Picked up the car last Friday and on Tuesday morning checked my coolant level. The level was just below minimum. So per manual I topped up with aprox 1/2 litre of water and phoned opc to tell them the fluid has either leaked or not been checked, in any case its booked in for friday to check. Any way from top up yesterday to this morning the level has dipped slightly with no water on the floor. You cannot really see the state of the oil from the telescopic refilling nosil so is there an idiots way to see if there is an internal leak?
I checked and refilled both times in the morning so the car had been left overnight.
I also have a flat spot in 2nd at around 2500 revs which appears to be common. I do hope its not going to be a problem.
