997 : 2004- 78
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 20
Cayman : 2005- 11
adeymars
PostPosted: Mon Sep 06, 2010 5:49 pm    Post subject: Sleep mode alarm Reply with quote
How do I unlock my car from sleep mode without the alarm going off?
I just can't seem to find a way!
996 C2 Manual
Arctic Silver
Goodyear 's GSD3
Down 10mm
Lloyd 6 Light -Konvertierung..
mathamb
PostPosted: Mon Sep 06, 2010 5:57 pm    Post subject: Reply with quote
On mine I just unlock it with the key but dont open the door, lock it again with the key and then use the fob as usual and all is well
Porsches owned;
Currently ; 996 Cab (Autofarm silsleeve engine)
Previously; 964 Turbo 3.6, 964 C2, 928gt, 930 3.3 Turbo x2; 87 and 82, 911SC Sport, Carrera 3.0 sport, 911E.
Richard H
PostPosted: Mon Sep 06, 2010 6:05 pm    Post subject: Reply with quote
I couldn't do it on my '98 C2. As soon as I turned the key in the lock (either way) the alarm went off. It didn't happen very often though, as I seldom left it for more than 5 days. I learned to be quick.
On my Turbo, it's no problem, as I get the 10 seconds to turn on the ignition, or I can unlock/lock with the key to wake it up and then use the remote - AS MATHAMB SAYS.
GT4
Nordschleife
Nordschleife
PostPosted: Mon Sep 06, 2010 6:19 pm    Post subject: Reply with quote
+1
Just mechanically unlock car (key in door).
Don't open the door, but now remote receiver has been woken, plip fob to disable alarm.
porkerman
PostPosted: Tue Sep 07, 2010 2:12 pm    Post subject: Reply with quote
Mine is only a Sunday car so always left for more than 5 days.Ii just put the key in the drivers lock and turn it anti-clockwise, as though i was locking it (nothing happens as its locked) and then remove key and just unlock in the normal way with the key fob Thumb
Current ,
996 C2 Cab, Ocean Blue
Astra Estate (company car hence the need for some Sunday fun)
adeymars
PostPosted: Tue Sep 07, 2010 6:26 pm    Post subject: Reply with quote
Thanks gents,
Ill try all this on Sunday especially the lock again method.
996 C2 Manual
Arctic Silver
Goodyear 's GSD3
Down 10mm
garyw
PostPosted: Wed Sep 08, 2010 9:34 am    Post subject: Reply with quote
Not sure if its the same on the 996 but to wake the car on a 997 just lift the door handle.
The keyfob works as normal then. Smile
garyw
theno23
PostPosted: Wed Sep 08, 2010 1:15 pm    Post subject: Reply with quote
On my '98 the alarm goes as soon as I turn the key either way.
Like someone else said, I've leaned to be quick Smile
If I'm going to leave the car for a week, I usually remote unlock + lock it to stop it sleeping, I don't have battery charge problems, but I rearely leave it for more than 10 days.
- Steve
GT4
Nordschleife
Nordschleife
PostPosted: Wed Sep 08, 2010 4:02 pm    Post subject: Reply with quote
Just tried the door-handle pull on my 996, no joy.
Key only to wake the system.
Steff
PostPosted: Thu Feb 08, 2018 12:30 pm    Post subject: Reply with quote
Hi All,
I know this has been discussed a thousand times, but just want to clarify.
On my early 98 C2 I don't believe there is a way to wake from sleep mode without the alarm going off.
I've tried the technique of turning the key anti clockwise, then pressing the remote but that doesn't work.
When I unlock on the key I don't get 10secs before it goes off, the alarm sounds straight away and keeps going until I turn the key in the ignition.
Based on other comments I think this is normal for an early car but just checking.
I used to leave it unlocked in the garage to avoid it happening but got a bit nervous about whether the insurance company would pay out if it was stolen!
theno23
PostPosted: Thu Feb 08, 2018 6:00 pm    Post subject: Reply with quote
That's right - from what I remember I had exactly the same thing with my '98.
It's very annoying!
The only solution was to remember to blip the lock every few days to stop it going into sleep mode.
- Steve
Steff
PostPosted: Thu Feb 08, 2018 7:56 pm    Post subject: Reply with quote
Thanks Steve
demon
PostPosted: Fri Feb 09, 2018 9:31 am    Post subject: Reply with quote
There is a bit of a legend that the early 3.4 RHD cars may have been wired incorrectly from the factory (or rather failed to be re-wired).....
i.e. its only the drivers side door that allows 10 seconds after the door lock mechanism is rolled back, in which to insert the key in the ignition and prove it was intentional
...theory is that it was overlooked that the drivers door isn't always the left one and the car actually thinks its the passenger door that has been breached - cue alarm going off full blast
Someone mentioned that it would be relatively simple to resolve this via the connections in to the control unit.... but not sure of the truth of this, or if anyone has actually done this to resolve the issue
1998 Carrera - Black, no sunroof, manual, cable throttle, IPD plenum, 200 cell x pipe, Ohlins R&T, LSD, polybushed, Girodisc brakes, custom ("shaved") GT3 RS decklid, 997 sports seats, litronic headlights, RUF mirrors
jonindorset
PostPosted: Fri Feb 09, 2018 9:52 am    Post subject: Reply with quote
On my 98, if I open the door after more than 5 or so days I just get straight in it and start it up and the alarm stays silent. I always keep it on a CTEK 5 battery conditioner too. Recently, during the very cold weather, keen to take it out for a Sunday breakfast meet, I somehow managed to break the drivers door lock mechanism that resulted in an expensive factory order replacement Sad
theno23
PostPosted: Fri Feb 09, 2018 11:33 am    Post subject: Reply with quote
Ha! That's a really interesting legend, and would eplxain why some people didn't have the problem.
Does the passenger side have a physical lock? I don't remember, would be easy to test if so.
demon
PostPosted: Fri Feb 09, 2018 12:36 pm    Post subject: Reply with quote
Nope - hence at least some crawling under a seat, or similar, is needed to test
- I'm sure I have various wiring diagrams somewhere, but have yet to try and see how clear it is re. signals from respective doors, etc and simply re-jigging a couple of connectors
demon
PostPosted: Fri Feb 09, 2018 12:41 pm    Post subject: Reply with quote
just as an aside, have you ever heard your alarm go off? i.e. could be the siren is kaput (they actually "howl" for a while when they start to fail - thought I was hearing somekind of leak from the aircon system at first on mine..!) - or may/may not lend credence to a wiring recall or similar..... not sure if the battery conditioner would prevent the car from entering 'sleep' mode(?)
Anyone whoever set their 996 alarm off in a closed garage will recall exactly what it sounded like... as this is the last thing they clearly heard before their hearing was destroyed
Surprised
Steff
PostPosted: Fri Feb 09, 2018 1:28 pm    Post subject: Reply with quote
Ha ha, that is a shame that the passenger side doesnt have a physical door lock as that would have been an easy solution.
I am more than familiar with the alarm sound in a closed garage.... but unfortunately there doesnt seem to be a way around it.... other than open the garage door I guess.
By the way I also put mine on a CTEK if left for any period of time but this doesnt have any impact on sleep mode or not and so the alarm will still sound if I unlock after 5 days.
