quote
^ Do you know the option code for LSD?
doulas bader
PostPosted: Sun Jun 19, 2011 11:26 am    Post subject: Reply with quote
no - but I know a man who does...
GT4
Nordschleife
Nordschleife
PostPosted: Sun Jun 19, 2011 1:09 pm    Post subject: Reply with quote
Option code depends on 2WD or AWD.
M220 = 2WD nonPSM = 40% (or dialable to 65% for track work)
M220 = 2WD with PSM = 22% (or dialable to 27% for track work)
X75 = AWD PSM standard = 22% (or dialable to 27% for track work)
Adjustment is via the diaphragm spring rates.
The PSM compliant low-locking 22%LSD was developed and offered after 2003 (MY2004/2005).
The low-lock LSD can be retrofit to any MY2004/2005 manual 996 (2WD or AWD).
There is no Tip compliant variant.
AWD LSD was not production line spec'able.
So if you had a MY2004/2005 C4, C4S or even Turbo,Turbo S you had to request an off-line factory bespoke mod.
The vehicle was built as normal then sent to the Special Wishes dept to be fit out with the PSM compliant 22/27% LSD.
As this was an "Exclusive" order it bears the code "X75".
Needless to say, this process added considerably to the order process (up to an additional 12 weeks).
It is debateable how much effect a 22% LSD (M220) model actually dynamically outclasses the standard Automatic Differential Lock (M224) on PSM equipped cars.
One big issue is the LSD is a wear and tear item and therefore without maintenance and replacement a worn M220 equipped car may fail to outperform an M224 car.
Then the LSD is just more weight at the back doing nothing!
mankers
PostPosted: Sun Jun 19, 2011 4:59 pm    Post subject: Reply with quote
^ I expected 3 or 4 alpha numeric characters! Cheers GT4 that's certainly a comprehensive reply. Smile
baptistsan
PostPosted: Mon Jun 20, 2011 11:33 am    Post subject: Reply with quote
Really tempted to chuck all of this on the car.
Modified oil pan partition box (larger alloy baffles with aperture valving replaces small plastic baffles).
Uprated exhaust gasket for larger exhaust ducts.
Adapted exhaust manifolds with larger cross-section and optimized flow behaviour.
Optimized inlet and exhaust ducts (machined and polished).
Modified intake system (modified cross-section - sand cast aluminium replacing plastic).
Assume I'd also need the modified oil pump to go with the new sump?
Worth doing or just a waste of time and money?
Stuart
2004 Porsche 996 GT3 Mk2
PostPosted: Mon Jun 20, 2011 11:50 am    Post subject: Reply with quote
The real benefit to the X51 is the additional cooling, internals and oil pick up, these are not cheap add on components. Everything else is your standard free(-er) flowing exhaust/ intake system, available from any aftermarket tuner.
As a package it's extremely expensive to retrofit properly and you will not recieve this back come resale.
Saying that I've added the oil pan (no extra pump) and the centre rad, I figured every bit helps...
Dont know
GT4
Nordschleife
Nordschleife
PostPosted: Sun Dec 22, 2013 10:17 am    Post subject: Reply with quote
Forgot to post the Power-up Edition photo:
ras62
PostPosted: Sun Dec 22, 2013 3:02 pm    Post subject: Reply with quote
Am I correct in assuming the X51 engine use the same IMS bearing as the standard car and therefore it is also prone to failure?
GT4
Nordschleife
Nordschleife
PostPosted: Mon Dec 23, 2013 2:49 pm    Post subject: Reply with quote
Yep.
But the high-G sump and dual oil pumps upgrade the block lubrication in general.
ras62
PostPosted: Mon Dec 23, 2013 10:46 pm    Post subject: Reply with quote
Thanks GT4. You have most likely seen this site but it was new to me and very informative. http://www.imsretrofit.com/ims-101/
GT4
Nordschleife
Nordschleife
PostPosted: Mon Dec 23, 2013 11:16 pm    Post subject: Reply with quote
Thanks, but yes (Early 2010 in the US, mid 2010 in the UK):
http://www.911uk.com/viewtopic.php?t=55510
DrMEMS
PostPosted: Sat Mar 14, 2015 6:47 pm    Post subject: Reply with quote
GT4:
This is great information! My book by Adrian Streather didn't differentiate between the 3.4- and 3.6-liter X51 engines. I'm having a 3.6-liter 996 X51 engine rebuilt right now. The builder took photos showing the X51 camshafts (they had "KIT" stamped on them) but didn't see anything different about the pistons (as you noted above, the 3.6-L X51 pistons are the same as stock). The engine block serial number starts off with "M96/03S", so I can tell that it is indeed an X51.
Based on what you said about the intake manifolds (parts 11 and 12 in the exploded diagram) being larger inside, I'll buy those, probably new from Porsche in Germany, as I haven't been able to find them used.
Do you have an exploded diagram showing parts 1-6 that you can post so I can tell what else is different from stock?
GT4
Nordschleife
Nordschleife
PostPosted: Sat Mar 14, 2015 11:04 pm    Post subject: Reply with quote
Will update next time I am in front of my PC.
GT4
Nordschleife
Nordschleife
PostPosted: Wed Mar 18, 2015 10:44 am    Post subject: Reply with quote
Exploded diagram 1-6 and pdf of detailed differences 1-12
X51 Detailed Differences
GT4
Nordschleife
Nordschleife
PostPosted: Wed Mar 18, 2015 11:08 am    Post subject: Reply with quote
Some more piccies:
1 = X51 upgraded dual chamber oil pump and additional return line
2-6 = X51 high-G vs std sump baffles and mating flanges
 Filesize:  80.63 KB
 Viewed:  8994 Time(s)
 Filesize:  104.85 KB
 Filesize:  91.87 KB
 Filesize:  79.08 KB
 Filesize:  63.32 KB
 Filesize:  68.89 KB
 Viewed:  8995 Time(s)
GT4
Nordschleife
Nordschleife
PostPosted: Wed Mar 18, 2015 12:35 pm    Post subject: Reply with quote
And exhaust system comparison
 Filesize:  132.37 KB
 Viewed:  8979 Time(s)
DrMEMS
PostPosted: Wed Mar 18, 2015 4:24 pm    Post subject: Reply with quote
Thanks for taking the time to document this. It seems like the X51 "power package" is as much about lubrication reliability as added power.
Previously you noted that for the 996.1 3.4-L engine, the pistons are different for X51 than for standard, while for the 996.2 3.6-L engine, the pistons are the same for X51 and standard. Are there any other differences you know of between X51 engines for the 3.4- and 3.6-L engines?
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Page 3 of 8
