997 : 2004- 65
996 : 1997-2005 35
964 : 1989-1993 1
Daniel
2000 Porsche 996 GT3 Mk1
PostPosted: Sun Sep 06, 2009 3:47 pm    Post subject: Gemballa Panamera Reply with quote
Quote:
For those who don't think the Panamera is pretty enough, there were always going to be a raft of styling options available from the Porsche converter crowd - and first out of the blocks is Gemballa with these images of its new 'Mistrale' package.
While others have criticised the Panamera for aping Porsche's classic rear-engined sports model, Gemballa pushes the connection further with extended front and rear wings that it says are a 'visual allusion to the classic 911-design'. Other visual differences to the standard car include a more sporty front spoiler with larger air intakes and a carbon lip, as well as a new bonnet with slotted ventilation ducts that Gemballa says should reduce lift.
Wings said to allude to 911They also propose a rear end treatment featuring a new apron with integrated diffuser and a quad-tailpipe sports exhaust system.
The Gemballa Mistrale rides on a re-programmed air suspension model that lowers the COG by up to 40mm, and those 22ins alloys hide an upgraded set of stoppers - 6-piston callipers gripping 420mm discs at the front, and 4-piston callipers with 380mm discs at the rear.
Buyers may need that extra stopping power if they start to dip into the Gemballa power options bin - the company says it plans further modifications that will include performance enhancements up to 750bhp for the turbocharged Panamera.
*Current - GT3 996.1 Clubsport (Manthey K400)
EX VR993 - C4
EX 993 - C2
EX GT3 996.1
EX Cayman 3.4 S 987.1
EX Megane R26R #36.
EX Cayman R
 Filesize:  27.41 KB
 Viewed:  1316 Time(s)
 Filesize:  20.46 KB
 Filesize:  26.56 KB
GT4
Nordschleife
Nordschleife
PostPosted: Sun Sep 06, 2009 10:00 pm    Post subject: Reply with quote
hmmm, carbon roof for those concerned about weight saving in their five-door, four-wheel drive, 5m, 2 tonne behemouth! Nice.
Wattie
PostPosted: Mon Sep 07, 2009 8:24 am    Post subject: Reply with quote
Carbon fibre roofs are an absolute joke - carbon fibre has no stiffness whatsoever in flat sheet form - you would get a lot more rigidity, with less weight, using steel or aluminium! Also, carbon fibre is not repairable - so get a scratch or a crack and it's a whole new panel required every time: So really not a suitable material to ever be used on the outside of a motor car!
It makes me laugh when people assume that because something is better in one application, it will always be better wherever you stick the stuff... nooo
