I have had the car put on diagnostics and have been told fault codes for the window switch, wingmirror switch from the dme control unit as c123, c150 and c152, control box pcm.
for the high beams i have been told the fault code is fc 8021, no communication and no voltage to them.
i have also been told it is probably the convienience control unit or the control module or the vehicle electrical system or the loom.
ANY IDEAS ON HOW TO FIX IT OR EXACTLY WHERE IT MAY LIE.?????????
