996 : 1997-2005 29
Boxster : 1997- 14
berni29
Watkins Glen
PostPosted: Fri Nov 27, 2009 9:14 pm    Post subject: Harness loom replaced under recall and found........... Reply with quote
Hi There
Went to pick up my 993 from the OPC this evening and the service manager showed me some wiring that they changed under the recall. About 3 inches was totally burnt with bare wires and no insulation left. I am used to older cars and dodgy wiring, but even the colour blind Lotus electrical workers in the 60s and 70s would have been proud of this result. I cannot really believe that it did not short out.
Someone in a post I read about the recall said it was a service rather than a safety recall. Well I can assure you it is a safety issue!
As many have said, if you have not checked your car on this then get it checked.
Berni
993 C2 Tip 1994 187k miles. Black and Grey. M029 & Bilstein HD's, Elephant Racing RS bushes F&R, RS mounts, strengthened engine carrier, 100 cell cat inserts, HID's. Solid steering arms mod, top of the engine rebuilt, mapped by Wayne, suspension set up by Chris.
wizard993
1966 Singer Gazelle
PostPosted: Sat Nov 28, 2009 10:20 am    Post subject: Reply with quote
When I started rambling on about this a while ago(re the cedric thread) some said I was just "scaremongering"
This is what happens.....it can then start to overfuel and spew petrol which can then get ignited....possibly bye bye 993 Surprised Surprised .
Glad you got it sorted but there are still 993's running about with the wiring recal undone.
A quick phone call to your OPC with the VIN is worth doing if your unsure.
"The smallest feline is a masterpiece"
- Leonardo da Vinci
Zuffenhausen :O)
PostPosted: Sat Nov 28, 2009 10:29 am    Post subject: Re: Harness loom replaced under recall and found........... Reply with quote
berni29 wrote:
Hi There
Berni
Goodness me! Thank god you got the car checked out under the safety recall Berni! Surprised
If you can keep your head whilst all those around are losing theirs you obviously haven't grasped the seriousness of the situation!
993 C4 Varioram Coupe
berni29
Watkins Glen
PostPosted: Sat Nov 28, 2009 5:06 pm    Post subject: Reply with quote
Hi Wizard
I had been meaning to get in touch with Porsche and have it checked, but it was reading your posts in that thread that made it a priority for me, so many thanks!
As an aside the rear blower works now so I can have some heat in the car, so happy days there.
All the best
Berni
pierrebear
PostPosted: Wed Aug 01, 2018 7:43 pm    Post subject: Reply with quote
Chaps,
I know my car definitely hasn’t had the recall and am trying to get it booked in ASAP. Is there any way of checking myself how bad my wires might be?! Getting slightly worried!
Pierre
1995 Carrera 2 coupe manual, midnight blue
EX 997.1 Carrera 4S coupe manual, basalt black
EX 2003 Mercedes SL500, green black (dark blue!)
decgraham
PostPosted: Thu Aug 02, 2018 7:05 am    Post subject: Reply with quote
Hi pierrebear,
If the car hasn't blown up yet it probably wont. Just book it into Porsche and they will do the recall for FREE. I had an outstanding recall for the 2 front locking motors on my cabriolet top, although I'd never had a problem since ownership in 2000. Didn't get it done in Kuwait when I was there didn't get it done in the UK while the car was there either. I had it sorted by Porsche in Alicante Spain in 2011 Thumb no charge and a nice job, the motors were around €300 each Surprised They also told me that if and when I wanted to sell the car to get in touch Very Happy
ATB Smile
pierrebear
PostPosted: Thu Aug 02, 2018 8:21 am    Post subject: Reply with quote
Thanks very much decgraham - coming to the rescue once again thumbsup
Having done some Rennlist digging, I found the offending part numbers on the technical work sheet from Porsche Cars N. America. The car is at a local garage today for the thermostat and cooling fan repair and I've asked them to tell me what the part number on my wiring loom is.
Given the age of the car and depending on whether I have one of the offending part numbers, I think I'll probably bite the bullet (read pay lots of money for a ferry) and take the car over to a Porsche Classic Centre in GB soon.
decgraham
PostPosted: Thu Aug 02, 2018 8:53 am    Post subject: Reply with quote
Pierre,
Just give Porsche UK a call give them your VIN / Chassis number and they will tell you if the recall has been done or is needed.
You can then arrange your trip to the U.K. From what I have read it's a 2 days job.
ATB Smile
pierrebear
PostPosted: Thu Aug 02, 2018 9:36 am    Post subject: Reply with quote
Thanks, Graham. I have given them my chassis number and they've confirmed that it hasn't had the recall but does need it.
The issue was more that *apparently* they only replace in the event that particular part numbers are present (see page 12 of 36 in the attached using page numbers at bottom left corner: https://members.rennlist.com/pcaracing/files/harness/NA_Harness_TSB.pdf) - and they are not able to tell that from simply looking up the chassis number.
Anyways, I'll be booking a trip back to the UK soon - hopefully whilst the sun is still shining.
Cheers,
Pierre
decgraham
PostPosted: Thu Aug 02, 2018 10:10 am    Post subject: Reply with quote
Hi Pierre,
Thanks for the link I didn't have that Technical Service Bulletin Thumb
Just went out and checked my rear harness and mine is 993.607.016.16 so all OK. I knew that there wasn't a recall on my harness but no harm in double checking.
ATB Smile
jhrfc
1994 Porsche 993 Carrera 2
PostPosted: Thu Aug 02, 2018 1:18 pm    Post subject: Reply with quote
Reading this forum is the automotive equivalent, or reading a medical encyclopaedia. As said in 3 men in a boat 'you end up thinking you've got everything except housemaid's knee!'
tyinsky
1997 Porsche 993 Carrera 2S
PostPosted: Thu Aug 02, 2018 3:22 pm    Post subject: Reply with quote
This thread is a good heads up and worth taking note of.
My car is a 1997 car which Porsche GB confirmed is not subject to the recall as the loom issues had been rectified by then. But I have had an issue with mine and a wire degrading that caused ignition timing problems and many hours of diagnostic work to resolve. No idea what year the recall was issued but there is no escaping the wiring is over 20-years old.
Maybe a fire extinguisher is a good idea Question
pierrebear
PostPosted: Thu Aug 02, 2018 3:26 pm    Post subject: Reply with quote
Yeah, I am tempted to buy a fire extinguisher to keep especially for longer road trips etc. I am going to get it booked in with an OPC Classic Centre asap - just waiting for Hatfield and Swindon to call me back.
tyinsky
PostPosted: Thu Aug 02, 2018 4:28 pm    Post subject: Reply with quote
Fire extinguisher probably a handy thing to have in reach for personal protection too. Gun Fire
pierrebear
PostPosted: Thu Aug 02, 2018 5:26 pm    Post subject: Reply with quote
Agreed that it is worth checking to ensure that one's wiring harness has been redone. I had a quick look and mine is one of the offending part numbers as seen in the Technical Service Booklet.
Couple of pics attached - part number is on the white sticker on the wires themselves. The date was written on in fountain pen! Laughing
Wires in the box itself look absolutely fine, but the issue (as I understand it) might well be what's happening elsewhere in the harness where there's more heat...
 Filesize:  51.51 KB
 Viewed:  4217 Time(s)
 Filesize:  49.46 KB
tyinsky
PostPosted: Thu Aug 02, 2018 6:12 pm    Post subject: Reply with quote
Exactly that. The bit in the engine bay was the recall part (for earlier cars) as I understood from talking to Porsche GB, but my issue was with the wiring buried deeper in the car.
Anyone got a beat solution for a fire extinguisher which does not intrude the cabin much?
ch3tman
1995 Porsche 993 Carrera 4
PostPosted: Thu Aug 02, 2018 7:50 pm    Post subject: Reply with quote
This seems like an interesting and discreet option...
Open Youtube Page
Mounted in a 993:
https://rennlist.com/forums/993-forum/918409-what-did-you-do-with-your-993-today-79.html#post15120119
*FOR SALE*
OEM 17" Cup II Wheels + Tyres
jhrfc
PostPosted: Thu Aug 02, 2018 8:03 pm    Post subject: Reply with quote
Sorry if i'm being thick where are thos pictires taken? the fuse/relay box in the frunk? or somewhere else?
Endoman
PostPosted: Thu Aug 02, 2018 10:06 pm    Post subject: Reply with quote
Engine compartment. I had the recall done soon after I got the car. The dash instruments went haywire and it ran very rich. Indie where I bought the car had no idea. Not impressed do not use them anymore.
decgraham
PostPosted: Fri Aug 03, 2018 8:00 am    Post subject: Reply with quote
It's in the engine compartment, LHS rear next to the rear fan, black box with a yellow warning sticker on it.
ATB Smile
 Filesize:  524.25 KB
 Viewed:  4028 Time(s)
 Filesize:  108.28 KB
 Viewed:  4031 Time(s)
Goto page 1, 2, 3  Next
Page 1 of 3
