Looking for opinions on the latest dilemma -If you are an obsessive, meticulous 997 owner you will have cast a critical eye over the naff wheelbolts at some time. Indeed you will also have seen articles regarding wire brush refurbishment and some fresh paint. However I spotted on a 911 specialist website, stainless steel replacements. Thinking this would be the answer to all my problems I ordered a set. They arrived last week and I have to say very nice looking pieces of engineering, I quickly whipped off one of the old ones to find that the new bolts are 7mm longer. So while not yet questioning the supplier why this is so, I did think I would call Porsche in the hope that I may get a tech to confirm that 7mm will make no difference thinking that the drillings would be well in excess of this into the hubs. Sadly and perhaps as expected I got a case of ...No Porsche cannot recommend any fitting of non supplied components esp NOT wheeelbolts - will invalidate warranty should there be any issues arising - When questioned why... the issue relates to heat causing bolt expansion and thereafter the rationale became less clear...
So the question is (short of me taking the wheels off and determining the thread depth) has anyone been here before and what are your thoughts on the matter ...dont say plastic covers !!
Also this refers to a C4S which does have different wheel sizes to S.
Thanks for your opinion
