991 : 2011- 19
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
berni29
Watkins Glen
PostPosted: Tue Sep 21, 2010 2:04 pm    Post subject: Endoscope inspection camera ideas required. Reply with quote
Hi
What I am trying to do is inspect the cavity around my windshield to see if there is any serious corrosion.
I am "happy" to take a wing off and drill a small inspection hole. Drilling a hole is not an issue as long as it is small. I will rustproof it and seal with a bung afterwards.
I have seen some inspection cameras but they all seem to need reasonably large holes apart from one which has a 5.5mm diameter head. That one does not have a light on it though.
Does anyone here have any experience of these things. Should I just give up on the idea?
The problem I have is that if I inject the rustproofing fluid into the cavity it will make a future repair more difficult if there is in fact some serious rust.
I have a couple of bubbles on my sill for instance. With that I was able to get a light source into the sill through one of the slots that retain the cover and then look through a different hole and see enough of the corrosion to make a judgement call. In fact the corrosion was fairly minor so I gave the inside of the sill a good blasting and injected the bubbles with rustproofing fluid through a hypodermic needle from the outside. That should slow the corrosion down a lot if not pretty much stop it. At some point I will have the sill repainted and a proper inspection done then.
All the best
Berni
993 C2 Tip 1994 187k miles. Black and Grey. M029 & Bilstein HD's, Elephant Racing RS bushes F&R, RS mounts, strengthened engine carrier, 100 cell cat inserts, HID's. Solid steering arms mod, top of the engine rebuilt, mapped by Wayne, suspension set up by Chris.
ShadesOfRed
PostPosted: Tue Sep 21, 2010 3:39 pm    Post subject: Reply with quote
I have one with a 9.5mm illuminated head. But beware that they're generally fish-eye lenses so the "view" isn't perfect.
I would avoid removing the wings - there will be tell-tale signs visible to the trained eye which might raise eyebrows about why they were removed. That said if they've been off before then it doesn't matter
Achtung
PostPosted: Tue Sep 21, 2010 5:23 pm    Post subject: Reply with quote
I have a notion of buying one of these myself. Could you post a link to the one that you have please Phelix. Smile
ShadesOfRed
PostPosted: Tue Sep 21, 2010 5:29 pm    Post subject: Reply with quote
http://ridgidtools.co.uk/ridgid-seesnake-micro-inspection-camera-mk-ii-95m-p-798.html
Achtung
PostPosted: Tue Sep 21, 2010 5:35 pm    Post subject: Reply with quote
Thanks for thay Phelix!
What do you think of the specification of this-
http://www.maplin.co.uk/Module.aspx?ModuleNo=257206
And this-
http://www.maplin.co.uk/Module.aspx?ModuleNo=259804
ShadesOfRed
PostPosted: Tue Sep 21, 2010 10:43 pm    Post subject: Reply with quote
Using a laptop as the viewing screen seems costs effective but note that both have larger heads.
Achtung
PostPosted: Wed Sep 22, 2010 8:37 am    Post subject: Reply with quote
Indeed, you need a head that will fit into a spark plug opening and still be able to be moved around.
The one that Connie Beecham uses in Holby City would be ideal! Question
the_rossatron
PostPosted: Thu Sep 23, 2010 3:02 pm    Post subject: Reply with quote
And this-
I have the maplin one. I used as my "eyes" when swapping out the starter motor. It enabled me to see the top bolt and then get an allen headed socket in it. Without it would have been near impossible.
The pathetic LED lights on it should not be relied on though, you'll need a lot of light from another source to get a usable image.
Achtung
PostPosted: Thu Sep 23, 2010 4:42 pm    Post subject: Reply with quote
And this-
Was that the £40 one or the £150 one Rossatron?
the_rossatron
PostPosted: Thu Sep 23, 2010 5:19 pm    Post subject: Reply with quote
It was just the £40 one.
vlad
PostPosted: Sat Feb 16, 2019 11:57 am    Post subject: Reawaken an old endoscope thread Reply with quote
Hi, just wondering if anyone has any recommendations for an endoscope with illumination (or better still one I could borrow Smile ).
I am trying to get my newly restored Fiat Dino registered with the DVLA with a colour change but the original V5C which had the chassis number did not have the engine number.
DVLA have now decided they want a photograph of the engine number ! But there is no room to get a picture - thinking I might be able to get a picture with an endoscope ?
vlad
PostPosted: Sat Feb 16, 2019 2:10 pm    Post subject: Reply with quote
seem to be cheap as chips so bought this one (kismet) Smile
 Filesize:  34.02 KB
 Viewed:  1596 Time(s)
AP90
PostPosted: Sat Feb 16, 2019 2:16 pm    Post subject: Reply with quote
I bought a camera off ebay for 60.00 quid second hand, to be honest it was a waste of time, I think you have to go high quality
I used it for various jobs and it failed 9 times out of ten
It was like a handset model with built in screen
It did help me spot the fact that the small boys had built a nest on the front left cylinder but it took a lot of wrangling
PostPosted: Mon Feb 18, 2019 9:30 am    Post subject: Reply with quote
Surprised 9year thread resurrection.
Achtung - Where is he now Dont know
The game's afoot. It's time to put a bit of (Colini) stick about......Why RUF when you can WUF
Tobesetc
PostPosted: Tue Feb 19, 2019 12:50 pm    Post subject: Reply with quote
There seem to be loads of these on the market - not sure why no one saw them on Amazon nine years ago Wink
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
chicb
PostPosted: Tue Feb 19, 2019 4:00 pm    Post subject: Reply with quote
Lidl have them on sale just now £50. The lens is 8mm dia
