996 : 1997-2005 48
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayman : 2005- 17
Cayenne : 2003- 7
Macan : 2014- 3
912-914-924-928-944-968 3
tigerd
PostPosted: Tue Dec 16, 2008 6:55 pm    Post subject: Question for cayenne experts Reply with quote
Hii i have a 05 4.5 s cayenne, recently i have noticed that when im driving and then gently put my foot on the pedal, you can here clunking type noises as if the car is struggling to find the right gear, it almost shudders. The acceleration does not require the car to drop down the gears but this clunking and shuddering still happens.
I have to say that if i do accelerate a lot, the car drops down the gears and there is no problem.
Anyone any idea what this issue might be? Its more annoying than anything else
Porscheuro
PostPosted: Tue Dec 16, 2008 7:09 pm    Post subject: Reply with quote
what sort of mileage has it done. do any warning lights display,
may be worth someone changing the tiptronic box oil whilst also checking underneath the vehicle,
tigerd
PostPosted: Tue Dec 16, 2008 7:16 pm    Post subject: Reply with quote
hi its done 55,000 and was serviced at 53,000. At that time i can remember saying to the service manager of the clunk and he said its becuase of the size of the gearbox etc etc, however he mentioned something about a reset r something, its only the last week its started to happen again.
Should i think about changing the gearbox oil?
also no warning lights are coming up
sportsandclassic
Approved Trader
PostPosted: Tue Dec 16, 2008 8:42 pm    Post subject: Reply with quote
Hello
They suffer alot from gearbox hydraulic valve chest failures and this can give the symptoms you describe...you can try the adaptaption reset at a specialist with a piwis tester....but i doubt this would work.
Mike
tigerd
PostPosted: Tue Dec 16, 2008 9:28 pm    Post subject: Reply with quote
hi Mike i really hope like the last time a re-set will do it, but what exactly is gearbox hydraulic valve chest failure?.
Surely a fault like that would at least fire a warning light up
thanks
wizard993
1966 Singer Gazelle
PostPosted: Tue Dec 16, 2008 10:59 pm    Post subject: Reply with quote
http://www.911uk.com/viewtopic.php?t=39704&highlight=cayanne
Have look at this thread too
"The smallest feline is a masterpiece"
- Leonardo da Vinci
