Have a manual 997 Carrera 2S of which i needed to change gearbox oil. Spoke to local Porsche Dealer who advised 3.6 litres of 75W-90 fully synthetic. Easy job to do so drained old oil out which amounted 2.5 Litres. Noticed that the car had been leaking oil around the driveshaft seals so thought car had probably lost 1 litre over time which was slightly alarming. After replacing the gearbox oil with 3.6 litres found the car difficult to get 1st and 2nd gear when cold. Called local dealer again to check on amount and was then advised 2.9 litres, when i asked why they said 3.6 they replied "i'm not sure who advised that" which i replied the parts adviser that sold me the oil!
My question is does anyone know the exact quantity the maunal box holds and what fluid is best as i am going to replace it again when i change the driveshaft seals. I am also now worried that the dealer has given me the wrong oil as they only sold it per litre in a clean container so wasn't labelled up apart from the Porsche invoice that said Gear oil.
