Posted: Tue Sep 28, 2010 2:22 pm Post subject: Old v New Cayenne
Some images of the new Cayenne in the car park that reminds me I have the old model. _________________ 1971 Alfa GT 1300 Junior
1973 911E (restoration project)
1995 993 RS
2013 110 Defender
2018 Panamera Hybrid
Filesize:
209.79 KB
Viewed:
1668 Time(s)
Filesize:
250.96 KB
Viewed:
1668 Time(s)
Filesize:
253.84 KB
Viewed:
1668 Time(s)
Filesize:
245.34 KB
Viewed:
1668 Time(s)
Maxie Yas Marina
Posted: Tue Sep 28, 2010 2:37 pm Post subject:
Is the new one smaller than yours? I think the later design is slightly better.
~ Maxie _________________ Currently Porscheless, 2018 BMW 640d M Sport +
I think it is actually bigger, certainly it has slightly more legroom in the back.
Probably bad camera angle / pictures.
The new design is better, sleeker profile when you see them up close.
Its never going to be the best looking. Great to drive and ok off road. _________________ 1971 Alfa GT 1300 Junior
1995 993 RS
2013 110 Defender
GT4 Nordschleife
Joined: 08 Nov 2008 Posts: 30174 Location: Hertfordshire and Hampshire
Posted: Tue Sep 28, 2010 3:09 pm Post subject:
It's slightly longer, narrower and much lighter (something like 180kgs!)
Length
4846mm New
4782mm Old
Width
2155mm New
2200mm Old
Height
1705mm New
1699mm Old
Maxie Yas Marina
Posted: Tue Sep 28, 2010 3:20 pm Post subject:
GT4 wrote:
It's longer, but much lighter (something like 180kgs!)
I wonder from where? I'm guessing bonnet, doors and tailgate made of aluminium, most suspension components and more engine components than before? Gearbox casing from Aluminium? 180kgs is a heck of a lot.
GT4 Nordschleife
Posted: Tue Sep 28, 2010 3:42 pm Post subject:
Don't tell anyone, but the first one was made to be a proper off-roader, this one isn't.
The drive systems (including old gearbox and heavy-duty 4WD mechanicals, low range gearbox and locking diffs) and complex suspension have been jettisoned to save almost 10% weight.
The Cayenne S sheds 180kg even though it adds an additonal 70kg more standard equipment!
A new production process for the doors saves 39kg, ditching the transfer case with its low speed gearing 50+kg. Aluminium chassis components shaves a further 16kg. The optical biased wiring loom is 10kg lighter.
The Cayenne’s bodyshell uses "smart steel" for the body structure (variable thickness and welding techniques) with an aluminum bonnet, doors/tailgate.
Don't tell anyone, DMS have altered the boost on my Turbo S. Goes like the wind, faster than the new turbo. _________________ 1971 Alfa GT 1300 Junior
1995 993 RS
2013 110 Defender
GT4 Nordschleife
Posted: Tue Sep 28, 2010 6:22 pm Post subject:
Mum's the word.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum You can post calendar events in this forum
