Porsche Panamera racer unveiled !
Moderator
8 Feb 2008
7,361
When I saw this, I thought it was a wind up ! apparently not !!
These are the first pictures of the Porsche Panamera racer, which is being prepared by multiple touring car title winners N.Technology and Porsche Racing.
The car, which has an aluminium spaceframe that has been under construction since February, is powered by a 450bhp 4.8-litre V8 - up 50bhp on the Panamera S but down 50bhp on the Panamera Turbo.
It weighs 1320kg - down 550kg on the standard car.
The car will be driven in the Superstar racing series by eight-time touring car champion Fabrizio Giovanardi. The team will make its debut at Hockenheim in Germany, on 13 June.
http://www.ntechnology.it/
Here are the technical specs of the Panamera S racecar
Chassis: Steel frame with aluminum components
Engine: V8, front
Capacity: 4.8 litres, 4 valves per cylinders
Power: 450hp
Intake: Single throttle
Traction: Rear wheel drive
Friction: Carbon double discs diameter 184 mm
Gearbox/transmission: 6 gear sequential, self locking ramps and plates differential
Brakes: Front 355à—35 disc, with 6 pots caliper, Rear 330à—32 disc, with 4 pots caliper
Steering: Pinion and rack
Suspensions: Front double wishbone with 3 ways adjustable dampers, rear four rods multilink with 3 ways adjustable dampers
Wheels: Magnesium wheels 10,5à—18
Tires: Michelin 27/68-18
Aerodynamics: Front splitter, front and rear widened fenders, Rear wing (single supplier of the same element for all cars)
Weight: 1,320kg
"It weighs 1320kg - down 550kg on the standard car" ...... it looks like it was left overnight on some council estate
124,601
1,441,987
49,035
Retep
