allybally007
- Joined
- 3 Dec 2008
- Messages
- 5
Has anyone come across this problem? I have a 56 plate 997 4s. In the last few months the car will intermittently refuse to start when the key is turned. The depress clutch pedal message shows up, despite the clucth being down. Eventually the car starts. I assume the sensor on the clutch pedal is playing up? I had a look without dismantling anything and found what appears to be a sensor switch which activates in the first few cm of travel but there must be another sensor which goes at the end of clutch travel. Has anyone had this problem? Is there an easy fix or a way of bypassing the sensor?
Thanks.
(p.s. what I really need is a Haynes manual!!)
Thanks.
